05-31-07, 11:05 PM
| | Look at my cow...
| Fuel Tank Line Source? Anybody have a source for the fuel tank line that goes from the tank to the outside tubing. I see SOR lists it all as discontinued. My 1971 has the flexible line with threaded fittings so no hose clamps.
I have not tried any other fitting on the tank.
__________________ Hugh Heifer |
06-01-07, 08:42 AM
| | Site Addict
| If you are talking about the fuel line that exits your tank at the side then through the floor; it's a british thread (whitworth), it's the same thread as the carb fittings. Do a fuel line search here you should find a few posts on it.
Many have retro fitted a peice of fuel line and installed a hardline into that reverse flare then used a peice of soft fuel line. I myself wanted a proper fitting and called on Mark at Marks Offroad.
If I continue to see folks looking for this peice I may stock up on these fittings and have the lines made up locally
__________________ 1978 (mostly) FJ-40, lift, 2F, bigger tires and custom swiss cheese body panels to reduce weight!
Various other toys 87 4runner, Motorcycles Ducati and Triumphs with an old Mach III in the mix. |
06-01-07, 08:57 AM
| | Forum Regular
| I could use one as well......... |
06-01-07, 09:12 AM
| | Site Addict
| I'll stop by the hydualic shop today or call, I'll need to run down my tank and pull the fitting, that won't happen for a week minimum. I tore down a knuckle and am waiting for parts. Other wise I can burn up a tank of dino in a few hours!!!!
Do you all want a line to go from the tank to the hard fuel line on the truck? Or one that goes to the fuel pump (soft line the whole way). I would need a measurement dependent apon how you will run your line.
06-01-07, 04:19 PM
| | Look at my cow...
| Quote:
Originally Posted by F-junker If you are talking about the fuel line that exits your tank at the side then through the floor; it's a british thread (whitworth), it's the same thread as the carb fittings. Do a fuel line search here you should find a few posts on it.
If I continue to see folks looking for this peice I may stock up on these fittings and have the lines made up locally | Fer sure. Would be worth it. There is no gromet in the hole where the line goes through the floor in my 40 and the fiber hose is getting shredded. I would like something as similar as the original.
06-01-07, 04:26 PM
| | Site Addict
| try these guys - they have almost everything http://www.mcmaster.com/ from fittings to hose and more crap than you can imagine |
06-01-07, 05:53 PM
| | Site Addict
| Also Check with Cool Cruisers of Texas. They are remaking some of the gas tank and filler parts. For what years I am not sure. |
06-02-07, 12:32 AM
| | elder statesman
| I have the threaded fittings to run standard 5/16ths fuel line from tank to filter, pump, carb etc in stock. But if you'd rather reinvent the wheel............
__________________ A carbureted man in a fuel injected world.
65SWB45, 64LWB45, 68FJ40, 69FJ40, 72VJ40, 76HJ45[gone],84FJ60[gone], 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
TLCA member, The White Trash Of The Elwood chapter
my website: http://www.marksoffroad.net IT'S FASTER if you CALL ME! |
06-05-07, 02:25 PM
#10 (permalink)
| | Site Addict
| Again I would recommend calling Mark above.
06-06-07, 12:46 PM
#11 (permalink)
| | Look at my cow...
| Quote:
Originally Posted by 65swb45 I have the threaded fittings to run standard 5/16ths fuel line from tank to filter, pump, carb etc in stock. But if you'd rather reinvent the wheel............ | That sounds like a plan. I'll give you a holler in a bit Mark.
06-06-07, 07:26 PM
#12 (permalink)
| | 250+ Club
06-06-07, 08:10 PM
#13 (permalink)
| | Site Addict
| I believe I tried here in the past. I know I looked for a twin 90 degree fitting and had no success.
