Old 05-07-07, 01:37 PM   #1 (permalink)
F-junker's Avatar
So what if I don't use the special tool???...
Yeah I'm sure to hear some stuff about it.
I need to rebuild one steering knuckle and don't have the SST spec'ed in the manual. Can I get close using all new oem toyota parts? Can I substitute something and improvise?
What if I tear it down and replace all (with New)bearings and shims back in the same order. Am I asking for a problem????
1978 (mostly) FJ-40, lift, 2F, bigger tires and custom swiss cheese body panels to reduce weight!
Various other toys 87 4runner, Motorcycles Ducati and Triumphs with an old Mach III in the mix.
F-junker is offline   Reply With Quote
Old 05-07-07, 01:39 PM   #2 (permalink)
use the same shims in the same order and it should (90% chance) be fine.
lcruzrlvr is offline   Reply With Quote
Old 05-07-07, 01:40 PM   #3 (permalink)
JJS
Get a heavy duty mechanical fish scale for 1/10th of the price. It will get you very close. Make sure you get one with a rigid hook on it. You can throw it in your tackle box after you're done with the axle.
Originally Posted by Atticus View Post
I've never shared a picture of my wife with you and this board. If I did, I would pick one that did not give off the impression that she was hydrocephalic.
JJS is offline   Reply With Quote
Old 05-07-07, 01:46 PM   #4 (permalink)
KY854RUN's Avatar
You will need a micrometer to measure the shims. Just measure the old shims and match the new shims to the old one's measurement. The shims should be equal top and bottom. This will get you close. If the knuckle is to tight then add shims as needed to get the right resistance. A fish scale can be used to measure the turning resistance of the knuckle.
Kevin
`85 4Runner - work in progress
M416 Trailer - ukn year, rebuilt July 2007, build thread
`68 FJ40 - planning stages of a build
Green Country Cruisers - member
Wish List - to long to post
KY854RUN is offline   Reply With Quote
Old 05-07-07, 01:47 PM   #5 (permalink)
D'Animal's Avatar
Garage
Thats what I did.
I did not know that Toyota made a tool for this application?
Land Cruiser Garage Sale Items <- Link
Get Your Marlin ToyBoxes Now!
Beagle Chariot
1962 FJ40
1964 FJ 40
1968 FJ 40 <- For Sale
FJ 40.5 Build 4BT Cummins Conversion
1976 FJ 40
SPEN Trailer
D'Animal is offline   Reply With Quote
Old 05-07-07, 01:50 PM   #6 (permalink)
KY854RUN's Avatar
Yes they do, if you read the FSM the special tool sounds harder to use then using the fish scale method.
Kevin
Old 05-07-07, 01:51 PM   #7 (permalink)
JJS
Originally Posted by D'Animal View Post
Thats what I did.
The SST is the spring-tension tool that Toyota made for service. It's still available, but it's over $100. The guy who taught me used a fish scale, and I think it's what most people use.
Old 05-07-07, 01:56 PM   #8 (permalink)
F-junker's Avatar
Thanks gents. Maybe I should get some more shims???
One quick question-- I lost my silverstar and can't figure out how to resubscribe.
Old 05-07-07, 01:57 PM   #9 (permalink)
KY854RUN's Avatar
There is also a special tool for determining the shim thickness needed and I was referring to using that tool. The spring-tension tool is nothing more than a glorified fish scale.
Kevin
Old 05-07-07, 01:58 PM   #10 (permalink)
D'Animal's Avatar
Garage
I used a Chilton manual when I did mine. I think they had a picture of a fish scale. I'll have to double check it.
Beagle Chariot
1962 FJ40
1964 FJ 40
1976 FJ 40
SPEN Trailer
Old 05-07-07, 02:23 PM   #11 (permalink)
camcruiser13's Avatar
just put the shims you took out back the same way you found them and dont worry about it.
youll be fine.
trail gear sales on for 10 bucks
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
DIY Beadlocks
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 05-07-07, 03:00 PM   #12 (permalink)
My understanding of the knuckle centering tool is that it is used for centering the knuckle on the housing. The fish scale (spring scale) is for the bearing preload measurment. Totally different things.
If you are rebuilding and using the same parts and reinstall the shims back in the same order as they were top and bottom, then you wouldn't need that centering tool , because the original shims will take care of that.
The spring scale you still have to use to adjust the bearing preload.
Which if you find to be out of specs, you can correct by adding or subtracting the same thickness shims from both top and bottom to keep it correctly centered. That is how I see it .
Vic
Vicm is offline   Reply With Quote
Old 05-07-07, 03:02 PM   #13 (permalink)
F-junker's Avatar
thanks guys I feel better about tearing back into it, new tre and budbuilt relay rod ordered today. I'm gonna stave off the saginaw for another year or so and stay with the popeye power steering!
Any advice on the factory style steering dampener as far as replacement? OEM etc.
Old 05-07-07, 03:29 PM   #14 (permalink)
Supporting Vendor
cruiser_guy's Avatar
This is true for bearing pre-load. It is NOT true for knuckle centering.
When you rebuild, use the same shims in the SAME locations and add or subtract equally from the top and the bottom for bearing preload.
www.wirrell.com
Old 05-07-07, 06:57 PM   #15 (permalink)
Macgyver's Avatar
lost??? something tells me it will be found and a pm will be sent on how to subscribe............ oh, fish scale is great......... just don't lie about your axle like you do about the fish!!!!!
NRA LIFE MEMBER
DAV LIFE MEMBER
gpojerry@gmail.com
Macgyver is offline   Reply With Quote
Old 05-07-07, 07:17 PM   #16 (permalink)
Supporting Vendor
Isotel's Avatar
Marlins new seals make up for the fact that you will never get it perfectly centerd without the SST
http://www.marlincrawler.com/htm/axles.htm#hdseals
I wheeled all week in moab, and no leaks yet from my knuckles!
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers -=- CrAwLoRadO.com
Redline Land Cruisers - PM me for info on our products or to order!
Old 05-07-07, 07:20 PM
cruiser88
This message has been deleted by cruiser88.
Old 05-07-07, 07:37 PM   #17 (permalink)
Degnol's Avatar
F-Junk, if you use a kit when you reassemble everything, it will/should have shims in it. I have some shims if you need them. I'll stick them in an envelope and mail them to you.
Ed
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
Degnol is offline   Reply With Quote
Old 05-07-07, 08:18 PM   #18 (permalink)
User title
gladly's Avatar
go to this thread
http://forum.ih8mud.com/payments.php
select either the one year or recurring membership option, click order, then follow the link to pay with paypal, you get your star instantly (or at least I did)
Originally Posted by yooper View Post
It's not The Adequate Thread.
_______________________________________
1975 fj40
2003 xr400
gladly is offline   Reply With Quote
Old 05-07-07, 09:31 PM   #19 (permalink)
The last rebuild kit I ordered from Marlin had shims for large and small pattern Knuckles. I just reused the ones that were in the knuck in the first place though. I pulled on the steering arm, It felt like 15 lbs or whatever the spec is and left it at that.
72 Fj40, lots of mods, nothing original-big fan of Mud.
Sorry if I am slow getting things in the mail, it's just this stinking job keeps holding me back.
FJ40fiji is offline   Reply With Quote
Old 05-07-07, 09:43 PM   #20 (permalink)
Marlin Crawler sells a scale for $10 for this anyway.
