10-08-07, 11:28 AM
Chevy 350 Carburetor??
I'm finally shopping for a replacement carb for my stock 1972 Corvette 350 engine (Edelbroch Performer manifold). Has anyone done the research into which manufacturer and size works best in fj40??
Happy Columbus Day!
10-08-07, 11:32 AM
Happy Columbus Day!
not in a 40, but quadra junks (quadra jet) 4 barrells usually work pretty good on 350's.
for a bit more coin, you can go with holley's 650's or 750's. I would think though the 650 would be fine for powering the 40 while also lending itself to better MPG's
I had a holley 750 double pumper on an Ford 360 once and I always had a hard time keeping enough fuel running through the bowls. It always wanted more than I wanted to give to it!
Bear
not as young as I was once was, but 'bout as good as one knight should be!
 that goes where??????
10-08-07, 11:39 AM
holley 4150 truck avenger
"Yes I have a Pool, I have a Pool and a Pond, the Pond would be good for you."
10-08-07, 11:40 AM
What about the edelbrock 600cfms? Anyone running one of those??
10-08-07, 11:47 AM
This subject has been beaten to death badly many times. Holleys suck ass for off road use unless you have them modified for such. Quadrajet seems to be the winner carb wise from most of the posts on this subject, and speaking from personal experence, it has worked the best in my 350 fj40.
And mileage wise, the theory I once heard was that Qjets were better for mileage due to the small primaries which is used most of the time, saving the large secondaries to really drink it down when needed.
10-08-07, 11:51 AM
I guess edelbrock is out of the running??
10-08-07, 12:01 PM
chebby 283...edlebrock torker II with a holley truck avenger 400 cfm...so far very pleased with the performance of both
osagecruiser
1968 fj40 back in the shop for a few more mods(after DSR!)
1972 fj55
1963 fj45 swb....
LX450
Tornado Alley Cruisers
tlca member #14777
10-08-07, 01:47 PM
another vote for quadrajet... thats what i got..
71fj40-350,SM465,3SPD L/C T-Case,4 WDB's,SAGINAW
Dude!, those are my work moccasins!
10-08-07, 01:59 PM
I have a Quadrajet in my Goodwrench350, and think is the best choice for this engines, never failed.
Emmanuel N Serna MD
10-08-07, 02:07 PM
#10 (permalink)
Hey guys,
I really appreciate the input. I've talked to several people and have gotten several differenct answers. My thoughts are; the factory QJ carb cant be that bad if Gm used em on their Corvettes? Now... can anyone recommend a decent carb rebuilder in SOCAL or NORCAL???
10-08-07, 02:07 PM
#11 (permalink)
I switched from Edelbrock ,to Quadrajet ,it's like night and day between the two ,Edelbrock wins hands down on the street ,i loved it .the motor had alot more get up and go ,but for offroad and off camber situations .the Quadrajet wins everytime . i miss the umph of the Edelbrock , but the Quadrajet is what i have kept on it for the past few years .The Quadrajet works flawlessly offroad .
Jake S.
FJ40,350 small block ,sm465 ,spring over ,cut-N-turn,saginaw,shackle reversal, 38.5 superswampers, 4 wheel disc brakes, OBA=CO2 ,
Warn 8274 ,4x4 labs high steer,Marlin chromo birfs ,lunchbox lockers(front+rear) ,Metaltech Jackson cage
 ... ROTW:PBGBOTTLE
....  ... Cardomain Pics
10-08-07, 02:19 PM
#12 (permalink)
Howdy! I am running the Edlebrock/Carter 500 cfm w electric choke. Less cfm usually means better low rpm performance traded for a little less top end. Quadrajets were factory equipment on Chevy for many years. Probably the easiest to bolt on and drive, especially since that's what you have now. I assume it is beyond rebuild? Just about any carb will need some adjustments or mods. Edlebrock seems to be the least expensive, and simplest to work on. Get one with spring loaded floats, block off the crossover passage in the rear of the body, and run a variable pressure regulator with a gauge. I run about 6 psi on the street, but about 3 in the rocks. Mine runs good under 500 rpm for those "delicate moments" when you really wish you had put in a crawler box! I hate smoking the clutch so I'm not banging in the rocks. John
85 Toyota mini truck  for chase/support!
CSC #41
10-08-07, 02:26 PM
#13 (permalink)
I am also running a Edelbrock 600 cfm on a 283 after my Holley 2bbl gave up for good.
I still think a quadrajet would be better in offroad conditions.
FIST IN THE AIR IN THE LAND OF HYPOCRISY!!! 1978 FJ40 - 283 V8
10-08-07, 02:26 PM
#14 (permalink)
Oh Sh_t! I'm really getting confused now. Anyone else got anything else to say? I think I'm gonna have to put all the replies in a hat and pull out the lucky one... they all sound good.
10-08-07, 06:36 PM
#15 (permalink)
qjet
10-09-07, 08:27 AM
#16 (permalink)
Hey Camcruiser13,
Is there a model # or year that works better? My Qjet is from a 1972 350...
10-09-07, 10:30 AM
#17 (permalink)
x1000
I had an Edellbrock on my 40. Kicked ass on the street. ANY off cambor and it would load up and flood.
My Ebrock is for sale on this board under my user name. My asking price is a steal.
