Old 04-22-08, 01:23 AM   #1
40 dead SOS
I do not know nearly enough about trucks to own a 79 40 but I have driven it since I was 16 and I have gone through everything I can think of so any help would be greatly appreciated. I left the lights on like an idiot and drained the battery. I jumped it and drove it twice after that and it ran fine but one day it would not crank at all. I tried a fresh battery and it still did nothing. The key turns and makes no noise at all. I thought it may be the starter. But with a fresh battery neither the lights nor the radio turn on. I checked the grounding and a few wires and everything looks fine. Where should I go from here? Thanks for any advice.
mitch79fj40 is offline   Reply With Quote
Old 04-22-08, 03:35 AM   #2
mooker82's Avatar
I would test your battery. If it is dead charge it and then test your alternator. I bet your alternator is on its way out and killed the new battery.
74 ford bronco , 97 40th anniversary, OME lift, ARB bumper, Dolby 5.1 surround sound Rusty 72 FJ40
mooker82 is offline   Reply With Quote
Old 04-22-08, 04:08 AM   #3
american psycho's Avatar
I'd venture a guess that your battery cable clamps need cleaning - wire brush or sandpaper.
I echo advice I got from the 40 Masters:
Get a volt meter and learn how to use it.
Get the wiring diagram for you 40 and understand it.
Prepare for more electrical gremlins (oxidized fuse block contacts was my last challenge that I fixed with som 220 grit sandpaper).
just did it!
american psycho
american psycho is offline   Reply With Quote
Old 04-22-08, 04:11 AM   #4
BigRedFJ40's Avatar
check the fuseable link at the battery. If that is unhooked or melted, you will be dead in the water.
BigRedFJ40 is offline   Reply With Quote
Old 04-22-08, 05:09 AM   #5
I'd bet on this, if you jumped your old battery and ran it to charge the dead battery you most likey toasted your alternator. I believe advance auto can test alt's.
bob
94 green 80
63 patrol L60
63 sunbeam alpine
I cut this wire 3 times and it's still to short.
norville is offline   Reply With Quote
Old 04-22-08, 06:30 AM   #6
total rice
dgangle's Avatar
TLCA# 10793
Harbor Freight Tools - Quality Tools at the Lowest Prices
get one of these....cheap and easy to use. Every tool box should have one.
1975 FJ40 - V8, 4WDB, Saginaw PS, SR, 4" lift w/ 33X12.50X15 BFG MTR's, M8000
2007 4 Runner SR5 4WD - stone stock daily driver
2007 Avalon - free company Grandpa car
TLCA#10793
My ROTW: http://tinyurl.com/2mfwfw
Originally Posted by C W McCall View Post
So we crashed the gate doin' 98, I says let them truckers roll, Ten-Four.
dgangle is offline   Reply With Quote
Old 04-22-08, 06:45 AM   #7
GSMTR Chair
Trollhole's Avatar
TLCA# 15077
X22222
Old 04-22-08, 05:29 PM   #8
thanks alot yall I will work on all of these suggestions before I have to break down and go to a mechanic.
Old 04-22-08, 07:53 PM   #9
IH8MUD Junior Chipmunk
40's rock's Avatar
TLCA# 14773
The real problem lies in that you have not shown proper respect for mud. Buy a star, worship the elders and your 40 will magically return to life. Mine has
76 - 40 - 32x11.50, ARB, weber, header, HEI, old school 2f by the Wise One
79 - 40 nothin but frame and some awesome axles...the body is getting a little augmentation....hmm now what about the engine...
40's rock is offline   Reply With Quote
Old 04-22-08, 09:36 PM   #10
what he said
Mace's Avatar
Star is not necessary, but it is a nice gesture..
I would bet battery cables (the fusible link is included in this)
I am kinda gay.......
My Myspace
Old 04-22-08, 11:52 PM   #11
cruzerman350's Avatar
a battery needs at least 10 volts to make noise. if nothing is working then you most likely have corrosion somewhere in the battery connections. you could get a set of jumpers or a charger hooked up jsut to test the lights and see if it is in fact a dead battery. if you starter did freeze up trying to crank would unload the entire potential of the battery in turn roasting the wire connecting battery to starter. i have had many problems with corrosion on battery terminals and thats where would start and then jsut trace both the pos. and neg. leads til you find the problem. with more information i could give you a move refined area to search but no power to anything is very vague.
