09-04-07, 12:59 AM
Lifer with a 2F-ETI
2F-ETI Home brew air to water Laminova intercooler
After looking around and not been able to find a suitable inter-cooler for my 4.3Ltr stright 6 comp engine running upto 15psi of boost at an estimated 400hp I decided to build one.
Air to air is just too bulky and limited when air flow is low when wheeling so I decided to go with water to air.
Had a quote for a company here that use Laminova intercooler cores for $3000Aus    which are very compact and highly efficient.
So I hit ebay and picked these up in the USA for $50 plus $40 for shipping
http://cgi.ebay.com/ebaymotors/ws/eB...158682257&rd=1
Smart Aluminum Supplied the rest.
200mmx200mmx10mm Plate
34mx16mmx3mm Flat bar
2.5mx80mm Tube 3mm wall thinkness
All up $150Aus
Let the fun start
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
09-04-07, 01:29 AM
check out this company...used to use their stuff before I totaled my Porsche. They are a really great group. Their air/liquid intercooler pipes are awesome.
http://www.lindseyracing.com/mm5/mer...&Store_Code=HP
74' FJ40 Freeborn Red, 114kmi, 31x9.50 ssTSLs on stock steelies, stock, except non USA Dist. Awesome.
09-04-07, 04:44 PM
Lifer with a 2F-ETI
The sleeves for the Laminova cores have been cut
The 10mm plate is marked out and 4 holes will be machined through the plate. 10mm of each end of the Sleeves will be machined down to slot into these holes for a flush fit with the other side of the plate.
Finished size should be about 140mm X 177mm X 376mm
Links
Mac's Space
On the rev limiter
09-10-07, 03:57 PM
Lifer with a 2F-ETI
The 3mm plate when all the parts are ready will welded up, just waiting on the cores arriving now
Links
Mac's Space
On the rev limiter
09-12-07, 07:11 PM
My son got one of these for his Corrado off ebay. Air to water with radiator and pump for about $100.
And it's toyota.
Kevin
72, 74 and 78 FJ40s
09-14-07, 09:00 PM
Lifer with a 2F-ETI
The 65mm in and 80mm out are now finished
This will sit opposite the throttle body intake just have to figure out some mountings.
Still waiting on the intercooler cores now
Links
Mac's Space
On the rev limiter
09-14-07, 11:11 PM
Nice show of skill man. You have a very cool set up. Hows it run ? Thanks David.
09-14-07, 11:16 PM
Lifer with a 2F-ETI
Best have a read here mush easier to understand then my explanation would be lol.
http://www.opcon.se/index.asp?sPage=1&langID=2&cID=15
Still have to make up the end caps with the water fittings but waiting on the cores now
Links
Mac's Space
On the rev limiter
09-17-07, 04:57 PM
Lifer with a 2F-ETI
Links
Mac's Space
On the rev limiter
09-18-07, 11:59 PM
#10 (permalink)
Lifer with a 2F-ETI
Picked up 300mm of 65mmO/D Aluminum bar today the end caps for the intercooler cores will be machined from these.
Almost there, anyways time for a break away to the Alpine Challenge on Friday morning back late Monday.
http://www.alpine4x4challenge.com/
Last year pics, we were team one  just watching this year though
http://www.offroadimages.com.au/4x4e...dex.php?cat=17
Links
Mac's Space
On the rev limiter
09-19-07, 01:17 PM
#11 (permalink)
So you have water in the cores, and air flows over the slotted tubes. All this is contained in a sealed box....except for the input air (I assume this draws from a filtered area), to the intake manifold?
09-19-07, 01:30 PM
#12 (permalink)
Lifer with a 2F-ETI
Filtered air compressed from the turbo comes in through the the 65mm inlet and is forced to pass over the cores inside the sleeves (slotted tubes). The spaces between the sleeves will be sealed with the 16mm flat bar.
This can be seen in the photo of the end which has the red air flow lines on and the black lines showing where the 16mm flat bar will go. All this will be sealed and welded and boxed.
The water will flow through the cores internals and is sealed with an O ring which is contained in the end caps. There are 8 end caps in total.
Just need a small radiator and electric pump and a thermo fan to suit radiator
http://www.opcon.se/www/files/lamino...cool_21apr.pdf
The Air will not be able to pass from one side of the intercooler to the other without having to go inside the sleeves and around the cores.
