Old 03-09-08, 12:50 AM   #1
lostmarbles's Avatar
Hood repaint
Thought I'd post this thread on how I've painted my hood in case it is of interest to anyone.
Her'es a photo of the hood as it was before the work began. The faded grey paint is "cold galvanising paint" that I had been slopping everywhere where rust had been beginning to take hold:
And here is the underside. Under the ribbing is "congealed fishoilene". It has performed well in preventing rust for almost 30 years but its black colour makes it look ugly
The hooks were looking a bit "rugged" too. (I'd been pumping them full of grease to prevent internal corrosion and keep them operating smoothly.)
lostmarbles is offline   Reply With Quote
Old 03-09-08, 01:02 AM   #2
The hinges had gotten the "cold galv treatment" too:
As usual all the work was carried out outdoors because my garage is too full of junk
Now anyone who leaves their cruiser outside year round will know that the underneath of the hood gets covered in dew at times. The hidden areas beneath the ribbing are thus particularly prone to rusting. So I decided to cut inspection/access holes in the ribbing and tried to do it in such a way that hood-strength wouldn't be compromised. I used a drill and die grinder to cut these holes:
Old 03-09-08, 01:06 AM   #3
Here's a close-up of my die grinder. This is probably my favourite tool:
And here is the cut-off wheel I used for making the straight cuts:
Here is the sanding drum I used to remove the burrs
Old 03-09-08, 01:12 AM   #4
Here are some of the bits I've cut out. Note the black fishoilene gunge on the sides that were formerly hidden:
Each of those packets contained 5 cut-off wheels and the cost of cutting those holes was around $60 in cutting wheels alone!
Here are the scratchers I used to take the paint off:
This paint-removal work is done in a similar way to Dans (M5driver) except in my case "yours truly" does all the monotonous manual labour
Here's a hole that I couldn't gobble up with a cut-out:
Old 03-09-08, 01:17 AM   #5
So I filled it with weld:
And I had to fill these holes too. The PO had drilled 6 of them in the bonnet in order to fit a perspex wind deflector. Apparantly the first months of my BJs life were spent towing a caravan right around Australia and the wind deflector was used to reduce fuel consumption:
As usual when I concentrate on getting a job done as best I can, avoiding injury seems to have low priority
Old 03-09-08, 01:25 AM   #6
This tab spot-welded to the side of the hood sits on a rubber pad. But it used to sit so heavily that it had worn into the rubber to the point where the securing screw in turn wore into the metal. (It is actually worn right through.)
So I filled that with weld too and bent the lip of the hood (complete with tab) upwards so it will rest more gently on the rubber (which has been replaced).
I welded the full length of the front of the hood to replace the sealant there with weld. (Burnt the sealant out.)
I reckon anyone who restores vehicles would never "break" under torture. I mean the weld spatter was burning real deep but NO WAY was I going to move my hand and risk flawing my weld (any more than it was already going to be):
Yes I do have welding gloves. But it was only a small job!!
Old 03-09-08, 01:30 AM   #7
Hey. How come all that last post was in small type? Only small job was supposed to be written small
Anyway. Here's the outside of the hood almost ready for painting:
And here's the underside:
And here's "Yours Truly" doing the painting. (Nah. Not really. I'd finished by then and was just pretending.)
Old 03-09-08, 01:37 AM   #8
Decided to glue the rubber here cos it was so old and weather-hardened that it wouldn't have sat properly otherwise. I also painted it with tyre-black to make it look like new:
And here's all the "hood hardware" ready for fitting. (Note the stainless fasteners.)
If anyone hasn't seen the hinges before - here is the thread covering them being made:
I'll add this link in a few minutes unless Alzheimer's says different
http://forum.ih8mud.com/40-55-series...od-hinges.html
How's that - I remembered
It is important to seal the bolts on the cowl-side of the hinges to prevent rain water dribbling onto your feet. I use neutral-cure silicone for this:
Old 03-09-08, 01:45 AM   #9
Here is the underside of those cowl screws (looking inside the glovebox):
Note that stainless locknuts have been added to prevent easy-removal of those screws and to remove the need for split-washers outside. (I hate split washers.)
