Old 05-21-08, 04:21 PM   #1
Any Advice For PS Pump Bracket on '74 F ?
Hi guys, I bought a PS conv. kit from SOR for my '74 FJ40, and have pre '80 saginaw box and pump. Any proven brackets for mounting pump on DE-SMOGGED F with no smog pump? All the after market brackets I see are for '75 2F's ????
Thanks Randy
ojaij40 is offline   Reply With Quote
Old 05-21-08, 05:27 PM   #2
Noaccount Webwheeler
Degnol's Avatar
TLCA# 14529
Get Bill Dorry's pump mount. Good guy, good product, good price, good hardware(included!) good INSTRUCTIONS!
I think it is also a plus that it does NOT use the head bolts. It fastens to the motor mount....but opinions vary.
Ed
Wdorry@yahoo.com
There is nothing so depraved as a man in the depths of an ether binge
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
Degnol is offline   Reply With Quote
Old 05-21-08, 08:37 PM   #3
Focus on the Journey
bsevans's Avatar
TLCA# 16217
Classic Cruisers used to have a couple of solutions that mount the pump either to two head bolts or in place of the air pump and uses a reconditioned water pump double pulley eliminating the slipping issues with the narrow width GM belt.
PS Conversions
78 FJ40
ARB's F&R, Rear Disks, DUI HEI, 200 Amp Alt, OME 2.5, 33x10.50, PS, RE8000, Stout Rear Bumper, 4+Plus Sliders/U-Bolt Flip Kit/Tie and Relay Rods/Anti-Inversion Shackles, Dual Tanks, BTB Dash Box, Tuned Ceramic Coated Headers, Extended Axle Vents, BrakeQuip Custom Certified SS Brake & Clutch Flex Lines
|ROTW My Yoda|HD Skid Plate|Recovery & Windshield Washer Tanks|Toyota Pulley on GM Pump|Bypass Hose|
bsevans is offline   Reply With Quote
Old 05-21-08, 10:22 PM   #4
Grindin Boogers
Toyo FJ40's Avatar
I moved my alt to the passenger side on my 74 with a 78 alt mount and made a pump mount to fit the bracket under the air filter.
I used a Toyota pump but a GM pump should work.
Kevin
72, 74 and 78 FJ40s
Toyo FJ40 is offline   Reply With Quote
Old 05-21-08, 10:44 PM   #5
I Like It !!!!
Thanks everyone, I like the idea of putting my ALT. where the smog pump used to be.
Homeowner Loans | Conservatories | New York Hotels | Loans | Personal Loans
