Old 05-20-08, 09:49 PM   #1
ojaij40 is on a distinguished road
Sorry, just don't get what shackle reversal accomplishes
Hi guy's, read almost all your posts, and enjoy them all, What does shackle reversal improve? Randy
ojaij40 is offline   Reply With Quote
Old 05-20-08, 10:04 PM   #2
peesalot is on a distinguished road
After running one for some time and watching similar equiped vehicles with no sr I would say nada, leave it shackle forward.
John on the hawgs
peesalot is offline   Reply With Quote
Old 05-20-08, 10:24 PM   #3
TLCA# 13526
greenfox is on a distinguished road
I would say don't do it!
What are plans for the rig?
crawler, or daily driver.
73 FJ40 Green - Original
74 FJ40 Red - (BMFCAGE) SOA 36X17IROKS weldedrear ARBfront and what ever els you can think of
97 FZJ80 Green (the wife's) - locked
67 fj45lwb in the works
greenfox is offline   Reply With Quote
Old 05-20-08, 10:28 PM   #4
woa woa whoa,...
I was just trying to figure out why ANYONE would do it, what does it inprove? Randy
Old 05-20-08, 10:37 PM   #5
bkcruiser's Avatar
bkcruiser is an unknown quantity at this point
Approch angle, unless ya install one o them caster correction type
70fj55,350/700,203,splitcase,oba,obw,hws,fj60axles,4.88's,arb 's,37's,screwlocks,cruise control,4 shifters,and a pig hood ornament!
bkcruiser is offline   Reply With Quote
Old 05-20-08, 10:37 PM   #6
TLCA# 13526
I doesn't improve anything. People say it drives better after they do it but that could be from a lot of reasons. like new bushings and everything has bin tightened up and most of the time they put power steering at the same time.
Old 05-20-08, 10:43 PM   #7
Hmmmmmmmmm, obviously
Thanks guy's I just got done installing a complete 4" Downey Pro Desert lift kit with extended shocks and Rubicon shackles and new greasable pins. While I was installing it IO was pondering what would improve by shackle reversal. Randy
Old 05-20-08, 10:51 PM   #8
TLCA# 13526
That's it Bill I'm going to do a 3 link
Old 05-21-08, 02:48 AM   #9
vk7ybi's Avatar
vk7ybi is on a distinguished road
Theres a nice writeup by Jim C here somewhere about the suspension geometry of the 40 series.. It makes good sense to leave it alone, I always figured the Toyota engineers know more than the average backyarder, and have probably spend more on R&D developing it.. Theres always those that argue SR must be better because Hiluxs and 4Runners are SOA and SR from the factory, but Toyota has had to put measures in place to counteract the effects of doing so..
'78 FJ40 Soft Top, 35x10.5 Silverstone MT-117 Xtremes, 8274, Lokka Rear - RD02 Front, 2.5in lift, H41, 4.11, LPG.
'78 FJ40 Hard Top, 31x10.5 MTRs, 8274, Lokka Rear - RD02 Front, H41, 4.11, RDB.
'81 FJ40 Hard Top, 33x12.5 BFG MT's, 2.5in lift, H41, 4.11, 253 Holden V8, Power steer.
vk7ybi is offline   Reply With Quote
Old 05-21-08, 02:52 AM   #10
vk7ybi's Avatar
Here it is.. Explanation re: Factory Shackle Location - Land Cruiser Tech from IH8MUD.com
Old 05-21-08, 08:54 AM   #11
theo
You can improve your approach angle if you use low profile hangers in front. If you climb boulders (or logs or whatever) you get your tires on the rocks before the shackles grind into them and maybe hang you up. (You can drop off steeper stuff too.)
With the shackles on the rear the springs and tires can compress back and up and make the transition onto a rock or other obstacle a little smoother.
But, compressing the axle towards the transfer case could mean shoving your driveshaft right through your transfer case and out the back side unless you take precautions. The changes in length on the driveshaft are smaller with normal geometry.
