Electric power steering pump / Variable PS
So I was looking around the web for an electric power steering pump. I wound up coming across this website.
Toyota MR2 Power Steering System So I wound up looking around for some more info about the electric PS pump for a 91 - 95 Toyota MR2. Turns out that this sucker puts out 2000 psi when it is running full speed and takes about 60 amps under full load. That isn't bad at all and could be supported by any 100 amp alternator. Well that's great I thought and began to look around for all the parts. Turns out that getting parts in the US from any junkyard now is damn near impossible and is ridiculously over priced. It's more economical to pull the motor and crush them or in the case of most Toyota's, ship them to Central or South America for parts. Best I could do was $200 plus shipping for just the pump. This would be ok because I also found this sight to run just the pump. DriveEV.com: JeepEV - Jeep Cherokee EV conversion But then I just did a google search and I got lucky. I found everything I needed, PS pump, PS Computer, PS Driver, and the Steering Sensor on ebay in the UK. Even with the weak dollar and the cost of shipping I got everything for $160. ![]() I haven't put this in my truck yet, and don't expect to for a few months, but this should work fine. I will post up some pictures of what I got shortly and I am going to put up a wiring diagram that will turn off the PS Computer and turns the pump on high full time for off-road/rock crawling. What I am expecting is that this will gain me a good amount of extra power as well as boost my MPH a good deal. It will also simplify PS installs as you wouldn't have to worry about belts or mounting the PS pump. There is one peculiarity in the setup that I can tell. There are a few different types of PS Motors/PS Computers combinations that were used.
If anybody wants help locating these parts, PM me. I believe that I can get all the parts including the wire pigtails needed for about $250. Joe __________________ "That which doesn't kill me, is dead when I am through with it." --Joey Nietzsche My Buildup, The Cucumber http://forum.ih8mud.com/40-55-series...-cucumber.html |
Ramblin Wreck
Why?
__________________ Bailey Quintrell '74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage '93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's '97 FZJ80 '98 UZJ100-OEM RR locker ΣΧ
In the garage
My guess is to be different and find out if it works. I look forward to your write up. I would buy and carry a spare pump and any other parts that are unique to that system.
__________________ 79 FJ40 & 78 FJ55 http://users.starpower.net/johnsmith <- Detailed ToyBox install instructions Please help save the Upper Tellico OHV area, Donate to the Rescue Tellico Fund http://www.sfwda.org/trails/tellico/donate.html |
#4 | ||
Oh...Durka Durka Durka.
Really? How do you figure? Presuming you do not have power steering currently, how does not removing any parasitic accessory drag from the belt drive currently equate to better MPG? The marginal amount of parasitic drag of a power steering pump spinning under virtually no load, ie. while cruising down the highway, is not something that you are going to feel in the seat of you pants when removed from the system. Quote:
In all honesty, if fabricating a power steering pump bracket and getting a belt properly aligned is a challenge and something that would be worth worrying about, then perhaps getting someone else with more experience with this type of modification involved in the project might not be that bad of an idea. After all, it is not just your safety in the balance when you are on the streets. Perhaps the poster ran across “nine page technical rant” Will Byars dissertation about the virtues in converting a Land Cruiser to diesel-electric...... ![]() Good luck with the conversion. I hope that it is reliable and safe.
It's an interesting idea. Might be an option for rear steer in a situation where running lines back is difficult and remote mounting of a second pump would be lighter, and/or more reliable.
__________________ jetboy, 75-40 |
give it a go mate
__________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#8 | |
The reliability of these pumps is excellent. They outlast the lifetime of the MR2 by a whole lot. Toyota built these things right, you can replace the brushes on the motor without ever taking it apart. Taking it apart is trivial too, no special tools required. Wiring this pump up with the PS computer, the PS driver, the steering sensor, and the VSS means that it will only turn on the pump when I am going slow and I am turning the wheel. I don't need to rev up the engine to get more pressure from the pump while rock crawling or moving slowly because off-road I will have it switched to high full time. This pump also has 2000 PSI which is about 400-600 more PSI than any expensive HO mechanical pump running at full tilt off of the engine that I have encountered. Keep in mind to get max PSI out of a mechanical pump you need to rev the engine which in turn needs to be in neutral so that it can rev it this high and not go anywhere just to turn the wheel. As for safety going down the highway, it is just as safe as any Saginaw steering gear. Same thing that happens when a mechanical pump stops working applies here. You no longer have power steering and still have full manual control. I am using another Scout II Saginaw gear. I don't need to carry around a spare pump any more than a truck with a mechanical pump. Like it or not, these days electronics and electricity are longer lasting, more reliable, and cheaper than mechanical by a long shot. And yes I can come across as a snarky prick even though it is not my intention. Any more questions or clarifications needed?
#10 |
Any more questions or clarifications needed? Great answers... It's nice to see someone which a sense of humor... I hope that this works well for you! |
#11 | |
Dan Dare!
I have the same problem with this that I do with electric air pumps.