Links
Mac's Space
On the rev limiter
09-23-07, 07:17 PM
#13 (permalink)
wow that's an interesting set-up can't wait to see the final product
09-24-07, 01:07 AM
#14 (permalink)
Very interested to see how this works out for you so I can copy you
Jon m0zxj
01 UZJ100 auto - lifted, locked, front bumper, sliders, snorkel, big tyres etc.
93 HDJ80 12v auto - lifted, oem locked, front bumper, sliders, big tyres etc
09-24-07, 04:20 PM
#15 (permalink)
Lifer with a 2F-ETI
I emailed Laminova's R&D a link to this thread and asked for their opinion and guess what.
The actually took time to reply top blokes.
Hi Matt,
Interesting project! As I don't know the specification of your application
(such as air flow and temperature, coolant side conditions), it's hard to
estimate only by looking at the pictures. But the design of your intercooler
looks promising. I guess you're going to use 4 cores of Ø39,5 mm diameter
and approx. total core length of 392 mm (375 mm finned length)? This should
perform quite well based on your engine size and power.
The design of the sleeves is similar to what we have done in the past and
the 15 mm slot width is a good choice. Perhaps you have checked our webpage
for some design info?
Having the cores in a staggered arrangement is practical in terms of space.
Looking and the end caps, it should even be possible to make smaller (having
the sleeves closer to each other), but perhaps this is nothing critical...
Looking at the core orientation, you will route the water in parallel
through the cores? What kind of water pump will you use? The efficiency of
the intercooler is highly dependent on the coolant flow (velocity) through
the core and should be minimum 20 l/min per core. (That gives for parallel
arrangement a pump capacity of about 80 l/min total.)
Good luck!
Best regards
Mattias Antonsson
Project Engineer
Links
Mac's Space
On the rev limiter
09-26-07, 06:01 PM
#16 (permalink)
Lifer with a 2F-ETI
Dropped the sleeves, end plates and divider in to the welders today. Cash job  The guy that does the welding is top notch with a tig. But as a job on the side I have to be patient, 2 weeks.
While this is done all the end caps can be machined up, once we get the newly welded up section back the holes to mount the end caps can then be drilled in the end plates before the final outer skin is welded over.
Links
Mac's Space
On the rev limiter
10-05-07, 11:42 PM
#17 (permalink)
Lifer with a 2F-ETI
All welded up thanks to Awill4x4 and as always top quality work.
Now on with the end caps
Links
Mac's Space
On the rev limiter
10-24-07, 07:09 PM
#18 (permalink)
it looks aeronautical.... cool
71fj40-350,SM465,3SPD L/C T-Case,4 WDB's,SAGINAW
Dude!, those are my work moccasins!
10-25-07, 12:56 AM
#19 (permalink)
Lifer with a 2F-ETI
It's been a lot of fun to build from scratch, but the proof will be in the pudding next Jan when it goes in with the new engine and turbo.
Links
Mac's Space
On the rev limiter
10-29-07, 02:50 PM
#20 (permalink)
Lifer with a 2F-ETI
Elected to make a minor modification to ease the air flow into the plenum from the intercooler as suggested by Awill4x4. Every little bit helps. Just have to make the opposite side now.
Links
Mac's Space
On the rev limiter
10-31-07, 03:16 PM
#21 (permalink)
Lifer with a 2F-ETI
All done now time to weld it all up, you can also see inside the button which once welded up will be re drilled and tapped out to 14mm for the Air Temp sensor. Small hole to the right is the ISC air feed.
Links
Mac's Space
On the rev limiter
11-01-07, 11:31 PM
#22 (permalink)
Lifer with a 2F-ETI
Off to the welders next Wednesday
Once back the Laminova cores will be re fitted and sealed, then were waiting on the new engine so I can work out some mounting points.
Links
Mac's Space
On the rev limiter
11-02-07, 03:13 AM
#23 (permalink)
Matt....can you take some more pictures with a beer can or something to give us a sense of its size...perhaps hold it over the engine bay or something.
Looks great....pretty nifty fabrication.
11-02-07, 02:52 PM
#24 (permalink)
Lifer with a 2F-ETI
My Beer comes in 440ml
My ruler is 300mm long
But hope these help, remember the end caps are not on at the moment, I will also be swapping the quick release fittings over too 90 degree hose tails once all is complete and final testing has been done.
Links
Mac's Space
On the rev limiter
11-02-07, 02:56 PM
#25 (permalink)
Oh....that is a lot smaller than I thought it was. For knuckleheads like me that need the conversion....100 millimeters is like 3.94 inches. So...the length of that intercooler is a bit over 12 inches long and maybe 6 high at best.
cool....
11-02-07, 03:02 PM
#26 (permalink)
Lifer with a 2F-ETI
cool....
