Old 04-16-07, 07:13 AM   #1 (permalink)
2/40's's Avatar
Header/Exhaust removal & replacement
I'm pulling my header and exhaust pipe and the bolt that holds the mount in the middle (under the driver seat) is old and seized.. I'm thinking about cutting it off with my roto-zip.. are there any safety issues here?
Also, i have a new header gasket, should i be using some type of sealant between the new header & gasket?
Input! Need more input!!
2/40's is offline   Reply With Quote
Old 04-16-07, 08:56 AM   #2 (permalink)
blueticker17's Avatar
As to the first question I do not know. The header gasket does NOT take any sealent. I had to put 2 gaskets to stop my air leaks and it has worked flawlessly. I used Toyota parts. Do a search on exhaust gaskets and there is a lot of info. They helped me out.
Good Luck
blueticker17 is offline   Reply With Quote
Old 04-16-07, 09:20 AM   #3 (permalink)
2/40's's Avatar
Thanks blueticker17!!
Old 04-16-07, 12:12 PM   #4 (permalink)
Degnol's Avatar
And don't forget to retorque, retorque, retorque.
Ed
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
Degnol is offline   Reply With Quote
Old 04-16-07, 05:58 PM   #5 (permalink)
FineWynsFJ55
FineWynsFJ40's Avatar
Wait... 2 gaskets? Hmmm... I might wanna look into that...
Brian
~ Two paths diverged in the woods, and I, I engaged my front axle and took the path less travelled ~
1974 FJ40: Pandora's Box
1970 FJ55: Iron Pig
FineWynsFJ40 is offline   Reply With Quote
