Old 04-24-07, 08:13 PM   #1 (permalink)
77cruiser's Avatar
Defrost not working
Whenever it rains my windshield and windows become a foggy mess. Anyone have this problem? Do i need to rebuild the heater or replace hoses?
77cruiser is offline   Reply With Quote
Old 04-24-07, 08:15 PM   #2 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
Garage
Are you sure that your blower motor is moving air?
Are you sure that the air it is moving is going through the heater core?
Are you sure that the defrost plate is flipped up, directing air towards the defroster ducts/tubes?
I learned long ago to have a towel in the truck, along with a scraper.
Old 04-24-07, 08:19 PM   #3 (permalink)
Same here. I have a towel stowed away for this reason. I'm still debating if I should replace the fan assy. to one that performs better than the one that is currently on there.
fjwagon is offline   Reply With Quote
Old 04-24-07, 08:25 PM   #4 (permalink)
Poser's Avatar
Garage
Blower motor options/upgrades from the F A Q <---- this is a link
Old 04-24-07, 08:41 PM   #5 (permalink)
... gets you back
GetsUThere's Avatar
Does the fan come on when you turn it on?
Does warm air come out of the heater when pull "warm pull" and have the heater set to HEAT?
Does any warm air blow out of the defroster vents when you set the heater to DEF?
If the airflow is weak out of the heater and defrost vents but the fan runs and the air is warm, it's most likely bad (or disintegrated) foam seals. There is weatherstripping foam around the blower, both sides of the duct, and flat pieces within the heater on the flaps. As that decays, air leaks everywhere and it doesn't go where it's supposed to. You can get a kit from aatas1x if you need to replace foam in the heater or blower.
If the air blows but isn't warm after the engine warms up, you have a problem getting coolant to the heater or there's a bunch of junk that fell onto the top of the heater core (or both). If warm air comes off the bottom of the heater but not the defrost vents, the plastic tubes that go up to the vents may be missing or have fallen off the round lower part of the vent. Your heater's flaps also might not be flipping right when you move the control.
If the fan doesn't come on and no air blows, you have a wiring problem or bad blower motor.
Party like it's 1929
1977 FJ40, 1980 FJ40
GetsUThere is online now   Reply With Quote
Old 04-25-07, 04:28 AM   #6 (permalink)
Spud's Avatar
Untill I looked really close at the lever...I thought the control read: Heat/Vent/OFF....Then a few days later I realized it said HEAT/VENT/DEF.
* Make sure you have it on DEF and not OFF. (just being a wise ass).
On another note, the rain-X for windshield works awesome...They also make a product for anti fog-up, (may be called Rain-X anti fog?). Maybe try that out untill you can get it fixed mechanically.
Good luck...
Keep going,
Sam
"Is it being prepared to do the right thing, whatever the cost. Isn't that what makes a man?"
"Sure, that and a pair of testicles."
84' 4runner (work truck)
Nov / 76' FJ40 (work/fun truck)
80' Jeep J-20 Dump and Boom
Spud is offline   Reply With Quote
Old 04-25-07, 09:57 AM   #7 (permalink)
77cruiser's Avatar
defrost
Could have given more info, The blower works. When i pull the heat to high it blows hot air pretty strong but when i switch it to DEF(NOT OFF) it doesnt come out up top. On another note when i only pull it out half way there is not even a fraction of the heat coming out. sounds like there could be a clog of some sort.
Old 04-25-07, 08:52 PM   #8 (permalink)
I beleive when you pull it out half way, the circuit is using a resistor to slow down the fan. Pulling it all the way will speed up the fan(bypass resistor-located on top of fan) and turn the fan located behind the seats or if it like mine in the middle of the seats, under the console. May want to check for an "open" on this resistor. I have fixed this resistor in the past cus I'm a cheap bastard using "wire wrap". It's best to replace it but if attempt to fix it be careful not to change the value of the resistor.
Old 04-25-07, 10:39 PM   #9 (permalink)
CRWLNRX's Avatar
I had the same problem and found out that the hoses from the heater slipped off the hose mount under the dash which is under the defroster vents. Got new hoses mounted them (difficult to reach) and they work great.
The Colonel Mustard: 1971 350V, C&T Spring Over, High Steer, SM465, Discs Front & Rear, Locked Front & Rear, 488 Gears, Trac Bar, HD Skidpate, 17" Rock Crawlers, 37" Iroks
http://i44.photobucket.com/albums/f3.../FJ40after.jpg
CRWLNRX is offline   Reply With Quote
Old 04-25-07, 11:04 PM   #10 (permalink)
wesintl's Avatar
the other thing is sometimes the lever gets slop in it and doesn't close the flapper all the way. Reach under the heater and push it up or at least confirm it's closing all the way.
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
wesintl is offline   Reply With Quote
Old 04-26-07, 06:18 AM   #11 (permalink)
x2.
The 3 I've owned all had this problem when acquired.
Robert
64* 04' 37" N
144* 39' 30" W
1977 FJ40 - it's gettin there.
2000 Tacoma - CONDEMNED!! Thank you Toyota!
2006 4 Runner - for the
www.LongTrailAppraisal.com
VTFJ40 is offline   Reply With Quote
Old 04-26-07, 06:23 AM   #12 (permalink)
THC
Trollhole's Avatar
Garage
x3.
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
Originally Posted by grant5127 View Post
Having a motor that doesn't have enough power to pull a sick whore off the piss pot would be hard to ignore........
Old 04-26-07, 12:13 PM   #13 (permalink)
Also: Open the fresh air all the way.
igotta40 is offline   Reply With Quote