That goo squishing out is lanolin. I like to use that as a rust-preventative and antiseize nowadays.
Trouble with outdoor workshops is that rain tends to come at the most inopportune times. (Unless you live in Oz where it usually doesn't come at all.) But at least it enabled me to check the weathertightness of those screws:
Old 03-09-08, 01:49 AM   #10
Here's a photo of the new hinges looking pretty:
And here a photo of the new stainless shield hooks (obtained from CCOT same as the hood hooks):
Speaking of hood hooks:
Old 03-09-08, 01:53 AM   #11
Here's an outside view of the repainted hood:
And here's the underneath:
Oh - Forgot. I filed/sanded the burrs on the stainless hooks and I also drilled these holes to allow trapped water to drain:
Old 03-09-08, 01:59 AM   #12
Here's a photo showing how the windshield (aren't I good not calling it a windscreen?) washer line is routed.
I left that plastic tie thingie in place during paint removal and painting because I knew I'd break it if I tried removing it:
Here it is closer Errr? Maybe not..... Let's say - further away (photos swapped of course):
And here is the hood lock:
Old 03-09-08, 03:30 AM   #13
And here's a closer look:
And here is how the lock has been broken/modified to enable it all to work. (Note the plastic on the hoop to prevent vibration noise.)
And one last photo (Already this thread has so many photos that I need to upgrade my computer to be able to download the page fast enough!!!)
This last one shows why I like POR15 so much. (Hey - Why doesn't the POR15 manufacturer support MUD by advertising on it like RB does? Or is it just that I haven't noticed their advertising?)
This photo was taken inside the glovebox. The primer I applied from within the engine bay has "wicked" right into the seam by capillary action. Then it has expanded as it set to force a little into the glovebox.
Name's really Tom & I have a 1979 BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981
The only people that aren't insane are the ones I don't yet really know.
Old 03-09-08, 04:45 AM   #14
hedgehog23's Avatar
Great post. the paint came out great. what did you use for hardware , and for paint. dont forget to add to this when you do the front fenders too
did i say great job?
hedgehog23 is offline   Reply With Quote
Old 03-09-08, 09:05 AM   #15
That's "Greyt" "Andy"
greytandy's Avatar
TLCA# 16669
Veerrryyyy nice. If I pay the airfare maybe you can paint my hood.
1970 FJ40 (AKA "Big Red")
2007 FJ Cruiser (Black Diamond )
greytandy is offline   Reply With Quote
Old 03-09-08, 11:04 AM   #16
M5driver's Avatar
Attachment 215141
Tom,
No blood would mean the job wasn't done right
Nice work!
1978 FJ40, "The Blue Mule", 217,000 miles
1980 Maule M5-235C, "The Blue Beast", 1404 hrs TTAF&E - FJ40 with wings
1982 Mercedes 300D Turbo, "Ol' Red", 380,000 miles
1953 Spousal unit, "The Wife", lifetime warranty, definite keeper (and firmly attached to all of the above)
KA3JWW, but I don't have my rig right now
M5driver is offline   Reply With Quote
Old 03-09-08, 11:07 AM   #17
SD_rdcruzer's Avatar
Great job. I like all the photos. I'll need to respray mine in the near future and this gives me some ideas. Thanks
"The Other Guy"
SD_rdcruzer is offline   Reply With Quote
Old 03-09-08, 11:23 AM   #18
'Pops'
island45's Avatar
Great job, great post! And at first I wondered why you were on your back, spraying 'uphill', then I remembered you are south of the equator. Duh.
Some old Ford one ton pickups,'66 fj 45 lpb, '79 fj 55, '66 BSA 441 victor special,BMW r75/5 toaster tank, Ancient one lung engines (1912 Stover...6" bore, 12"stroke, 8 hp at max 300 rpms, 2125 lbs) Never without an old 'cruiser for 23 years. Everything runs, and is mostly original, That's how we roll on Mt. Pickett....
