Old 04-24-08, 11:39 AM   #1
pc4400's Avatar
suspension install order
Hey everyone,
I'm putting on my Downey 4" lift and wanted to know what order do you guys usually install the springs in?
Rear Axle
1) Bolt leaf spring to front spring perch
2) Bolt leaf spring to shackle (already bolted to rear perch)
3) Bolt axle to leaf spring
Or mayble bolt the axle to the leaf spring first?
Also regarding torque;
1. Torque U Bolts to 80 in the aire, then re torque to 100 on the ground, right?
2. Torque shackles to what? I would assume just enough to flatten the lock washers, right?
Sorry for the n00bie questions, but it's better to ask now then after.
72 fj40
Old name - Little Red Wagon
Current Name - Rusty
pc4400 is offline   Reply With Quote
Old 04-24-08, 11:42 AM   #2
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Get the leaf spring installed into the solid spring hanger on the frame first, then attach the spring to the frame with the shacke, then set the axle back down on the springs and secure with the ubolts.
Old 04-24-08, 11:45 AM   #3
pc4400's Avatar
Good, that's what I thought. I just had lots of time to think since Im waiting on my greasable spring perch bolts (one of mine broke when removing).
What about my torque numbers, do they look right?
72 fj40
Old 04-24-08, 03:31 PM   #4
In the garage
John Smith's Avatar
TLCA# 9074
60 ft lb. is what Haynes says for u-bolts. I can't find a spec in my FSM.
For the shackles just snug them up and keep an eye on them. If you use nylock nuts they won't back off. If you over tighten your ride will suffer greatly.
79 FJ40 & 78 FJ55
http://users.starpower.net/johnsmith <- Detailed ToyBox install instructions
Please help save the Upper Tellico OHV area, Donate to the Rescue Tellico Fund http://www.sfwda.org/trails/tellico/donate.html
John Smith is offline   Reply With Quote
Bad Credit Mortgages | Debt Settlement | Hypnosis | Bad Credit Mortgages | Payday Loan
