#31 |
GSMTR Chair
Just got off the phone with the metal shop. Getting them to bend up a 1.5 deep pan that is 10"x14" that I should be able to sink under my seat without a lot of modification.
Cost me $25. __________________ Marshall Upstate Cruisers Toyota parts number lookup / don't be stupid click this link and save yourself a whole lot of trouble. The Great Cruiser Part Links Thread Buying a Land Cruiser Guide 73 Fj55 Big Ugly 76 FJ40 ROTW Big Gay 2f Build 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
#32 |
Thanks, i'll only need about 6'.
Jeremy __________________ Project Evelyn 71' FJ40 W/ 78 2F, 4 speed Tranny & Transfer SOA, 38" TSL's, 4W discs |
#33 |
GSMTR Chair
Finally got all my stuff. Now for the wiring.
#34 |
Cool! I'll follow this on closely. Looks like a good setup... What color is the battery box going to be?
__________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
#35 | |
GSMTR Chair
Need some more help. Bought a Blue Sea fuse block to run all the new stuff and some old stuff. Didn't really put a whole lot of thought in it. Most of my stuff I plan on connecting to it would be switched power. Since this only has one input to all 12 circuits I'm only going to be able to wire it one way or the other. I thought about just buying a smaller 6 terminal block and making it non switched. Question. I don't want the ignition switch to take the full brunt of the switching to the 12 circuit panel. What good relay is there that would work for 100amps and under? I was thinking about one that is latching. __________________ Marshall Upstate Cruisers Toyota parts number lookup / don't be stupid click this link and save yourself a whole lot of trouble. The Great Cruiser Part Links Thread Buying a Land Cruiser Guide 73 Fj55 Big Ugly 76 FJ40 ROTW Big Gay 2f Build 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
#36 |
LIFER with a 2F-ETI
Part No is in the Pic 100amp Solid state, hit search for your local stockiest or if you can wait a few days PM me I have one in the shed new and unused.
__________________ If the wife's not complaining your not spending enought time with your 40! 2F+3FE+T+I-3F=2F-ETI THE MULE @ 400hp max Est @ 15PSI DYNO'd at 8PSI 155kw/208hp and 650Nm/480ftlb @ the RW Links Sponsored by OZZIEWEBHOSTING Mac's Space
#37 |
Do the solid state DC relays "leak" like the AC ones do? They use those on sterilizers and film processors, but unlike a mechanical relay when they are de-energized they can still leak enough voltage to shock you. With 12V the shock wouldn't be as big of a concern as the potential to run down a battery if left unattended for long periods of time.
#38 | |
LIFER with a 2F-ETI
#39 |
GSMTR Chair
Pan is 1/8 steel so I shouldnt have an issue need to weld then paint
Fits perfect. You could of made the pan half an inch deeper and it still would have worked, __________________ Marshall Upstate Cruisers Toyota parts number lookup / don't be stupid click this link and save yourself a whole lot of trouble. The Great Cruiser Part Links Thread Buying a Land Cruiser Guide 73 Fj55 Big Ugly 76 FJ40 ROTW Big Gay 2f Build 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. Last edited by Trollhole; 06-24-08 at 08:52 PM. |
#40 |
If you want a good mechanical continious duty solenoid good for this app then look at this
http://order.waytekwire.com/CGI-BIN/...B63082+M37+ENG 85 amp continous, 85 amp make AND break. 4 terminal insulated and water proof. Doubt you would ever be pulling all 100 amps through your fuse box so this would work. $27.75 from Waytek Part # 77003 Here ia a 12V 100 amp continous duty from Grainger made by White Rogers... $25.45 Electrical > Solenoids > DC Power Solenoids > DC Power Solenoid,12V,Amps 100 : Grainger Industrial Supply With that long of a run make SURE to fuse or circuit breaker this wire! __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
Buy PSP | CreditCards | Cheap Car Insurance | Compare | eBay |
