08-29-07, 09:55 PM
#31 (permalink)
very nice.
i like it.....
ivan
96 FJZ80 w/ lockers 177k stock
68 FJ40 SBC350 (in progress)
08-29-07, 11:47 PM
#32 (permalink)
amg2y took me up on the free drum brake parts.
They are spoken for now.
08-30-07, 07:24 AM
#33 (permalink)
Looking good.
Thats a lot o switches
___________________________________
FZJ80KIDPEN
96' FZJ80 186K miles
285/75/R16,OME 850/860's,locked,LED's
Homebrew Rear Bumper and sliders, Flareless and Line-X
09-10-07, 05:34 PM
#34 (permalink)
soo, we have had good waves for the last two weeks, so not much work got done.
Got a delivery of switches and connectors.
I decided to reuse the supports, in the back channel. I cut them out, and found the best way to get the old material off, was to use vice grips and twist.
My bend press will only bend so much, and I am running low on metal, so I ended up making the rear channel, out of three pieces. You can see in the picture the supports bars I slavage, from the orginal.
Here's the back end stitched up. After I finished this I had enough metal left to make the corners for the rear support bar.
09-10-07, 05:36 PM
#35 (permalink)
Originally Posted by amg2y
I got all the parts yesterday. Thank you very much.
Got my drum brake fixed and I don't have to double pump the pedal anymore. Thanks, amg2y
ttt
09-10-07, 08:06 PM
#36 (permalink)
Rounded up some nabors to get the tub off the frame.
09-11-07, 06:55 PM
#37 (permalink)
Orian HD
After I wire wheeled the top of my frame, and high pressure blasted it, I had to picked up my inspected NV4500 and Orian HD transfer case today. AA bolted it together for me, so what I did was:
Hoist the engine up to the back of the tail gate, and bolted the trans to the engine. Then I swinged it all around and onto the frame. Yea, nobody around to help today, but no problems or strains.
Here it is sitting on my frame.
Close up on the shifter knobs they provided for the twin shifter.
Next I will finish up the frame, and the underside of the tub.
09-17-07, 07:38 PM
#38 (permalink)
Metal Tech Family Cage
Metal tech full cage, hood loop, and stinger showed up today.
Too bad I don't even have the tub back on the frame yet.
I think by monday next week, I will be able to start in on the cage. I don't think I will put on the hood loop or stinger until I get a winch, and decide how to mount it all.
I have decided I will not be done in time to make it to Surf N Turf this year. I don't want to rush, and I want to enjoy this now that I am past the major damn body work.
Oh well, three years in a row is not too bad for SnT.
09-17-07, 07:54 PM
#39 (permalink)
Dog is my co-pilot.
Hi All:
Dude, awesome build thread!  Thanks for sharing all your hard work with us!
That Orion HD t-case is pretty damn badass! But, the body work you showed is even more badass!
Looking forward to the rest of this thread!
Regards,
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
" The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
09-17-07, 08:10 PM
#40 (permalink)
Originally Posted by Josie'sLandCruiser
Hi All:
Regards,
Alan
Thanks for the support, that body work, almost did me in.  Glad to be past it.
09-18-07, 10:26 AM
#41 (permalink)
Is is edible?
yeah, this is another incredible learning experience for me. thanks for keeping us all up to date.
and i agree with alan: the body work is awesome!
When the Reaper comes to my door, I won't be dragged away kicking and screaming.
I will, however, try to talk my way out of it: "No, no you must want the other BadKarma..."
1969 FJ40
2004 4Runner
09-30-07, 04:42 PM
#42 (permalink)
I have taken more pictures then have worked on it. Got the body back on the frame yesterday. I still have some body smoothing to do, but wanted it back on the frame, before I got my hammer and filler on it.
I rolled it on the grass to make it easier to bring the body on from the back.
The dog is getting pissed, because now that summer is over, and the life guards are gone, it's beach season for her.
The list is way too long, to make it to SnT.  If I did rush to make it, the paint would just be curing, and I would most likely end up with a sand/salt engraved paint job.
(this next part fits under the, "it's your cruiser, do what you want.")
For the inside of the cruiser, after going over my patches with herkliner, which was already on the rest of the inside, I sanded it down to take down the rough/sharpness, and painted over it. It still has grip, but not the scaring quality it has out of the tin.
I need to take some photos of the underside. the back channel, and all the body seams, i herklined. I also painted the whole underside black too.
Next I will plastic cover, and tape up the bottom, and inside. Start in on the roll cage, and final body work.