1977 FJ40 Softop
Chevy 350
Turbo 400
35 inch MTR's
Dual Band Ham
8274 with Synthetic rope
40 gallons on board fuel
10-09-07, 11:08 AM
#18 (permalink)
Hey Camcruiser13,
Take the numbers off the side of your carb and go get a rebuild kit & carb cleaner and rebuild it. Or find someone local to rebuild it for you. It should be fine.
72FJ40/350/sm420/model 18T/Case/4.88's/D44frt/
Detroit/ARB/36tslsx/8274/scout p/s/$on$on$on
75FJ40countycruzer/350/NV4500/32bfg
76 CRUSTY,K20/350/350/203/14BFF/ D44/
FARM BEATER OR PARTS IN A PINCH
www.jpknightdiamonds.com
10-09-07, 11:56 AM
#19 (permalink)
Originally Posted by FJ40_owner
x1000
Howdy! That is a very common problem on the Edlebroch/Carter setup. It takes about 15 minutes and 5 cents worth f fuel line to fix. Just remove the top plate from the carb, insert some fuel line vertically into the long passage that connects the two float chambers, then cut off the fuel line flush with the top of the main body casting. It does not have to be 100% fuel proof, just has to stop the rush of fuel from running lefty-righty on off camber trails. Best 5 cents I ever spent. John
CSC #41
10-09-07, 12:26 PM
#20 (permalink)
If you want to actually drive it on the trail there is nothing better than an old Q-jet. I have built alot of carbs for my buddies that even spent the big bucks on the so called trck carb and they are all running the q-jet again......Rod.....
10-09-07, 03:06 PM
#21 (permalink)
where does vacuum secondaries and mechanical secondaries fit in this topic ,and does it make a difference? just thinking out loud , doesn't the Q-jet only sucks what it needs . versus mechanical always opening up no matter what .
Jake S.
 ... ROTW:PBGBOTTLE
10-09-07, 03:46 PM
#22 (permalink)
Howdy! Good question. As I recollect, vacuum setup is less aggressive, and perhaps more economical. The mechanical ones are adjustable, and you can feel them when they "kick in". Back in the 60's when I was a crazy hotrodder, I spent a lot of time working on Rochester Quadrajets. Nowdays, I think they are actually made by Edelbrock. Still pretty much the same as the originals. Both old and new are a darn good carb, but a lot more parts and $$$ than my Carterbrock. John
CSC #41
10-09-07, 04:36 PM
#23 (permalink)
TLCA# Associate Member/Sponsor
If you can't have fuel injection, then Q-jet all the way. Everything that was mentioned above (that is good and holy) about the Q-jet is true!!!!!
10-09-07, 10:05 PM
#24 (permalink)
I've got a 71 with a q-jet. Love it in the rocks....has been very reliable. My buddy found a retired mechanic here in the San Diego area that rebuilds old carbs on the side. You take it off your rig, give it to him and he rebuilds it and gets it back to you. If you don't want to tackle the rebuild yourself, PM me and I will get a hold of my buddy and try and get the guys info. The guy's rebuilt the carb off my buds '68 Ford F250 and his 1980 Dodge 440 powered motorhome. They both run well. Good luck!
Mike in So. Cal Toycruiser71@yahoo.com
'71 FJ40
ProComp lift BFG Muds 4Spd w/3spd T-case
Chevy Small block w/RV cam Doug Thorley headers
True dual Dynomax exhaust
MSD Ignition w/pro billet distributor
Custom rear bench
10-08-08, 09:38 PM
#25 (permalink)
Stick with a quadrajet if you take it offroad. If you have one on there already send it to recarbco for a killer rebuild. Can't beat a q-jet.
Dan
97 FZJ 80 locked and stock with 80K--Slee harness and side marker mod. Georges LEDs--mall cruiser
72 FJ40: V8,SOA/shackle reversal/ford shock towers,discs, traction bar, 4x4lab hi-steer,longs, locked on 37s, dual-batt, fresh wire, OBA,tube fenders and leather power seats
TLCA #13723
10-08-08, 10:17 PM
#26 (permalink)
I have a Qjet on a 327 and agree with the above pertaining to Qjets. I would go Qjet or injected, and nothing in between.
1991 FJ80
2.5" Medium lift, .50" spacers in front (still uneven) 33's on black steel, snorkel, de-smogged and some other stuff.
2005 Sequoia 2wd (for the wife & kids).
66 FJ40 (Sold on MUD!)
3F-E De-Smog Thread
Originally Posted by Tofudebeest
We would get along like peas and carrots. He'd fish while I drank all his beer and puked on his deck. We would laugh, I'd get punched in the face. We'd laugh some more. I'd swim ashore. Good times.
10-08-08, 10:28 PM
#27 (permalink)
x2
impressed with it. truck aveneger carb is over rated and priced. not worth it
10-09-08, 05:32 AM
#29 (permalink)
I just replaced our Holley 4160 with a Edelbrock 1406...600CFM with Electric Choke.....for $179 from Summit. Search for part Number EDL-9906........factory refurb.
We're running Edelbrock Performer intake too........anybody need a used Edelbrock Torker II?
10-09-08, 08:29 AM
#30 (permalink)
another vote for the Q-jet. i started with a holley, then an edelbrock both did well on the street. the holley didnt like to run up hill, the edelbrock didnt like off camber. ive had the quadrajet on for the least amount of time but i have to say its a big improvement off-road.
78 fj40 sbc,sm465 / 87 fj60 3fe DD / 89 mini stock / 85 celica gts conv. / 77 celica gt/ 01 4-runner