You could work it out by adding the o/d of the tubes plus the 15mm flat bar and 3mm for the outer skin  but I'd rather drink the beer.
Links
Mac's Space
On the rev limiter
11-02-07, 03:07 PM
#27 (permalink)
Yeah...I don't know what day and time it is there, but its like 5pm on a Friday here and I am not calculating anything else for the day. I am thinking about a beer and dinner....but definitely not in millimeters. I might switch over to 2 fingers of whiskey.
Sorry for the chat...I'll stop.
11-02-07, 03:16 PM
#28 (permalink)
Lifer with a 2F-ETI
Chat's cool
8:15 am Here just got off work it's the end of my week and I have 4 days off, it's Melbourne Cup on Tuesday (horse race and we have a public holiday for it here in this state)
Links
Mac's Space
On the rev limiter
11-09-07, 08:29 PM
#29 (permalink)
Lifer with a 2F-ETI
Links
Mac's Space
On the rev limiter
11-10-07, 02:12 AM
#30 (permalink)
Lifer with a 2F-ETI
Reassembled you can now see the intercooler cores in situ.
Links
Mac's Space
On the rev limiter
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/175439-2f-eti-home-brew-air-water-laminova-intercooler.html
| Posted By |
For |
Type |
Date |
| MegaSquirt Forum • Thema anzeigen - 2,0 16V mit Rotrex Kompressor |
This thread |
Refback |
11-11-09 03:10 AM |
This thread |
Refback |
10-20-09 10:55 PM |
This thread |
Refback |
10-15-09 11:21 AM |
This thread |
Refback |
09-18-09 08:49 AM |
This thread |
Refback |
09-14-09 09:22 AM |
This thread |
Refback |
09-12-09 12:24 PM |
This thread |
Refback |
09-09-09 03:21 AM |
This thread |
Refback |
08-24-09 08:51 AM |
This thread |
Refback |
08-06-09 05:12 AM |
This thread |
Refback |
07-15-09 07:38 AM |
This thread |
Refback |
07-12-09 06:36 PM |
This thread |
Refback |
06-30-09 05:42 PM |
This thread |
Refback |
06-25-09 01:27 PM |
This thread |
Refback |
06-18-09 12:10 PM |
This thread |
Refback |
05-19-09 02:37 PM |
This thread |
Refback |
05-08-09 06:34 AM |
This thread |
Refback |
05-04-09 12:37 AM |
This thread |
Refback |
04-17-09 07:48 AM |
This thread |
Refback |
04-12-09 03:54 AM |
This thread |
Refback |
02-27-09 07:22 AM |
This thread |
Refback |
02-22-09 03:40 AM |
This thread |
Refback |
02-01-09 12:03 PM |
This thread |
Refback |
01-31-09 03:01 PM |
This thread |
Refback |
01-26-09 08:12 AM |
This thread |
Refback |
01-20-09 06:40 AM |
This thread |
Refback |
01-17-09 06:17 PM |
This thread |
Refback |
01-07-09 12:34 PM |
This thread |
Refback |
01-01-09 01:18 PM |
This thread |
Refback |
12-21-08 07:05 AM |
| Laminova cores in a intake manifold for a TURBO SETUP - Honda-Tech |
This thread |
Refback |
12-12-08 10:05 PM |
This thread |
Refback |
12-08-08 01:00 PM |
| Ever thought about building your own intercooler? - Memphis Racing Scene |
This thread |
Refback |
12-05-08 09:57 PM |
This thread |
Refback |
12-05-08 01:15 AM |
This thread |
Refback |
11-28-08 09:32 AM |
This thread |
Refback |
11-23-08 01:58 PM |
| Chilled intake...? - Page 2 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
11-20-08 02:42 PM |
| Possible source for Laminova intercooler cores - Honda-Tech |
This thread |
Refback |
11-20-08 01:03 PM |
This thread |
Refback |
11-13-08 03:56 AM |
| A Different Approach To Intercooling - Skylines Australia |
This thread |
Refback |
09-06-08 08:31 PM |
| FJ40-2F-ETI-LOCKED-N-LOADED - BUILD UP - INTERCOOLER |
This thread |
Refback |
04-21-08 06:38 AM |
| Outer Limits 4x4 Board :: View topic - Time to Turbo my 80 - any Thoughts? |
This thread |
Refback |
02-28-08 04:15 AM |
| High or low impedence - Page 7 - The Australian Magna Club |
This thread |
Refback |
01-14-08 04:39 AM |
This thread |
Refback |
01-13-08 07:38 PM |
