Old 05-21-08, 07:43 AM   #1
TemeculaTim's Avatar
TLCA# 17320
I am a happy camper- PS upgrade is done
Just finished my saginaw conversion.
Name:  May 2008-half doors-power steering 031.jpg
test fit before welding everything up. I also decided to add a 5/16 plate where the box penetrated the frame for a little extra strength
Name:  May 2008-half doors-power steering 029.jpg
I used the Borgeson 36" DD telescoping steering shaft- It fit between the motor mount and frame.
Name:  May 2008-half doors-power steering 037.jpg
Ready for some rocks now
Tim
1976 FJ40 - Trail Rig
1969 &1972 FJ55'S -Dos Puerco's
2003 Toyota Tundra 4X4 access cab - Daily Driver
2005 Subaru Outback - Wifes Dog Hauler
1990 Kubota B20 4X4 TLB- Weekend Work Horse
1997 Honda XR600 - The Ultimate Baja Pleasure Machine
And abecker's 1964 FJ45 SWB project
TemeculaTim is offline   Reply With Quote
Old 05-21-08, 07:47 AM   #2
TLCA# 17320
here is a shot with the bumper on.
Name:  May 2008-half doors-power steering 039.jpg
Old 05-21-08, 09:05 AM   #3
UNO_RACING's Avatar
Very nice job. Enjoy the simplcity of driving in the rocks....
Everyone is trying to accomplish something big, not realizing that life is made up of little things.
--Frank A. Clark
UNO_RACING is offline   Reply With Quote
Old 05-21-08, 09:59 AM   #4
FJ40 MNTCRZR's Avatar
TLCA# 16256
Whats the deal with the wire ties
" IF I HAD TO EXPLAIN,YOU WOULDN'T UNDERSTAND "
2008 Sandstorm FJC
FJ40
LEXUS
HARLEY
THE GOOD LIFE !
FJ40 MNTCRZR is offline   Reply With Quote
Old 05-21-08, 10:05 AM   #5
In the garage
John Smith's Avatar
TLCA# 9074
My guess it they are to hold the rubber bellows boot to the steering slip shaft to keep debris out. These are found on many factory setups and are normally held on with metal band clamps but a zip tie can do the job just fine also I bet.
The blue high and low pressure hoses look very nice!
79 FJ40 & 78 FJ55
http://users.starpower.net/johnsmith <- Detailed ToyBox install instructions
Please help save the Upper Tellico OHV area, Donate to the Rescue Tellico Fund http://www.sfwda.org/trails/tellico/donate.html
John Smith is offline   Reply With Quote
Old 05-21-08, 02:27 PM   #6
AKFJ62's Avatar
can you take pics of the hole steering shaft from the fire wall to the box?.
bythe way it looks good, enjoy
AKFJ62 is offline   Reply With Quote
Old 05-21-08, 03:59 PM   #7
Search 1st, THEN ASK
zuluzeugma's Avatar
Does that thing ride hella-hard? Your front shackles are almost verticle.
72' FJ55 - SOA, SR, DB, FJ62 PS, Webber, Header, H.E.I., 37 X 12.5 X 15 MT/R's, Savanah-heat air freshener.
73' FJ40 - Long term project in the hands of HappyChappy
83' FJ60 - Mint Condition
07' FJC - Atrac Hack - DD
08' Tundra, 4.7 2WD - Company Truck
zuluzeugma is offline   Reply With Quote
Old 05-21-08, 04:17 PM   #8
1973Guppie's Avatar
Hey Tim,
looks good, that's it,
I won't randomly pick out anything else that looks wrong on your truck!
let's go wheelin!
Noah
Front disc brakes: http://forum.ih8mud.com/showthread.p...+brake+dummies
1973 FJ40 - Finished! Vortec/NV4500/ARB's/SOA
FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40
1970 FJ55 - Restoration Project in the works /2F/AC/PS
FJ55 Restoration Thread: http://forum.ih8mud.com/40-55-series-tech/102079-guppies-fj55-build-thread.html
1973Guppie is offline   Reply With Quote
Old 05-21-08, 05:59 PM   #9
TLCA# 17320
John Smith was correct- Just a dust boot- like they use for shocks. - BTW- I did trim the excess off so it would reduce drag and friction
The shaft is a Borgeson telescoping shaft. They have a nice web site that has some good info.
Actually rides nice for 32 year old springs. Give me a little time and I will correct that shackle angle-
Originally Posted by 1973Guppie View Post
Hey Tim,
let's go wheelin!
Noah
Ready for Big Bear
Old 05-21-08, 06:01 PM   #10
venpick's Avatar
TLCA# gave up
that cruiser looks clean. very nice.
77 fj 5.7 vortec, h55f, marks 3.05:1 geared transfer, 4.88:1 ring and pin., arbs,six shooter knucks with high steer, marfields, 3 link front, 4 link rear, custom dents.
venpick is offline   Reply With Quote
Old 05-22-08, 02:14 AM   #11
Looks good! What steering column are you using? I'm tring to get mine wrapped up, but the steering shaft is hitting the frame on the steering box side of the motor mount.
BTW mine is a 71' Fj40, SBC, saginaw 4.25 box, tilt column from a 1992 chevy truck.
ToyLet503 is offline   Reply With Quote
Old 05-22-08, 06:43 AM   #12
Weedhopper's Avatar
Looks GOOD !!!
Speed bumps hurt
78 FJ 40 Russstard..and a sistership for parts
Weedhopper is offline   Reply With Quote
Old 05-22-08, 08:22 AM   #13
TLCA# 17320
Originally Posted by Weedhopper View Post
Looks GOOD !!!
Thanks for the nice comments- I took way longer on this than I should have out of a desire to do it clean, right, and have something safe! I kept my stock stering shaft- just cut it above the rag joint. I had the u-joint at the shaft connection welded on by a professional- again with keeping safety in mind.
Name:  May 2008-half doors-power steering 028.jpg
The shaft was a 36" DD with a 1" bottom and 3/4" top. It cleared the motor mount and frame barely- but with some wiggle room.
I would strongly reccomend this shaft and u-joint set up for anyone doing this conversion- it's just superior to a solid shaft set up and the u-joints are trick sealed bearing units.
Now I am planning for the next mod- SOA-high steer.
Tim
Old 05-22-08, 05:00 PM   #14
jabxyz's Avatar
TLCA# 18735
Tim,
You got a link for the Borgeson shaft site? What hose did you use for the pressure hoes? BTW The rig looks nice.
Thanks.
Just looking for a straight answer in a twisted world
Build thread: http://forum.ih8mud.com/40-55-series...storation.html
Member Mudders in Latin America
http://el-salvador-mud-4x4.blogspot.com/
Get your OEM Style Soft Tops Here...
jabxyz is offline   Reply With Quote
Download movies | Bad Credit Mortgages | Loans | Remortgages | Credit Card Debt Consolidation
