Old 06-04-08, 10:42 AM   #31
camcruiser13's Avatar
Originally Posted by '74 UA FJ View Post
looks good cam. I will be building one very similar. Not sure if I will use a johnny joint though. Let us know how that works out.
i almost didnt, but then i saw my brothers when it flexed and it seems to bind up pretty good, and i thought the joint would ease some of that. its probably not a necesity. sp
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 06-04-08, 11:00 AM   #32
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
Maybe not, but it looks like an excellent idea. Post up where you got the joint and the shell.
Andrew
1997 FZJ-80 Driveway queen
Old 06-04-08, 11:28 AM   #33
i got it here, probably not the cheapest or the best place but i was in a hurry to get it started and they had what i needed,
Sam's Offroad Equipment-Your source for Warn Winch, Teraflex, Rancho, Service and Installation i think it was 45 bucks or so. shipping was ridiculously retarded $$$$ and i thought sor was bad
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 04:54 PM   #34
inkpot's Avatar
TLCA# 10338
Howdy! I used a double joint on the front of mine to allow slight axle movement front to rear. I put a fixed bushing on the cross member, and then made a 4" shackle to drop off of that. My "Y" arms join a few inches before the shackle and they are mounted onto a heim joint I picked up for about $20 at the local John Deere dealership. They have some nice BIG stuff there, like shackles, D rings, chains, PTO drives, etc. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is online now   Reply With Quote
Old 06-04-08, 06:24 PM   #35
KI6MIE
TLCA# 11734
Thanks. Bookmarked.
Andrew
Old 06-04-08, 09:27 PM   #36
ok ok were did i leave off??
oh yes the jonny joint, got it in and the snap ring in its place. now i could hang the baby shackle and start getting my lengths for my bars
as i now knew the length of the lower bar i notched it as well
also i notched and tacked the upper link end that is fixed to the axle
and here is the thickness of the bars, i told you they were thick
perfect to crush rocks with
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 09:30 PM   #37
i then loosly put it together ti get the upper link length, as i already tacked one end of the upper i ran a bolt through it for proper alignment
now in this pic you can see just how well it will protect the driveline
another angle,
i wanted it below, but not too far hangin down
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 09:34 PM   #38
now i knew the length of the upper and lower i could notch the upper to sit tight on top of the lower, now im not one to bitch and moan but notching this peice almost put me in my grave,
and after the grinder and some elbow grease, i got the fit i was looking for
so then tacked it and got it set for the burn
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 09:37 PM   #39
not that kinda of burn (although it prbably wouldnt hurt)
got em burned
and then it was time to attch the half moon pieces
another
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 09:38 PM   #40
got that done
and it was time to let them cool make sure it all fits right too
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 09:40 PM   #41
and so as they cooled i tried to find some spray paint, wanted all black but only found 1/8 of a can in black and i had some red so i thought, why not, itll be trashed and covered in mud most the time anyway
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 09:41 PM   #42
80s muncher
2badfjs's Avatar
Very Nice!!!!! :d
SOLID ROCK OFF-ROAD
http://www.solidrockoff-road.com/
1991-92 80 series sliders available, WITH CAT PROTECTION!
It's how YOU want it, i'm just here to build it for you.
SLIDERS FOR 40s' 60s' and 80s' plus a little bit more
2badfjs is offline   Reply With Quote
Old 06-04-08, 09:41 PM   #43
then i painted the axle peices and it is all drying as we speak and will be assembled tomorrow after i weld in the crossmember
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 09:42 PM   #44
i will get back later after it is all dried and hopefully fully assembled, golf tomorrow so i dont know how much ill get done.
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-04-08, 09:56 PM   #45
you alway do such damn fine work My brother needs a trac bar so Im glad that you posted this up nothing better than someone else better skilled leading the way
cruiserjunkie is offline   Reply With Quote
Old 06-04-08, 11:16 PM   #46
1973Guppie's Avatar
wow, those are some colors! Are you david lee roths cousin?
j/k, looks great
Front disc brakes: http://forum.ih8mud.com/showthread.p...+brake+dummies
1973 FJ40 - Finished! Vortec/NV4500/ARB's/SOA
FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40
1970 FJ55 - Restoration Project in the works /2F/AC/PS
FJ55 Restoration Thread: http://forum.ih8mud.com/40-55-series-tech/102079-guppies-fj55-build-thread.html
1973Guppie is online now   Reply With Quote
Old 06-04-08, 11:30 PM   #47
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Why the shakle type mount up front?
I realize it is designed that way, but why? Wouldn't it still allow your axle too wrap the full motion of the shackle movement?
D'Animal is online now   Reply With Quote
Old 06-05-08, 12:09 AM   #48
incogrhino's Avatar
TLCA# 16350
So it can move with the travel of the axle on the leafs.But it won't let the axle roll.
Drafting the big bricks with my little brick
78'&80'fj40'&a83'fj60
Great Lakes Land Cruisers
incogrhino is offline   Reply With Quote
Old 06-05-08, 12:18 AM   #49
fj40forlife's Avatar
TLCA# 5624562435
It would just pull the shackle down and stop axle wrap. i have mine like this and works great.
What is rock crawling?
My build http://www.pirate4x4.com/forum/showthread.php?t=637144
fj40forlife is offline   Reply With Quote
Old 06-05-08, 12:20 AM   #50
bingo
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-05-08, 12:22 AM   #51
fj40_73's Avatar
I may be wrong but I think the triangle wins. That is, the triangle stops the twisting. Most of the stress is at where the top bar meets the bottom bar. I think some run the top bar all the way to the joint, but with that thick of tubing, he could of had them meet in the center and still be fine. The baby shackle keeps it from limiting flex, I am guessing.
How much dose that thing weigh?
Looks good and will definitely do the trick.
edit: damn, took to long typing..........
73 FJ40 - Build Thread
350 V8, NV4500, Orion HD, F&R ARB.
Power Steering, 4" Spring Lift
Volvo Seats, 22 Gallon Gas Tank
Disk Brakes Front and Rear
fj40_73 is offline   Reply With Quote
Old 06-05-08, 02:06 AM   #52
inkpot's Avatar
TLCA# 10338
Howdy! Yea, this is a great working setup with the shackle. Ya did good on choosing some super tube for the main sections. Mine is very similar, and since I have double LockRights, I run a lot of 2wd low range. I can hammer the throttle and the pinion does not climb up at all. Two years ago I did a nasty hill climb, but I forgot to slip it back into 4 low. I hardly noticed the difference! Much better traction and control with a good anti-wrap bar. Certainly worth the time/work/money. You're gonna luv it! Good job. John
CSC #41
Old 06-05-08, 10:39 AM   #53
thanks, im hoping for some good results. does your shakle hang straight down or is it a little tilted like mine? just wondering if i should move the crossmember back a tad or leave it.
any ideas. probably doesnt make a diff. i dont know
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
