Old 04-18-08, 07:24 PM   #1
Quiet there's a J**P
JONNYFJ's Avatar
TLCA# 18337
How to properly adjust a brake system proportioning valve
Does anybody know how to do this properly I have had backyard mechanics tell me, but have never noticed a difference. Also where should the valve be mounted. I was told towards the rear near the rear brakes, is this true?
69 FJ40 383 Stroker SM420 3Speed Toyota T-Case SOA ARBs 35 MTRs and more
84 Mini Truck 22RE Stock Tranny Duel T-Cases Flat Bed 35s
JONNYFJ is offline   Reply With Quote
Old 04-18-08, 10:42 PM   #2
JONNYFJ's Avatar
TLCA# 18337
Seriously no one knows?????
Old 04-18-08, 10:50 PM   #3
The location shouldn't matter. Stock landcruiser is on a bracket under the master cylinder. Toyota pickups are often mounted on the frame above the rear axle.
I adjusted mine by braking on varying surfaces until the rear brakes were not locking up all the time.
I kept adjusting it until felt right. I then confirmed it by having a local brake shop run it across there skid pad.
bikersmurf is offline   Reply With Quote
Old 04-18-08, 10:52 PM   #4
JONNYFJ's Avatar
TLCA# 18337
I see. So what your saying is bring it to Break Check
Old 04-19-08, 12:00 AM   #5
Brake Check final step
I was able to adjust it properly by trial and error (Four wheel disc brakes). The brake test performed on the skid pad showed the balance front to rear and also the balance side to side. If you don't have it close the brake shop may want to charge you for there assistance.
Old 04-19-08, 06:56 AM   #6
I can mangle anything...
DSRTRDR's Avatar
TLCA# 14706
I mounted the valve by the master cylinder
to adjust it, we took the truck on a dirt road and I stepped on the brakes hard while going 15-20 mph, while my husband watched front/rear lock up
then adjusted the valve so that the front would lock before the rear
repeated several times and tested on flat as well as downhill several times again
Claudia
'72FJ40 with a no-number 2F, new MAF headers, 4spd, 33x10.5 BFG MT, 4" lift, roll cage, ARB lockers f/r, MAF disk brakes f/r, hand throttle, Painless wiring, dual advance dizzy, Bilsteins, 4+ front bumper/rear shackles/U-bolt flip, Kevin-improved frame, finally a functioning CB, with ChaseTruck
Copper State Cruisers #40
www.desertrider.net
DSRTRDR is offline   Reply With Quote
Old 04-19-08, 07:17 AM   #7
total rice
dgangle's Avatar
TLCA# 10793
I went to an office park on the weekend when there were no cars. The asphalt had just been resealed...you know the type of place...very black, stinky and very slippery especially when wet. Moving around to different spots I'd do some aggressive stops while adjusting the front to rear brake bias with the adjustable proporting valve. It left nice, black, long marks from each tire. They probably didn't appreciate it come Monday but whatever. 33's make a heck of a howl that freaks some people out.
I go through this drill when I add/remove my hartop as the extra weight changes the bias needed. I like the fronts to lock up just before the rears. Vice versa and you have your hands full on a short wheel-based vehicle.
I have mine under the hood. The circle track guys mount them so the driver can adjust during the race as traction/track conditions change. Now that would be the shitz.
1975 FJ40 - V8, 4WDB, Saginaw PS, SR, 4" lift w/ 33X12.50X15 BFG MTR's, M8000
2007 4 Runner SR5 4WD - stone stock daily driver
2007 Avalon - free company Grandpa car
TLCA#10793
My ROTW: http://tinyurl.com/2mfwfw
Originally Posted by C W McCall View Post
So we crashed the gate doin' 98, I says let them truckers roll, Ten-Four.
dgangle is offline   Reply With Quote
Old 04-19-08, 08:29 AM   #8
Front brakes lock up?
If your front brakes are locking up you're loosing the ability to steer. With disc brakes on the front they should be almost impossible to lock up. If you're jumping on the brakes that hard the rears should also be locking up. I prefer to have all of the brakes lock up at the same time on loose surfaces. On dry pavement that'll mean the fronts will never lock up and the rears will lock when the back comes off the ground. You'd be surprised how fast my 4700 lb FJ40 will stop.
Be aware that if the rear is locking up too fast it will want to pass the front in sudden stops (spin out).... which I wouldn't want. But having the fronts lock first will prevent you from avoiding the kid that just ran out on front of you.
If you take it from one extreme to the other and then back and forth you should be able to tweak it so your rig will stop on a dime. Faster than the camaro now parked under your rear bumper.
Old 04-19-08, 01:52 PM   #9
JONNYFJ's Avatar
TLCA# 18337
My 40 barely stops on a city block let alone a dime haha. I am going to take it to a brake mechanic. Last TLCA meeting I was driving home and the light turned red but I was just along for the ride because the 40 was not stopping
Old 04-23-08, 12:50 AM   #10
Brake Adjustment?
It sounds likes your breaks are out of adjustment... or you've got bigger problems than just Porp valve adjustment. I'd get it checked out before something bad happens.
Old 04-23-08, 04:48 PM   #11
TLCA# Associate Member/Sponsor
Any brake shop can adjust your front-to-read proportioning with gauges, should be in the 60% front to 40% rear ball park.
Downey is offline   Reply With Quote
Old 04-23-08, 07:51 PM   #12
total rice
dgangle's Avatar
TLCA# 10793
Stainless Steel Brakes sells kits for this purpose. I paid $50 a few years back and it is a very valuable tool for the $$.
Jim, I know this has been discussed B4 but what kind of pressures should one expect for front disc/rear drum and front & rear discs??? It may good to note it here in this thread.
TLCA#10793
Old 04-23-08, 08:40 PM   #13
I don't think my cruiser has a proportioning valve. Sometimes my rear left tire locks up if I brake to hard. Where can i install one so i can place more pressure on the front bakes then on the back?
Batalia is offline   Reply With Quote
Old 04-24-08, 06:25 AM   #14
total rice
dgangle's Avatar
TLCA# 10793
-----thread hijack-------
If you have one rear that is locking up a proportioning valve prolly isn't going to help. You got other issues to look into that could be anything from a simple adjustment to a seized wheel cylinder, worn shoes, broke/missing return spring, contamination of the shoes, etc. Take them apart and see what's going on.
A proportioning valve (non-adjustable like the OE or adjustable like those offered from Willwood, Summit, etc) is nothing more than a regulator. It goes in the rear circuit and is used to take a pressure drop on that line's pressure, thus reducing the braking force.
If you want some help determining if you have/need one we are going to need more info and pictures never hurt.
TLCA#10793
Mortgage Calculator | Personal Injury Lawyer Los Angeles | Submit Articles | Loans | McDonalds
