Old 05-12-08, 05:39 AM   #61
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Few More
D'Animal is offline   Reply With Quote
Old 05-12-08, 06:37 AM   #62
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
What necessitated the linkage to cable & carb bellcrank conversion?
The truck and engine and carb are all 75-78, so the stock throttle linkage should fit?
Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's since 1988.
FJ40Jim is offline   Reply With Quote
Old 05-12-08, 11:04 AM   #63
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Body lift to accomidate the Twin Stick for the Orion and the shifter for the Rock Box.
Old 05-12-08, 10:12 PM   #64
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
That would tend to move the linkage bits all askew.
Thanks,
Jim C.
TLC Performance
Old 05-13-08, 06:07 AM   #65
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Once this passes SMOG I will be starting on my "Black Label" 1977 FJ40. Wish me luck.
Now where did I put FJ40Jim's secret cell #.
LOL!
Old 05-18-08, 08:44 AM   #66
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
I have driven it a bit now and put some fresh fuel in the rig.
It starts and runs fine. There is a slight dead spot in the transition of the secondaries opening.
Idle is around 600rpm.
As it warms up the idle comes up. When it gets to operating temperature it idles around 1,200 RPM and slowly climbs higher.
If you let it cool down, like overnight, it will start and idle at 600rpm again.
Where does the BB go?
Old 05-18-08, 09:22 AM   #67
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
Adjust the idle speed to your preference. typically in th 500-700rpm range.
In the Daisy Red Ryder BB gun.
At the pointer, or a little below it.
Thanks,
Jim C.
TLC Performance
Old 06-29-08, 08:06 AM   #68
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Engine Hot or cold?
Cold it idles great. After driving about 10 miles it will not come back down to proper idle.
I'm thinking it has something to do with the VSV? Or am I looking too far, too deep to quick?
Old 06-30-08, 09:41 AM   #69
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
Idles speed & mix settings are made at operating temp.
Thanks,
Jim C.
TLC Performance
Old 06-30-08, 07:16 PM   #70
The Anti-Tech
surfpig's Avatar
TLCA# 14386
Nice thread...
I have some questions, and possible hijack...
I have a '77 CA spec FJ55, needs to be kept smog legal, and a '76 federal carb I'd like to put in. Is that easily do-able? I'll double check the actual MFG dates on the carbs...
nial, Hippie teleboarder
The more I see, the less I know...
'77 FJ55, stocker, with a locker (and some other stuff). Now with 95% Mojo!
Footsoldier for the Kingdom of TUT
surfpig is offline   Reply With Quote
Old 06-30-08, 07:35 PM   #71
The Anti-Tech
surfpig's Avatar
TLCA# 14386
Originally Posted by surfpig View Post
Nice thread...
Well, I just checked the date codes and the one that is supposed to be the "CA stock '77" is "6 - I - 23" (9/23/1977?) and the "76" is "7 - E - 4" (5/4/1977?). This might explain why the "older" one gives me a better "seat of the pants" improvement in performance...
Which one should I run, and how can I route the vacuum lines for best performance (and emissions compliance when I need to)?
The truck is a July 1977...
Old 07-02-08, 09:30 PM   #72
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
6 I 23= 1976 Sept 23. A 1977 model year carb.
7 E 4= a 1977 carb also.
Might be possible to swap them, if they are both drilled for CA emissions vac connections.
Thanks,
Jim C.
TLC Performance
Old 07-03-08, 08:41 AM   #73
The Anti-Tech
surfpig's Avatar
TLCA# 14386
[sorry for the hijack...]
But is one "better" than another? And which one might be best for performance modifications?
One has the power valve port and the TP port (#14), one doesn't. I forget which jets and such they have...
Mortgage Calculator | Loans | Problem Mortgage | Online Advertising | Nelly Furtado