To pump using electricity; Step one convert mechanical energy to electrical energy with the associated loss due to efficiency. Step two convert electricity back to mechanical energy, again with losses due to efficiency in both the motor and the pump To pump with direct drive; Run the pump, one set of losses due to efficiency in the pump. __________________ Dan Johnson Quote:
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.) And a pair of Pink Panties, now with a doohicky in the front. Rust never sleeps. .- -.. --... -. .-- |
#12 | |
Dan- Are you serious? You cannot bring that kind of thought to this party..... |
#13 | ||
Dan Dare!
#14 |
Cheers buddy for trying something new.
I can't add much technical help, but I did think to check the definition of efficiency on wikipedia..... Efficiency - Wikipedia, the free encyclopedia |
#15 |
pump
Sounds like it could be a nice set up this newfangled lectricity thing
Might really be worth it if the install is easy and it is reliable The only thing that worries me is 60 amps sounds like a lot of power draw if it is constant but That is probably peak load, one winch I looked at draws 85 amps at 2k pull for comparison. Now here's another idea---couldn't a hydraulic winch be run off this thing also? Show us how it's done!
__________________ B Smith123 Chaos, panic, & disorder - my work here is done. The easy way ain't cheap and the cheap way ain't easy!!! 71 FJ frame off build "UGLY BETTY" 33 in BFGs, 4 inch HFS lift, Durabak lined tub, and a soft top on the way! Last edited by bsmith123; 02-19-08 at 08:45 PM. |
#16 | |
Why are these pumps coveted for use in racing applications? Why are all the manufacturers rapidly moving to this setup? A quick search on ebay motors shows 3 electric power steering pumps from 3 different car companies, Subarau, Mazda, and Cadillac. Either I am onto something here or I am the dumbest smart person ever.
#17 |
SRP
I think we can all relate to the concept of simple, reliable, proven on this site if nowhere else! so I can understand the dissent
yet if it works out we all get a peek at a new way to do it. Doesn't appear to me from the post that he's asking for an opinion or help, just I'm doing this if you want to check it out, probably will not end up on my rig but I can dig it!
__________________ B Smith123 Chaos, panic, & disorder - my work here is done. The easy way ain't cheap and the cheap way ain't easy!!! 71 FJ frame off build "UGLY BETTY" 33 in BFGs, 4 inch HFS lift, Durabak lined tub, and a soft top on the way! |
#18 | |
From Wikipedia: Brushed DC Electric Motor - Wikipedia, the free encyclopedia As an unloaded DC motor spins, it generates a backwards-flowing electromotive force that resists the current being applied to the motor. The current flow through the motor drops as the rotational speed increases, and a free-spinning motor has very little current flow. It is only when a load is applied to the motor that slows the rotor that the current draw through the motor increases."In an experiment of this kind made on a motor with separately excited magnets, the following figures were obtained: __________________ "That which doesn't kill me, is dead when I am through with it." --Joey Nietzsche My Buildup, The Cucumber http://forum.ih8mud.com/40-55-series...-cucumber.html |
#19 |
All doubt has been removed; you are on something. ![]() ![]() Again man... Good luck with this, and please, start a thread with the build up.
#20 |
IH8MUD Reader
I'll take the low hanging fruit...In a racing application the idea is to get the most HP you can and by stripping everything off the belt drive you gain HP, which when .001 seconds counts in a NASCAR race it makes sense...On an FJ40, not so much.
I really can't imagine that you'd pick up any noticable difference in MPG, even on a wind tunneled dyno. The key being the wind...you have noticed that an FJ40 isn't the most svelte body style right? This reminds me of the old windows down or AC fuel economy question. I'm running both a GM pump and a york compressor, and I can't tell a difference when the york is on, or off from a power standpoint... But like Poser said, build it, write it up and ![]() ![]()
__________________ Please donate to the Rescue Tellico Fund and help save the Tellico OHV area --Todd Chattanooga, TN 1980 FJ40, H41/0rion, SOA, 38.5 TSL/SX, LF Beadlocks, Longs, Sag pwr steer w/ ram assist. TLCA#: 4920 STLCA Rescue Tellico Committee (SFWDA) And yep...I am White Trash
#21 |
I thought very seriously about going Electric motorised FJ rather than diesel.
What stopped me was DISTANCE, how far from the beach house I could go before I ran out of electricity, the problem was SIZE, WEIGHT of cable, energy lose, plus room required for the energy source. This is what I came up with
__________________ Rebuild 1974 FJ40 2F into a 1984 HJ43 2H Diesel. http://forum.ih8mud.com/40-55-series-tech/173333-rebuild-my-fj40-1974-rhd-down-under.html |
#22 |
Noaccount Webwheeler
I've seen that setup on pulling trucks to hold on to every ounce of HP and torque the engine can supply. Are you strictly offroad, as in dedicated trail truck?
Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#23 |
Elec pump
It's not a bad idea but it still takes an amount of HP to drive the steering gearbox to do it's work. So I might be wrong but the ALT will need to work that much harder to produce the ELECTRIC to turn the electric pump. The alt is belt driven so I don't see any gain. No matter what you do the engine is still making the HP to do the steering. Bill
