09-28-07, 03:17 PM
Front Spring Flip
As many of you know I have completed the rear spring flip and SOA on my FJ40. I am starting work on the front now. I have a shackle reversal on the front. I thought in doing my research I read that you want the military wrap on the side of the spring pack that is bolted to the frame. Due to my shackle reversal, this would mean that I can just spin the whole spring pack around and bolt it back up, correct? The military wrap would then be located in front, where my shackle reversal connects to the frame rather than the rear where I have a shackle.
Thanks!
09-28-07, 03:29 PM
Yup.
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser... LCR4WD), ARB Front/rear(By Poser... LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
09-28-07, 03:47 PM
as degnol says yea and you will be set! that IMHO the best way to do it anywayz when sprung over.
09-28-07, 04:30 PM
youll proabaly need a longer drive line, and brake line possibly, the extra wheelbase is nice so its worth it...
1982 FJ40,SOA,with flipped springs,30 Sp Longs Superset w/ ARB, lockright rear, Long's HD Hub gears,H41 w/ Marks 4WD gear set for split Tcase,Saginaw Power steering,4x4 Labs Hi Steer Kit,37x12.5x17 GDYR MTR's,Cruiser Outfitters "Cut and Turn",Stock 2F all oem equipment,Man a fre tuned headers
09-28-07, 05:36 PM
Thanks for the info guys! I already have the extended brake lines and I will measure for the driveshaft once complete.
09-28-07, 05:45 PM
Who sells the rear fender flares that fit after cutting the wheel wells to accomodate a spring flip?
09-28-07, 09:18 PM
Most run the TJ flares for a j**p
Youll be very happy with flipped springs front and rear.
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