10-10-07, 05:22 PM
#43 (permalink)
I have plans to use a 4+ tire/cooler rack on the rear, and feel the round lights from my oct 72 were not going to cut it around here. So to change to 74 lights, I made end caps made out of old front bumper. Went rounded to match body curve.
tail lights.
not bolted tight, but will be flush.
Got on the cage some too!!!
I got a full bikini family top, and made a templete as to where the straps go, and Tacked according. Check door clearences and so on. Getting a good fit.
Cutting a V out then using a Grinder to do the tube notching, as other threads have concluded, works great. I also have a HF hole cutter, and dont like the cut it gives, another POS to be returned to them.
11-01-07, 10:57 AM
#44 (permalink)
Welded most of the cage while it was in the tub. Here it is after I sanded it and put some primer on it. I'll get my top coat on tomorrow.
11-06-07, 11:21 AM
#45 (permalink)
Cage Painted and set in tub.
11-06-07, 11:39 AM
#46 (permalink)
Shane-
Looks sweet. I'll have to swing by soon. Sorry you didn't get it done in time for SnT. What 4" springs are you running? My springs are pretty beat after many years and I have a BAD rear sag now after SnT.
11-06-07, 12:19 PM
#47 (permalink)
Originally Posted by DomSmith
Shane-
pm sent. - and I am running tpi4x4's Smoky Mountain set. I got these about 4-5 years ago when I was very green about land cruiser suppliers. I now think they are over priced. Ih8 their website, dose not work for crap on macs. I always have to start up Paralles just to view it, I definitely would not submit a credit card over their system, but that is a chat subject.
11-06-07, 01:00 PM
#48 (permalink)
great work, are you going to tie the cage to the frame? I really like the looks of their cages. And it looks like it works well with the top mounted wipers.
1970 FJ40 350 NV4500 Orion Elocker front SO SR (for sale!)
2007 FJ Cruiser
Adam C. Ventura CA TLCA# 6141
http://www.toyland4x4.com
11-06-07, 01:39 PM
#49 (permalink)
eventually I probably will do that when I go to build some rock sliders. For now, I need to get this thing running.
yeah, it's pretty cool how the top motor clears it. Over all really cool fit and well thought out bends.
11-06-07, 02:37 PM
#50 (permalink)
What kind of shackle angle do you have with those smokey mountain springs? I have a new set on my frame off and right now it is not so good. I know they will break in some.
11-06-07, 03:02 PM
#51 (permalink)
My pinion angle in the rear is about 5 Degrees. After I get finished loading this thing up all its gear and weight, making it sit some, i will measure it again, and the flange off my TC, and add shims accordingly.
The front have shims to correct the caster for good steering.
My shackle angle is vertical right now.
01-19-08, 10:48 AM
#52 (permalink)
hello,
Verry good worlk  , and nice truck
like the garage
bye
01-19-08, 11:04 AM
#53 (permalink)
Originally Posted by TIAMMAX
hello,
like the garage
bye
Thanks, I finally am able to get back at it today. After my Christmas trip, and then cold. Finally feel good enough to sand and prep for painting the main body.
01-29-08, 12:01 PM
#54 (permalink)
Great build thread! I really like seeing these things restored right. You've got some real talent.
02-23-08, 01:28 PM
#55 (permalink)
Primer
Well, finally have to put down the sander and call it good.
Tuesday/Wed looks to be a couple of dry days for us, so plan is to do a wet sand on tuesday, and paint on Wed. Between the new year, work, and weather, this part has drug on way too long. Also had to half my space because the neighborhood got a city enforcer nazie threw it, and most of us got warning letters about this or that.
They said my tent stuck too far out.
Next week we should see green, back to the original color, back before it got a couple crappy paint jobs to hid the rust.
  But I still have rear doors, fenders, front doors, Hood, skits, bib, to paint, but only the fenders and rear doors need preped. The others are primed and ready for a wet sand.
03-03-08, 12:56 PM
#56 (permalink)
03-03-08, 03:01 PM
#57 (permalink)
VERY nice work....love the color!
03-03-08, 03:38 PM
#58 (permalink)
Shane-
Nice work bro. I just got home from Tavarua Friday and have to install some cabinets then back at it on the cruiser I hope. I'd like to check it out first hand soon.
Dom
03-03-08, 07:28 PM
#59 (permalink)
Back to the original Rustic Green, it started out as.
03-03-08, 08:05 PM
#60 (permalink)
This is the first time I have viewed this thread. I am very impressed.
The green looks good.
VERY COOL
96 fzj80 My DD, OME 2.5, 315 MTZs, THULE rack and more to come.
