also the linkage would need to be legthened or shortened, also the driveshaft
I think
__________________ 1980 FJ40 all stock, factory air and power steering
1988 FJ62 dog hauler
2X 1965 FJ45LPB
1963 FJ45LP, 1964 FJ45LV, 1970 FJ55 all needing some work
Thank you the quick responses. How would I find out if this PTO I am about to buy will be compatable? Is it something where I can pull the cover plate off the 71 and 75 (both 40s) and count teeth?
The PTO gear teeth are the same; the question is whether the 4sp transfer case has the PTO gear inside or not. If not, you need to buy a 4sp PTO gear and install it. A 3sp transfer case gear won't work in a 4sp.
I am not a great mechanic but trying to learn. So what I think I am hearing is a PTO is a PTO, regardless if it came off a 3 sp or 4 sp. What I need to check is whether or not the 4sp transfer case has the PTO gear inside. Does a 3 sp always come with a PTO gear?
Yep, for a given vintage, a PTO is a PTO. Didn't matter if it came on a three speed or a four speed. All 3 speed T/Cs had the PTO gear. The 4 speeds only had it if they also had a PTO.
