Old 02-15-08, 10:12 AM   #41 (permalink)
Coolerman's Avatar
Cool
Originally Posted by bsmith123 View Post
where'd you get the hoist stand combo?
Both are Harbor Freight specials. The stand is a 1000 lb stand and the hoist is a 2 ton hoist. Got both on sale last year for $199.00 total.
The hoist handles the engine easily, even when extended to the 1/2 ton position. This setting is necassary even with the front bumper removed!
!Oy my 1971 FJ40
It's not having what you want, it's wanting what you got...
http://tinyurl.com/ygeqfp7 FJ40 Wiring Parts for Sale
http://tinyurl.com/mxj5ve Misc Parts FOR SALE!
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 02-15-08, 10:20 AM   #42 (permalink)
IDave's Avatar
Did you have any trouble hooking the bellhousing under the lip of the dash? I found I've had to do a little manipulation to slip it under there because of the ps rear motor mount leg catching on the steel bracket thingie round the mount on the frame.
9/70 FJ40
9/64 FJ45 (L) P-B
4/84 Toy 4x4 Mini PU
We do not see things as they are;
We see things as we are. --Talmud
IDave is offline   Reply With Quote
Old 02-15-08, 10:57 AM   #43 (permalink)
CruisinMT's Avatar
damn that engine looks sick...It so clean and purdy. what is the red deal called in the 2nd picture?
67' FJ40 3- On the Tree
Rebuilt F 135 Bored
2.5 " Rancho Lift w/ 1.5" Extended Shackles
33 x 9.5's MT's
My ROTW http://forum.ih8mud.com/40-55-series...cruisinmt.html
1996 3.4L 4 Runner
135K
31X10.5 Goodyear Wranglers
08/89 FJ62 "Bruiser" (For Sale)
CruisinMT is offline   Reply With Quote
Sponsor 02-15-08, 11:23 AM
Sponsored Link
advertisement
Old 02-15-08, 11:23 AM   #44 (permalink)
Coolerman's Avatar
Cool
Not really, the body is hanging from the celing! I rolled the frame out from under the body so it was a straight shot in. Cheating I know...
!Oy my 1971 FJ40
Old 02-15-08, 11:25 AM   #45 (permalink)
Coolerman's Avatar
Cool
Oil Pressure Regulator
!Oy my 1971 FJ40
Old 02-15-08, 11:26 AM   #46 (permalink)
IDave's Avatar
D'oh! Yeah. Damn Cheater.
9/70 FJ40
9/64 FJ45 (L) P-B
Old 02-15-08, 11:32 AM   #47 (permalink)
Coolerman's Avatar
Cool
I've been so used to having total access to everything, it will be a pain to work on when it's all back together!
!Oy my 1971 FJ40
Old 02-20-08, 11:04 AM   #48 (permalink)
Coolerman's Avatar
Cool
OK, with all the pressure on me to get this out of the garage, I was forced to work on it some more.
Got the flywheel/clutch installed (sse here for the clutch disk backwards screw-up...
I made a clutch alignment tool from my old 3 speed tranny input shaft. Works perfectly and doubles as a paper weight.
I got the CCOT slave mounted and everything lines up correctly.
Then I started installing the 4 speed tranny...
I cut the heads off of two 12mm x 1.25 x 4" bolts to make some guide studs, greased up the T/O hub and slid the tranny into place. Piece of cake! Only had to wiggle the ouput shaft maybe 1/4 turn.
!Oy my 1971 FJ40
Old 02-20-08, 11:14 AM   #49 (permalink)
Coolerman's Avatar
Cool
and that's when I spotted what everyone said would be the issue: The @#$@#@# crossmember!
Just for reference: I'm doing the 4 sp trans to 3 sp t-case swap... The 4 sp trans is of course longer but some have claimed to get it in without moving the crossmember. I knew this was an issue, but wanted to mount the trans anyway to see for myself how much room there actually is.
There is aboput 2.3" between the end of the output shaft anf the crossmember. The T-case is of course 5.1" wide. I read I could remove the rear engine mounts and use a jack to lower the engine/tranny enough to slide the T-case on but have not tried it yet. This still means the e-brake could not be serviced without dropping the engine down again.
I may have to just cut the crossmember and move it back... Grumble grumble...
!Oy my 1971 FJ40
Old 02-20-08, 11:54 AM   #50 (permalink)
phishtaco's Avatar
Thats a good looking bellhousing.
73 FJ40
04 4Runner Sport V8
94 FZJ80(gone away)
phishtaco is offline   Reply With Quote
Old 02-20-08, 12:03 PM   #51 (permalink)
Coolerman's Avatar
Cool
Baked@ 600 degrees to remove grease, sand blasted to get the gunk off, powder coated gloss black. I did the 3 sp bell housing also at the same time.