-miles
"cruzerman that thing looks like it takes no prisoners...straight up black, the grim reaper of Toyotas"
-CruisinMT
72 FJ-40 with a 350 and fj60 trans and t-case. custom cage, belly pan, bilstien 7100s, and some badass paint
cruzerman350 is offline   Reply With Quote
Old 04-23-08, 02:46 AM   #12
lostmarbles's Avatar
Originally Posted by dgangle View Post
Harbor Freight Tools - Quality Tools at the Lowest Prices get one of these....cheap and easy to use. Every tool box should have one.
I smell a rat!!!!
In this country we have laws that combat misleading advertising and I suspect the seller of that meter would be made to withdraw it from sale (if it were for sale here).
How can that little meter truly check up to 1000 CCA?
Judging from the size of its leads it can't even measure 100A (which the seller also claims it does).
In order to do what is claimed, I would expect the meter to be a lot more substantial with leads as thick as battery cables!
Name's really Tom & I have a 1979 BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981
The only people that aren't insane are the ones I don't yet really know.
lostmarbles is offline   Reply With Quote
Old 04-23-08, 06:33 AM   #13
total rice
dgangle's Avatar
TLCA# 10793
Don't buy it then. I can substantiate it does at least 875CCA 'cause that's the rating on the battery in my 40. Spend more if it makes you feel better.
Heavy Duty AVR, Battery Load Tester, Electrical System Diagnosis
I bet this is a good one.
TLCA#10793
Old 04-23-08, 06:43 AM   #14
Coolerman's Avatar
TLCA# 13645
Cool
What the ad means is it will test a battery that is RATED at 1000CCA, not that it will MEASURE 1000 amps.
I have used this meter (though I do not own it) and can verify that it will indeed handle a 100 amps for a SHORT time just like the instructions say. The leads are short for a reason, they keep the resistance down allowing the large currents for short times... YMMV!
!Oy my 1971 FJ40
Not Road Legal
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 04-23-08, 02:34 PM   #15
Yeah. That's what I thought Coolerman. It uses "electronic trickery" to briefly measure a BRIEF high current output (from the battery). That is NOT a test that is of any use for a starting battery (where the high current must be able to be maintained until the engine starts).
In this country, that advertisement would not be allowed because it is deliberately MISLEADING. Either the product woiuld have to be withdrawn from sale or the advertising blurb made more HONEST.
Old 04-23-08, 02:36 PM   #16
Don't buy it then. I can substantiate it does at least 875CCA 'cause that's the rating on the battery in my 40. Spend more if it makes you feel better. Heavy Duty AVR, Battery Load Tester, Electrical System Diagnosis ..I bet this is a good one.
Yep. I think I could possibly trust that one dgangle
Here's a photo of my tester that cost me something like 10 or 20 dollars at my favourite antique/junk shop:
Old 04-23-08, 02:57 PM   #17
GSMTR Chair
Trollhole's Avatar
TLCA# 15077
In this country walking into a Harbor Freight store not expecting to get mislead would be a crime.
Old 04-23-08, 07:24 PM   #18
ohrly?'s Avatar
Check the starter connections, didn't think that I saw anyone say that.
ohrly? is offline   Reply With Quote
Old 04-24-08, 06:41 AM   #19
Coolerman's Avatar
TLCA# 13645
Cool
Warning! Off-Topic rant!....
You don't know how much I envy that law! In this country there is no such thing as truth in advertising. For a TV ad you can say pretty much anything! All you have to do is flash a disclaimer in 2 point type on the screen for 1.7 seconds. Even the disclaimer is all legalese...
The one ad that makes me want to scream is the Kinoki one for the pads that stick on the bottom of your feet and supposedly suck toxins out of your body...
Rant off...
On topic comment: That is a neat looking battery tester!
!Oy my 1971 FJ40
Not Road Legal
Remortgage | Personal Finance | McDonalds | Credit Cards | Credit Card
