Old 10-05-07, 12:28 PM   #1 (permalink)
vacuum guage interpretation
Please weigh in your opinion:
My truck runs well except for a slightly rough idle.
Jim C.-rebuilt carb roughly 4k miles ago. I told him the condition, smog-wise, of my engine, and he rebuilt from there. I have no reason to suspect the carb, it's been starting and running great (except) from day 1.
New plug wires, cap, points, etc. Dizzy is a non-usa vac-advance in great shape. Stock manifolds.
Vacuum guage reads 22 in Hg at idle, with slight irregular fluttering, up/down 1-2 in. Flutter sort of mimics the idle stumbles. Behaves at it should thru all other driving conditions.
Best source I could find that addressed the minor flutter mentioned valve overlap on high-lift/high-duration racing cams, but their idle readings are around 15-17 in.
So I think my rough idle is valve adjustment. What do the masses think?
'71 FJ55 Arizona truck
1 1/2" shackle lift, 33 x 9.50 BFG All-Terrains, 4-sp with Fairey overdrive, big brush guard with Warn 5687 (works now!), otherwise bone stock.
Plans: PS this winter, home-made headliner, 2 1/2" Alcan lift
brider is offline   Reply With Quote
Old 10-05-07, 12:37 PM   #2 (permalink)
LT
Supporting Vendor
LT's Avatar
Have you tried using the vacuum 101 on the technical page? It has a lot of useful information when it comes to reading your vacuum gauge.
Vacuum 101
Propane Powered 2f.
LT is offline   Reply With Quote
Old 10-05-07, 03:44 PM   #3 (permalink)
colangut's Avatar
This is a great page:
http://www.classictruckshop.com/club...ts/vac/uum.htm
"Needle rhythmically drops 1"-7" below normal Leaking combustion chamber or valve; ignition or plug failure effecting one cylinder"
-Stumbaugh
colangut is offline   Reply With Quote