Pics show differences between the F and 2F housings.
!Oy my 1971 FJ40
Old 02-20-08, 01:37 PM   #52 (permalink)
kvanoort's Avatar
I've really enjoyed following your build and have also referenced your Website for my own project. Looks great and thanks for sharing your experience!
1972 FJ40 Keeper Project - Buildup Thread: http://forum.ih8mud.com/40-55-series-tech/138817-1972-fj40-restoration-project.html
1978 FJ40 Sold Project - http://coolfj40.stores.yahoo.net/1978fj40.html
1975 FJ40 High School Cruiser - If that cruiser could talk...
kvanoort is offline   Reply With Quote
Old 02-20-08, 02:17 PM   #53 (permalink)
Wildman's Avatar
I am in the exact same spot, but my Xmember seams to have been modified, is yours directly 90deg straight up from the frame? Or is it rolled back a bit? Its hard to tell from the picture.
People dont get it, theres no blank spots on the map anymore, anywhere on earth, if you want a blank spot on the map, you gota leave the map behind...
Build thread: updated 2/23
http://forum.ih8mud.com/showthread.php?t=169539
Wildman is offline   Reply With Quote
Old 02-20-08, 09:27 PM   #54 (permalink)
Cruiser Curmudgeon
FJ40Jim supports the BlueRibbon Coalition!
FJ40Jim's Avatar
Pick it up!
Mark, just cherry-pick the engine & trans straight up one foot, and install the t-case, then set it back down.
I hate to say shoulda, but you shoulda bolted the whole engine/tranny/case together and then set it in the chassis.
But you're making nice progress!
Thanks,
Jim C.
TLC Performance <useful parts FS>
Underhood Janitor, cleaning up other people's since 1988.
FJ40Jim is offline   Reply With Quote
Old 02-21-08, 05:02 AM   #55 (permalink)
Coolerman's Avatar
Cool
Mine is actually tilted TOWARD the engine! I wondered if, as it came down the assembly line, that the assembler put some straight up, some tilted back, and some tilted forward?
!Oy my 1971 FJ40
Old 02-21-08, 05:11 AM   #56 (permalink)
Coolerman's Avatar
Cool
Thanks Jim, I read that many do assemble the whole thing on the floor then lift it into place. I did pull it all in one piece.
I just wanted a stable platform to install the clutch, tranny, and t-case I'm doing this completely by myself so stability is a huge factor.
In your experience, can the E-Brake be serviced without pulling the whole engine/tranny/t-case again? If it can I may just go ahead and lift it again to put the case on instead of moving the cross member. The hoist is still in position!
!Oy my 1971 FJ40
Old 02-21-08, 05:27 AM   #57 (permalink)
watrob's Avatar
Hi Coolerman,
Your making great progress, how much room do you have from the firewall to the back of the rocker cover. Its hard to tell from the photos but I was wondering because your so close to the crossmember when the transfer case goes on.
Will you have problems mounting the tub back on do you think?
Rebuild 1974 FJ40 2F into a 1984 HJ43 2H Diesel.
http://forum.ih8mud.com/40-55-series-tech/173333-rebuild-my-fj40-1974-rhd-down-under.html
watrob is offline   Reply With Quote
Old 02-21-08, 05:41 AM   #58 (permalink)
Coolerman's Avatar
The engine is in the stock location so there will be no firewall issues. In my pics the tub is actually hanging from the ceiling of my garage on cables. I can roll the frame in and out from under it to work on it.
I'm installing a 4 speed tranny in place of the stock 3 speed. It's longer than the 3 speed, so the t-case is too close to the cross member to install it without dropping the engine or raising the engine.
!Oy my 1971 FJ40
Old 02-21-08, 07:44 AM   #59 (permalink)
Cruiser Curmudgeon
FJ40Jim's Avatar
The BH and clutch must be installed w/ engine hanging from the crane. Then the engine can be set gently on a piece of plywood, then tranny & t-case are scooted up against BH and carefully maneuvered into place. The use of an engine tilter and some miscellaneous wood blocks helps a lot.
No, getting the e-brake off will be impossible w/ out either: lowering the rear of the engine or cutting out the x-member.
So install a new pair of shoes and replace the cable if at all questionable, then install the whole unit into the truck. Because you've antiseezed the P-brk works and replaced wear parts, you will not need to get in there for another 10-20 years.
Thanks,
Jim C.
Old 02-21-08, 10:42 AM
Sponsored Link
advertisement
Old 02-21-08, 10:42 AM   #60 (permalink)
excellant post
this has to be the best build thread i've read.
for anyone who has'nt seen his home page it's the best congrats coolerman i'm looking forward to more on you're web page.
71 fj40 2f eng
73 fj40
scotscan is online now   Reply With Quote
