Robert, if the transmission has been separated from a transfer case for any length of time, make doubly sure that the spacer sleeve on the tailshaft of the transmission that rests inside the rear extension housing is still there. The imput gear needs to press solidly up against it, or bad things will happen.
If you're not sure, best to post up again.
Best
Mark A.
