wandering?
hey guys gonna attack my front diff new gaskets, shims, and seals. my question is if i increase the knuckle bearing preload beyond say 15lbs can it help with the bad wandering habit
i did the soa years ago and knew nothing then of bearing preload so the preload is probably way off anyhow. all other components seem ok tie rod ends,spring eye bushings etc..thanx for any suggestions or replys
__________________ 75 fj40 soa, saginaw power,disk fronts,350 small block,warn 8274,35" mt's, all blown over with some rustoleum ![]()
I wouldn't mess with the preload.
The center arm seems to be the biggest source of wandering. Other than that improper alignment. |
UC VP & Cook
What is your Castor set at?
__________________ Marshall UC VP & Token Club Cook Greenville, SC Big Gay 2f Build The Great Cruiser Part Links Thread Buying a Land Cruiser Guide "On second thought, let's go to Chat. It is a great place." 73 Fj55 Big Ugly 76 FJ40 ROTW 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
#4 | |
IH8MUD wanabe
X2... Did you cut and turn when you went SOA?
__________________ 72' FJ55 - SOA, SR, DB, FJ62 PS, Webber, Header, H.E.I., 37 X 12.5 X 15 MT/R's, Savanah-heat air freshener. 83' FJ60 - Mint Condition which is now FOR SALE 07' FJC - Atrac Hack - DD 03' Matrix Xrs - It's her's 08' Tundra, 4.7 2WD - Company Truck Quote:
thanx for the replys guys , as for the castor angle i did not do the cut and turn myself. i bought a whole diff housing already cut and turned from a place called fab-tech off road i think out of kelowna, b.c back in the mid 90"s . the dude i bought from delivered the housing in person, seemed like a shadey character so not sure of the quality or angle...thanx
myopic luddite
No. I would not increase knuckle bearing preload to try to correct a wandering problem. I might tighten up my wheel bearings if I thought they were too loose. I might narrow up my toe-in. Do you even have a center arm with the Saginaw PS?
Other than those easy fixes, I might consider going to a professional front end guy and having castor and camber measured, toe-in too as long as there and just to double-check. __________________ "Well it's a '68, '69, '70, '71, '72, '73, '74, '75, 76, '77 FJ55" http://forum.ih8mud.com/424768-post9.html |
if i'm thinkin of the right thing(part) that item got turfed when i did the power steer conversion.could the saginaw box be wore out? i know u can adjust it, but inspecting it while someone saws on the wheel shows no slop?..
#8 | |
IH8MUD wanabe
I would buy a cheap magnetic angle finder from harbor freight and check my caster angle first. just set the angle finder on top of your steering arm and tell us what you find...
You need to measure castor relative to the road surface.
__________________ The garage is no place to park an automobile. (TLCA-14131) |
#10 | |
IH8MUD wanabe
What were you assuming he was going to do? Jack up the rear end and then measure it? haha
#11 | |
Castor is only a matter of a few degrees. The mildest slope on a driveway is enough to throw the measurement off. I laid an 8 foot straightedge down under mine when I did it and set the angle finder on that to find the reference point. Wonder of wonders, that part of my driveway was level!
#12 | ||
IH8MUD wanabe
Okay, I see your point. I guess i take my shop floor for granted... good call theo It still makes me laugh a little though __________________ 72' FJ55 - SOA, SR, DB, FJ62 PS, Webber, Header, H.E.I., 37 X 12.5 X 15 MT/R's, Savanah-heat air freshener. 83' FJ60 - Mint Condition which is now FOR SALE 07' FJC - Atrac Hack - DD 03' Matrix Xrs - It's her's 08' Tundra, 4.7 2WD - Company Truck Quote:
#13 |
Let's Go!
If this is a problem that started recently, then it's probably not castor.
__________________ Toyota still builds real Cruisers. They sell them overseas. |
#14 | |
__________________ 76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers, and way too much junk in the trunk!!!! ![]() 85 Toyota mini truck for chase/support!CSC #41 |
MPAA | Xecuter 3 Mod Chip | Remortgages | Loans | Secured Loans |