Shackle reversals on FJs were started by guys that wheel their junk and needed better off road performance. If you don't wheel hard there's no good reason to do it that I can think of.
The garage is no place to park an automobile. (TLCA-14131)
theo is offline   Reply With Quote
Old 05-21-08, 10:19 AM   #12
D-Cannon is on a distinguished road
Small bumps on the road
I had thought that in addition to hard wheeling, the SR improved small bump (at speed) handling. While it is true that the factory set up will move the axle back on big hits, the axle actually moves forward slightly as it begins to travel up. So, on the highway going 55 mph, when you hit a seam or repair on the road, the wheels head forward, into the bump. The factory set up is a little more "bumpy" feeling, compared to a vehicle that is set up with reverse shackles like the later models.
I could be incorrect.
D-Cannon is offline   Reply With Quote
Old 05-21-08, 10:26 AM   #13
motoloco is on a distinguished road
I dissagree, I have owned a LOT FJ40's, the BEST driving ones have always been SR. If used with a low pro hanger in front your approach is way better, your truck wont want to follow the road near as much (especially with longer than stock shackles), and hard edge bumps are much smoother since your front axle does not have to travel foward (into the bump) to go upward. That said, there is nothing wrong with a forward shackle set up with nice bushings and a reasonable length shackle, they can drive very nice. I believe toyota did it that way simply because the frames are higher at the ends and it was more cost effective than recessing a hole in the frame for a shackle, which is what they would have to do the keep the correct caster at stock height.
motoloco is offline   Reply With Quote
Old 05-21-08, 11:19 AM   #14
Sputnik40's Avatar
TLCA# 6187
Sputnik40 is on a distinguished road
I disagree to a certain extent for anything that's going to see some decent trail use. A low profile SR is awesome - those boat anchor versions from AH are pure rock magnets...
The only disadvantage to me on my low profile SR is the front end diving a bit under heavy braking (not that I'd notice if I'd not tried really hard to see if it actually happened as many say it does).
I broke my front frame horn once trying to push a shackle into and up over a rock - didn't stop me - but it ripped the frame pretty good (boxed now). These days - with low profile hangers - most time the extra few inches of clearance gets by an obstacle, or it easily ramps up and over. Course I'm SOA and have my tie rod behind the axle to boot .
If mostly a DD - then there's really no need at all.
"The devil made me do it the first time. The second time I done it on my own."
Sputnik40 is offline   Reply With Quote
Old 05-21-08, 12:57 PM   #15
Great Replies ....
Thanks guys you all did a great job of answering my question,
Randy
Old 05-21-08, 04:29 PM   #16
vk7ybi's Avatar
Hmm? The reason Toyota designed it like they did is outlined in Jim C's article..
Old 05-21-08, 08:57 PM   #17
TLCA# 13526
If you want to get into that far!
If you clime up a rock with s/r your axle will walk out from underneath you rig, pulling the drive shaft out and pulling your pinion towards the ground. As far handling on the road the rig will lean more going around corners do to the fixed point on the frame do to the fact that both axles are being pushed back.
Old 05-21-08, 10:39 PM   #18
NeverSummer is on a distinguished road
I've read all of your posts and read Jim's explaniation on the location of the shakles. My question is does the same that applies to toyota springs apply if you are going to put chevy springs on your rig?
Does the water go all the way around the Island?
NeverSummer is offline   Reply With Quote
Old 05-22-08, 12:27 AM   #19
vk7ybi's Avatar
The theory remains same for any brand of spring in the same configuration..
Old 05-22-08, 07:18 AM   #20
Sputnik40's Avatar
TLCA# 6187
Disagree again - if not just for the sake of debate - I'm running flat (ok almost inverted now) and flipped stock springs. My axle's not doing a whole lot of walking - and it's pulling up that rock more than it is fighting it .
