Go Back   IH8MUD Forums > Toyota Tech Forums > 40- & 55-Series Tech
Notices
Old 07-19-07, 07:01 PM   #1
Designs for parts made
I don't know if I should start this thread.
I am only starting this thread and I hope you will make it grow.
Post a pic or a drawing of parts or plates you have made to fix rusted or damaged parts.
Others can use your design to make their own.
Measurements should be include or some instructions if possible.
So here is my first one.
This is a drawing for the plate that goes between the rear shackle mount and the frame ( which usually rusts before anything else).
This the driver side , the passenderside is a mirror image of this one.
Put your preferred measurement on it and get one made. Drill the holes later , 1/8" thickness is good or 1/4" if you like.
I hope this a good idea.
Thanks in advance.
Vic
I would like to meet with people who own
BJ70s in Newbrunswick Canada area.
Vicm is offline   Reply With Quote
Old 07-21-07, 08:44 AM   #2
llih's Avatar
This is a great idea. Now if only I could draw.
1973 chevota
1990 suburban
1986 k3500
Stop the
SPP
Baldwin for President
llih is offline   Reply With Quote
Old 07-21-07, 11:07 AM   #3
If people get me their rough drawings, I can probably punch them up on AutoCAD and spit them back out as PDF's so everyone can open them. Work lets me do it to keep my skills sharp.
BayCruiser is offline   Reply With Quote
Old 07-21-07, 09:07 PM   #4
Here is another one.
The plate that holds the 2 rad support mounts in my front cross member was rusted out . This plate was made from 1/8" thick piece. 20" long as a replacement.
It sliped inside the cross member ( tight fit). No need to take that cross member out.
After alligning the rad and everything I marked and drilled the holes for the 2 rad support mounts.
B- Is a pice a coper wire I used to determine the 2 bends in that new plate A.
This plate can be welded or bolted to the cross member.
If welded, it is not noticable.
It worked out very neat.
Vic
Old 07-22-07, 06:01 AM   #5
excellant idea hope it takes of
scotscan is offline   Reply With Quote
Old 07-23-07, 10:09 PM   #6
ehsankiani's Avatar
Nice. Would love to see more
Ehsan
ehsankiani is offline   Reply With Quote
Old 07-24-07, 03:41 PM   #7
The following few drawings are for adapter plates that were made to
change stock SF rear axles to a FF rear axles with disc brakes.
Old 07-24-07, 03:43 PM   #8
Step 2
Old 07-24-07, 03:44 PM   #9
Step 3
Old 07-24-07, 03:45 PM   #10
Step 4
Old 07-24-07, 03:57 PM   #11
Here an actual pic of that plate after it is finished.
Old 07-24-07, 05:32 PM   #12
REZARF's Avatar
TLCA# 13041
all that technology and you must have used a camera phone for that pic
Just kiddin' you, great idea for a thread. Maybe they (the drawings) could be sent in full size template cut out form of some sort...
Rezarf <><
Drew F.
Rising Sun 4x4 Club
Old 07-24-07, 05:51 PM   #13
I am helping a friend put rear disc brakes on his 1990 Toy pickup now.
It would have been nice to find some post with a design for the caliper brackets.
That is the reason for this thread.
If you see something you want to copy it is there for you.
I would like to see some more stuff , and different ideas.
pumpers , tire carriers , frame parts and so on.
It doesn't have to a drawing , a pic will be fine. Just post it and someone will benefit from it.
Thank you for all your responses.
That pic was taken by a web cam. I know it is not the best , it sucks actually.
vic
Old 07-24-07, 06:14 PM   #14
Pinion's Avatar
TLCA# 11500
This is possibly the most interesting post I have seen here in a very long time. I hope this ends up an a FAQ or in the Technical Links with a new section.
Welcome to Midnight Q.
Tonight, we're going to enjoy the smooth jazz of Charles Mingus,
Norman Mailer is here to read an excerpt from his latest book;
and then we also have a girl from Omaha who's hiding a banana.
We'll find out where. Giggity Giggity, Giggity Goo.
Stick around.
Pinion is offline   Reply With Quote
Old 07-25-07, 04:41 PM   #15
This weekend I am going to start on this bracket.
For RDB with Toy calipers and rotors.
I can make it in one piece ,but because I will be using an old rotor, I will make it in 2 pieces along the blue line. That way I can easily change the distance from the rotor to the caliper mounts if I have to.
I think it is easy to mark the 6 holes using the backing plate for refference. Then I will use 1/2 a caliper to mark the 2 caliper bolting holes. I could also use a knuckle for that.
I will post a pic when I am done.
Old 07-25-07, 11:41 PM   #16
alex e's Avatar
Keep em coming. Rear crossmember repair plate?
1/75 FJ40 (soon to be V8 converted)
88 FJ62 Bionic Blue-SOLD
TLCA Member # 17731
Treat me good, I'll treat you better. Treat me bad, I'll treat you worse.
alex e is offline   Reply With Quote
Old 07-26-07, 06:16 PM   #17
Here it is , alex e
This was the easiest fix for my cracked rear cross member.
Had this plate bent wraped aroung the middle of the cross member , drilled the holes and bloted it to the cross member.
Man we are having a heat wave, I can't believe I am saying that in Canada..
Vic.
Old 07-28-07, 02:19 PM   #18
Ok , I started making that this plate today.
I ran into 2 problems as always, one I ran out of oxy so I had to use the grinder to cut the big hole. The other thing is I have to wait till monday to get the rotors and the calipers.
I made a little change to the design .
The main part is done and I got it bolted to the axle housings and everything is as expected.
I will put a drawing of the plate with the change then I will post some pics .
Old 07-28-07, 02:45 PM   #19
Here is the new design of the plate.
Old 07-28-07, 04:43 PM   #20
Warning: these pics are not the best.
Pic1 is the plate that I made today.
pic 2 the plate boltes to the brake baking plate mounting bracket.
pic 3 view from the back.
Old 07-28-07, 04:44 PM   #21
And here is a pic of the rotor on the axle shaft .
As you can see this is not the rotor I will be using to finish making this bracket or plate. So I will wait till I get the new rotors and calipers to finish it.
The rest is the easy part.
Thanks for looking.
Vic
Old 07-28-07, 09:55 PM   #22
cardinal fang's Avatar
TLCA# 6607
Caliper design for fj40 pdf format
Bill Jackson
AKA "Cardinal Fang"
1973 FJ40 - 1975 FJ55 - TLCA#6607
Folsom, CA
My webpage is here
"The iron hand
is no match
for the Iron Rod" ??
cardinal fang is offline   Reply With Quote
Old 08-01-07, 12:45 PM   #23
Here is some info for guys interested in RDB, but have the e-brake in the rear drums setup.
There are few calipers that can work with your existing cables you could use.
I think the best option will be the supra calipers (79-81)
I have included a pic of this caliper being used on a Toy pickup .
It could be used for RDB when you have your e-brake in the rear wheels.
As far as the bracket I am almost done , I have got one side comlete, I should have many pics hopefully by Monday or sooner.
Vic
Old 08-01-07, 01:21 PM   #24
In the garage
John Smith's Avatar
TLCA# 9074
Did you ever finish this project? If so, does it utilize stock FF spindles and bits from this point out? I am confused.
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 08-01-07, 01:54 PM   #25
Yes , I have been using that axle for few months now.
Here is a pic.
Vic
Old 08-01-07, 04:34 PM   #26
In the garage
John Smith's Avatar
TLCA# 9074
Here is a pic.
Vic
That looks very nice! Custom inner axles?
Are you a machineist or just really good with Cad and access to a mill/lathe? I believe you could make some $$$ selling these creations of yours.
79 FJ40 & 78 FJ55
Old 08-01-07, 08:31 PM   #27
Thanks John,
Axles ,I am getting some made this winter.
But right now I am just using welded ones. The reason for that is to test them and see how my seals hold up ,so I can make changes before I get custom made shafts.
I don't use or have any special tools , but the order and the way in which things are done can sometimes eleminate the need for accuracy and some of not all special tools.
For example you can make the bracket for the Toy disc brakes with only a drill an angle grinder and a 12m1.25 tap, but you have to follow a certain patren, and not necessarly the most logical one.
As far as selling stuff, I am not good at selling anything. So I tend to stay away from that, but I don't mind showing this to others. If it wasn't for others who show their ideas and know how, I wouldn't have learned much about cruisers and I am only a beginner still.
Vic
Old 08-01-07, 09:20 PM   #28
did you use a mini axle on the rear? if so how did you do you E-brake setup
project "SNAFU" 65FJ40/SBC350/TH350/NP205/SOA/manual steering
"I work harder not smarter"
65fj40 is offline   Reply With Quote
Old 08-02-07, 12:46 PM   #29
The pic in response # 23 is the rear of Toy mini with discs using the (79-81) Toy Supra calipers . These calipers have built in them levers that will work with your e-brake cables.
I can't see any reason why they can't be used on landcruiser rears that have e-brake inc in the rear wheels.
The rotors that you can use with the supra calipers have to be from the 79-85 Toy 4x4 pickups.
Vic
Old 08-05-07, 08:44 PM   #30
Rear dics ( Toyota parts)
As I mentioned before this weekend I am finished with making the brackets for 2 rear disc conversions.
One was done on a 89 Toyota 4x4 pickup Rear axles and one was done on a 78 FJ40 rear SF axles.
I will post the following drawings of 4 steps of how I made the caliper brackets for the fj40.
As I was doing this work the weather wasn't helping and I didn't have the expected extra hand , so I will be posting many good pics of every thing when I get a nice day and an extra hand, maybe somtime this week.