'Rusty ol' floorboards, hot on their feet...' Alan Jackson
island45 is offline   Reply With Quote
Old 03-09-08, 11:53 AM   #19
brooklyn's Avatar
Yes, very nice...but,
Now I have to do my hood! I also like your hood lock, where did you get the hardware for that nice trick? I am doing my hard doors as my first step in body work and sanding and painting.
It seems prep is very important - I am now re-doing after being lazy with the prep.
brooklyn is offline   Reply With Quote
Old 03-09-08, 12:18 PM   #20
tmarx's Avatar
Great work Tom !
It is posts like these that give me some hope..
Theo
105 1HZT I/C
BJ 42 LX 11/83 - 3b H55F P/S 3 wipers and slidin windas
tmarx is offline   Reply With Quote
Old 03-09-08, 05:11 PM   #21
Thanks for all the positive comments everyone.
I often question my motives - And I was questioning my reasons for posting this thread.
I think there is probably a bit of "showing off" (as with everyone else who posts threads on work that they're proud of). But I also posted this cos I don't really care anymore if anyone thinks I'm a dickhead. I think this "not caring" attitude comes with age cos I was certainly sensitive to criticism in my younger days. Not caring has given me "new-found freedom" (and I wish had adopted that attitude at a much younger age).
Anyways - Surprise surprise - I don't seem to be getting much negative feedback anyway.
Originally Posted by hedgehog23 View Post
Great post. the paint came out great. what did you use for hardware , and for paint. dont forget to add to this when you do the front fenders too did i say great job?
Thanks Hedgehog. (I've run over a few )
The hooks came from "Cool Cruisers of Texas" (CCOT). I can't remember the cost. It wasn't too bad anyway. But the freight getting them here to NZ was a killer (so I rarely buy anything from the USA now). They're quite good quality. The worst feature is that the internal springs are too strong. So it takes the thumbs of BOTH hands to unhook them.
Oh - Another thing bad (for me) was the "minimum purchase limit" and their refusal to accept creditcard or Paypal.
The hood was primed with gray POR15 (brushed on). Then topcoated with Dulon (a brandname used by PPG Paints) mixed to the formula for "Sky Blue 854".
Originally Posted by brooklyn View Post
Now I have to do my hood! I also like your hood lock, where did you get the hardware for that nice trick? I am doing my hard doors as my first step in body work and sanding and painting. It seems prep is very important - I am now re-doing after being lazy with the prep.
Thanks Brooklyn
I made the components (except the lock and fasteners of course).
I welded up the two halves and then had them hot-dip galvanised. The idea of the galvanising was so that I wouldn't have to worry about scratching paint when I fit or remove the padlock.
I'll add a link here to another thread on "hood locks" where I supplied more details. (Soon and if I can find it.)
Here's that link (post No.16):
http://forum.ih8mud.com/40-55-series...hood-lock.html
Old 03-09-08, 08:46 PM   #22
bsmith123's Avatar
nice paint
What a diff that makes! nice attention to detail, looks good
B Smith123
Chaos, panic, & disorder - my work here is done.
The easy way ain't cheap and the cheap way ain't easy!!!
71 FJ frame off build "UGLY BETTY"
33 in BFGs, 4 inch HFS lift, Durabak lined tub, and a soft top in a box! Now sportin a 2F and 4 speed
bsmith123 is offline   Reply With Quote
Old 07-11-08, 07:14 PM   #23
Righty-ho. Lousy weather so might as well post up stuff on what I've been doing the last couple of months........ That is ..... Continuing on from having finished the hood.
Had mega-loads of photos. so I've dumped at least 30%.
Here we go.....
Off came the fenders. Note the corrosion that was hidden between the "apron panels" and the fenders themselves:
Old 07-11-08, 07:17 PM   #24
Nothing serious. It had been "kept in check" by regular applications of fishoilene over4 the years (which is what most of the "black gunk" is).
The apron panels cleaned up well:
Old 07-11-08, 07:24 PM   #25
I even pained those little clips that hold the little bits of weatherstrip in place:
And I fitted stainless lips on the hood catches. That way the stainless hooks mate with more stainless. (No more contact with dissimilar metals that is open to corrosion.) And thereby, another source of "rust streaks down the aprons" is eliminated.
I obtained the stainless wire/rod from these:
