Old 03-24-07, 10:08 PM   #1 (permalink)
Rookie
Angry 3B in BJ42 High Idle and White Smoke.
Hello All,
Need some help with my BJ42.
She is rough (to the point when I have to pull the remote idle knob out to reverse out of the driveway) at idle when cold and idles fast when hot.
Couple of other interesting observations.
Will bellow white smoke when in gear down hill after climbing.
Will not bellow white smoke when snap off accellerator pedal at 100kph, (so hill or load related).
Does not use coolant or oil.
White smoke does not smell like coolant.
Have replaced out EDIC with "better looking one".
Does seem to give off a bit of smake from crankcase ventilation pipe when idling high.
Engine has 365k on clock with head replaced at 280k.
Injectors done at 310k
Servicing done as per normal (oil 5K, filters and oil every 10k).
A mechanic at work has suggested dropped injector or rack return as possible causes.
Am yet to inspect condition of hoses on either side of throttle butterfly for cracks.
Please Help ???
81 BJ42 RV Blue and Oxide.
sebas is offline   Reply With Quote
Old 03-24-07, 11:30 PM   #2 (permalink)
Welcome Sebas. I would ask this question on the diesel forum, someone over there will most likely have the answer.
1983 BJ42
1978 FJ40-Sold
1975 FJ40-Sold
Diesel42 is offline   Reply With Quote
Old 03-25-07, 01:23 AM   #3 (permalink)
KOOTENAY KRUZER's Avatar
TLCA# 17298
I don't know about the white smoke, but when the diaphragm in your governor wears out and gets holes in it (and it will eventually) your idle RPM will go up very high and you will burn oil. probably not enough to make a noticeable increase in oil consumption but enough to make blue smoke (at least it looks blue to me) at idle or any time the throttle is closed. Especially going down hill on compression. It can be replaced on the vehicle without removing the injection pump, takes a couple of hours, you do have to remove the EDIC for access. It is best to study the engine service manual before you start.
Wayne
1983 BJ42, SOA, Shackle Reversal, 4.11 diffs, locker in rear, Saginaw power steering, 33x12.5s. 4-wheel discs
1979 BJ40, 3"lift, 1982 BJ42 drivetrain, Saginaw ps, 32x10.5s, Warn 8274 winch
2001 Echo, stock
KOOTENAY KRUZER is offline   Reply With Quote
Old 03-25-07, 08:00 AM   #4 (permalink)
sebas
Hole in diaphragm .White smoke is unburnt fuel from rack not fully returning .
Check your vacuum hose to pump first .
grumpy .
grumpy is offline   Reply With Quote
Old 03-25-07, 08:30 AM   #5 (permalink)
Zekester's Avatar
See my comments in the diesel section..
Zekester
SW Ontario, Canada
12/79 BJ40, 3B, 5spd, Gozzard F/G body, 3" lift, SS snorkle, 8274
M101 Expedition Trailer I/P, but in service
1983 BJ60, slowly whittling it down to nothing
1997 BMW 328is winter beater
1957 Porsche 356 replica I/P
Zekester is offline   Reply With Quote
Old 03-25-07, 08:51 AM   #6 (permalink)
too tall's Avatar
I agree hole in diaphram .
1977 fj40 All Beat Up ... But Still going strong !
1993 80 series
too tall is offline   Reply With Quote
Old 03-25-07, 10:57 AM   #7 (permalink)
Henry James the 47th's Avatar
Also, check to see if any of your injectors are loose. A loose one can suck air in and that will cause white smoke.
My 1982 HJ47 rebuild: http://forum.ih8mud.com/fj45-owners-...come-here.html
Henry James the 47th is offline   Reply With Quote
Old 03-27-07, 02:47 AM   #8 (permalink)
Rookie
The holy diaphragm makes the most sense.
Have ordered one and will fit this weekend.
Will post to update.
Thanks for your help everyone...
Sebas.
Old 03-31-07, 04:29 AM   #9 (permalink)
Rookie
Cool Diaphragm Fitted - Problem gone.
Yes the diaphragm worked a treat.
I was a bit cautious about f\dropping the split pin into the pump but survived and the old girl runs better than ever...
