Old 05-11-08, 10:44 PM   #1
TLCA# 6453
mustardfj40
Saginaw steering or pump dead...
OK guys, I'm officially panic since I'm trying to get the truck ready for big wheeling trip coming up.
I have a J20 saginaw box and a saginaw pump...Everything works fine in 2WD. When I get the truck in 4x4, most of the time it would not turn left, turning right is OK, and steering box start to leak at the top cap (the cap with 4 bolts), and my pump is also spewing oil through the cap.
This is a bummer because the saginaw has only couple hundred miles, and the pump has about a thousand miles on it, and this is my 4th pump already. This used to work fine for a month. I hate to say this but these are the only GM stuffs I have on my truck and it gave me so much trouble
Anyone has idea what could be wrong? Thanks in advance.
/td
'75 FJ40 mostly stock....yeah right!
www.employees.org/~dirttrak
mustardfj40 is offline   Reply With Quote
Old 05-12-08, 01:44 AM   #2
inkpot's Avatar
TLCA# 10338
inkpot
Howdy! Can't help much on the pump and box, but the "no left turn in 4x4" sound almost like a bad Birf. Good Luck. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is offline   Reply With Quote
Old 05-12-08, 12:10 PM   #3
TLCA# 6453
mustardfj40
That's what I thought too, I put the truck on jackstand and enaged 4x4 and was able to turn the wheels to the left...I have installed these birfields about a year ago but haven't taken the truck offroad yet so I doubt that birfield is broken but I guess something could be binding up in there, I have the ring'ed longfieds.
I've just ordered another new Jeep J20 box and was told that I bought their last and only steering box more than a year ago But they special ordered another from a different distributor. Keep my fingers crossed that is the right box since these are very hard to find nowaday. I will pull the birfields and install the 30-spline chromoly longfieds today, and make sure that nothing is binding up the birfied.
Anybody has any other ideas please share with me.
Thanks.
/td
Old 05-12-08, 07:49 PM   #4
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Josie'sLandCruiser is on a distinguished road
Hi All:
Tien, I can source you a J20 PS gearbox from a local re-builder (a buddy has one in his rig) if you need it. Just let me know what I can do to help!
Regards,
Alan
www.seattlecruiserheads.com
Josie'sLandCruiser is offline   Reply With Quote
Old 05-12-08, 10:12 PM   #5
TLCA# 6453
mustardfj40
Alan, thanks very much! The box should be here tomorrow, if they cannot get it I will bug you then.
I've just pulled the passenger side ring'ed longfield and replaced it with the 30-spline chromoly set, the old f'ing bir looks good so is the poly performance chromoly inner. Will do the driver side tomorrow.
Old 05-12-08, 10:14 PM   #6
too tall
Do you have a locker in the front?
1977 fj40
1985 bj60
1978 fj40
1976 fj45 in pieces
1974 fj40
Too many if you ask my wife , Never enough for me !
too tall is offline   Reply With Quote
Old 05-12-08, 10:19 PM   #7
TLCA# 6453
mustardfj40
Yes, I have ARB lockers. I did turn it off.
Old 05-12-08, 10:34 PM   #8
cardinal fang's Avatar
TLCA# 6607
cardinal fang
First, bleed the system. Sounds like air in the pump and lines.
Pull, the hoses on the pump and manually turn the box to make sure it is not a problem with the box.
Also, if you say it happens when in four wheel drive, is the ARB on in 4WD? If the infamous "pin" in the ARB came out it would cause it to lock up.
Bill Jackson
AKA "Cardinal Fang"
1973 FJ40 - 1975 FJ55 - TLCA#6607
Folsom, CA
My webpage is here
"The iron hand
is no match
for the Iron Rod" ??
cardinal fang is offline   Reply With Quote
Loans | Loans | Remortgages | Hindi movies, hindi songs | Mortgages