Old 05-22-08, 12:05 PM   #21
GreatBasinCustomHomes.com
haystax's Avatar
TLCA# 14279
haystax
SR by itself won't gain you much, maybe a little better ride quality but you're not going to build a "rock crawler" by simply moving the shackle attachment points.
If done as part of a spring over or power steering or frame strengthening mod then you start to see small tweaks add up into a much more comfortable and better handling package. I know there is a night and day difference for the good after I did all of the above mods at the same time compared to a stock rig. But on it's own you don't get much done and you still need longer brake lines, longer travel driveline etc..
'76 FJ40 - 2F,SO,SR,RDB,PS,4.88,Q78TSL,earlydizzy,mod'd carb,Aussie'd front,weld'd rear,MetalTech'd...still too fast in 4LO
Great Basin Custom Homes
haystax is offline   Reply With Quote
Old 05-22-08, 12:08 PM   #22
Thanks again HAYSTAX, and all others, I knew it must do something, but wasn't obvious Randy
Old 05-22-08, 01:42 PM   #23
woooody's Avatar
TLCA# 7704
woooody is an unknown quantity at this point
It seems like every few years this comes up, and everyone points to Jim's article as the end all be all.
"Toyota designed it that way, so it must be right"
If that is the case, please explain 1979 - 1985 Toyota Hi lux suspension.
Why would the Toyota Engineers ABANDON front shackles of the Land Cruiser when they designed the Hi-Lux?
I've had SR and PS for 9 years now. It still works, still doesn't wander, still has a better approach angle than a front shackle configuration. I'm using 2 1/2" OME springs. I have never bottomed the drive shaft into the xfer case. I've driven my 40 at 80+ MPH with no problems. I've rockcrawled all over the sierras.
If you don't want to do a Shackle Reversal, fine. But please don't try to convince me that SR is worse than shackle forward.
Ross Woody
TLCA #7704
72 FJ40 with some mods... (now sporting ORION #342)
07 TRD FJC
woooody is offline   Reply With Quote
Old 05-22-08, 01:51 PM   #24
no convincing. I to am very pleased with my sr. I do however understand and agree that the better performing link type suspension uses a fixed rear point, so as to correlate that into a leaf spring it would follow that the leaf be fixed at rear end of leaf. Why switch it around for rear axle ???? thats what gets me is everybody debates the sr or no sr issue with blinders about the fact that the rear axle is set up shackle back. Bottom line is that the difference is minimal and you should build what suites you and your ideas.
John on the hawgs
Old 05-22-08, 02:30 PM   #25
haystax's Avatar
TLCA# 14279
haystax
Exactly - it was part of the re-design of your vehicle and contributed to the ability when combined with other probably more important and gainful mods. In the end you have a better setup than stock - but to leave it out of a front end build up process doesn't make sense either because there are some true benefits IMO
Old 05-22-08, 04:52 PM   #26
vk7ybi's Avatar
Ok, so why didnt they ABANDON the design in the 60 and 70 series LandCruiser? Why does Nissan and other competitive manufacturers use the same design?
Old 05-22-08, 04:57 PM   #27
woooody's Avatar
TLCA# 7704
Re - 60 - 70 -- Couldn't tell you. Could it be that they just modified existing FJ40, FJ50 plans when developing Fj70 / Fj60? For the Hi-Lux it was a new design.
For other manufacturers? I wouldn't even attempt it.
My point, which I obviously wasn't clear on, is that you can't use the argument that SR is bad because Toyota didn't design it that way. Toyota Engineers used SR is their design of the Hi-Lux. So it must not be terrible. After 85 they abandoned that in favor of IFS for the Minis, and Coils for the 80's.
Can you please detail what those "measures" were "to counteract the effects of doing so"?
Ross Woody
TLCA #7704
07 TRD FJC
Old 05-22-08, 06:21 PM   #28
vk7ybi's Avatar
