| I believe it also depends on the mini box bracket you use. I got mine from bbalbano (sp?) here on mud. Great bracket. I cut the column shaft on my '71 right at the flare above the worm gear for starters. I ended up cutting another 3.5" off the shaft prior to welding the rag joint adapter.
__________________ 10/71 FJ40,33s, HEI, 4WDB, PS
2000 UZJ100 Stock
2007 FJ Cruiser
__________________________ |
