Old 09-27-07, 08:25 PM   #1 (permalink)
3OTT help I gots a floppy shaft
Folks, I need to make a decision here.. I have a 71 that I plan to make a partial DD in a year or so. The three on the tree needs some help . Lot's of slop in the column only. The bolt in he lower column where the linkage starts under the reverse switch is loose or worn out?? It has a funky bolt with a hole in it and a wire wrapped around the shaft. Also the other worn linkage is the shaft that is closest to the engine kinda like a ball a loop socket junction the after the column pivot the closer to the engine one lots of play there. I think these two areas would get rid of my floppy shaft issue.
Or locally I can get the complete parts to swap in a 4spd from a 77 bell to shafts. Would I still be able to use my bench seat??
I don't mind the 3ott, but I would think the 4spd would give me more gear options for the F?? do like the retro column shift, but would hate to not drive it cause it's a pain in the dupa.
Please let me know what I should do?? This is a mall cruiser and occasion weekend wheeler.
thanks
bob
I cut this wire 3 times and it's still to short.
norville is offline   Reply With Quote
Old 09-28-07, 08:48 AM   #2 (permalink)
total rice
dgangle's Avatar
TLCA# 10793
I'm sure there are a multitude of reasons Toy went from a three on the tree to a floor-shift 4 speed. I would think the benefits far outweigh and whether or not the shifter clears your benchseat is the least of your worries. Alter the bend of the floor shifter with a little heat if you need to. It's only metal. We can out-think it.
1975 FJ40 - V8, 4WDB, Saginaw PS, SR, 4" lift w/ 33X12.50X15 BFG MTR's, M8000 ROTW
2007 4 Runner SR5 4WD - stone stock daily driver
TLCA#10793
"The advent of the internet has permitted stupid people to propagate their stupidity WAY too easily, all with a position of self-proclaimed authority preying on peoples' ignorance or stupidity. Everyone with a keyboard is an expert." UNKNOWN
dgangle is offline   Reply With Quote
Old 09-28-07, 08:51 AM   #3 (permalink)
I guess the cheapest easiest option would be a floor shifter for the 3 speed. I just hate passing up a good deal on parts so close. Seriously though I could use that money on other items needing attention and get it on the road sooner.
bob
Old 09-28-07, 10:52 AM   #4 (permalink)
Degnol's Avatar
TLCA# 14529
Bob, I had the same problem on my '66 and just removed the TOT and bought a floorshift/top plate for $25. Ultimately i swapped in a 4 speed. The floor shift is easy, quick and gives a much more positive shift. Bonus is that there is someone else who will want it when you are done with it.
Ed
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
Degnol is offline   Reply With Quote
Old 09-28-07, 11:01 AM   #5 (permalink)
Ed
Ed, you may be able to answer all my questions.
How large of a hole did you have to cut in the floor? I assume you were able to remove the top cover with the tranny in the truck???
So why did you goto a 4 speed? Easier/better driving? Or did your 3spd crap out? How much would you spend for all the parts to swap out for a 4spd? If you had the oppertunity to get a 4spd and just lay it in the corner till needed would you have(prior to your swap)???
thanks
bob
Old 09-28-07, 11:31 AM   #6 (permalink)
Degnol's Avatar
TLCA# 14529
The hole was not that large, maybe 3"? I put the top plate on without the shifter cane and put a nice ring of grease on the part of the top plate where the cane attaches. Then I carefully set the tranny hump back on, removed and it made a nice ring right where the hole should be. If you get a little crazy with the hole, just use a 4 speed boot and it will cover nicely. Yes, top plate is easily removed with the hump off. I put the tranny in neutral so I reinstalled the new top plate in neutral, piece of cake.
GL
Ed
Old 09-28-07, 12:34 PM   #7 (permalink)
Pin_Head's Avatar
The column shift is retro cool. Fixing it by replacing worn out or loose parts would be the easy way as many people throw them away.
Pin_Head is online now   Reply With Quote
Old 09-28-07, 04:48 PM   #8 (permalink)
Pin-Head, I agee, but I'm having trouble finding any info on the linkages. No one stocks the parts. And I haven't seen any for sale in the FS section. I admit I did not post on the wanted section...
I would love to see a write up and some pics if anybody has them. I've been to SOR and I have a toy manual here but the pics are small and not a lot of info.
bob
