Old 03-24-07, 08:53 PM   #1 (permalink)
starman's Avatar
fj40 spring replacement
I have a 78 fj40 that rides terrible that I am going to replace the springs on . I've been told to improve the ride (ie softer) I'll need to do at least a 2.5inch lift. I am considering safari 2.5 inch front and rear. Any thoughts? It's a daily driver with a little gravel and woods roads travel on the weekends. I'm looking for the softest ride for the last lift.
starman is offline   Reply With Quote
Old 03-24-07, 09:22 PM   #2 (permalink)
IH8MUD FREAKin' Addict
FF LC FREAK's Avatar
For a 2.5 inch lift, the best reviewed kits are from CCOT and OME. From what I have heard, Safari springs are somewhat stiff. There is also Alcan who will custom make your springs, but they are more money.
CCOT - http://coolfj40.stores.yahoo.net/liftkitfj401.html
OME - http://www.cruiseroutfitters.com/sus...ies_dakar.html
Alcan - http://www.alcanspring.com/
Good luck!
'71 fj40 capri blue - carb rebuilt and ported by 65swb45, vacuum advance w/ pertronix, SOR 2 piece header, Hell Creek 4" lift w/ homemade shackles sitting on BFG MT 33s, front disk conversion, H42 4 speed (wish it was an H41), Metal Tech rollbar (need to make it a family cage), Aussie locker in the rear, skull shifter knob , Heep bench seat in back. Lots of other mods...
ROTW
FF LC FREAK is offline   Reply With Quote
Old 03-24-07, 09:35 PM   #3 (permalink)
D'Animal's Avatar
Garage
Do you want to retaine the stock ride or do you want a 2 1/2" lift?
D'Animal is offline   Reply With Quote
Old 03-24-07, 09:37 PM   #4 (permalink)
toy4fun's Avatar
Garage
If you have stock springs now and nothing is broken I don't think changing to a lift spring will help soften the ride. There’s a lot of ways to get a softer ride but I don't think Safari lift springs will be helpful.
toy4fun is offline   Reply With Quote
Old 03-24-07, 09:57 PM   #5 (permalink)
Ndbbm's Avatar
Add a SR with the lift for a really nice ride.
79' fj40
2f, 4"po, photo elec ignition po,
Shackle reversal me
lots-o-mud me
Ndbbm is offline   Reply With Quote
Old 04-09-07, 09:37 PM   #6 (permalink)
starman's Avatar
Retain the stock height but improve the ride quality - so it rides smoother over bumps on the street.
Old 04-10-07, 07:53 AM   #7 (permalink)
Focus on the Journey
bsevans's Avatar
2.5" OME were a major improvement over the factory springs in my 78 FJ40. It was not until after I had replaced the springs that I saw just how much they had sagged. The 2.5" lift turned out to be closer to 3.5" due to the sad shape the factory springs were in. The ride was very much improved.
78 FJ40
ARB's F&R, Rear Disks, DUI HEI, 200 Amp Alt, OME 2.5, 33x10.50, PS, RE8000, Stout Rear Bumper, 4+Plus Sliders/U-Bolt Flip Kit/Tie & Relay Rods/Anti-Inversion Shackles, Dual Tanks, BTB Dash Box, Tuned Ceramic Coated Headers, Extended Axle Vents, BrakeQuip Custom Certified SS Brake & Clutch Flex Lines
ROTW My Yoda|HD Skid Plate|Recovery & Windshield Washer Tanks|Toyota Pulley on GM Pump|Bypass Hose|Vapor Recovery Tank
bsevans is offline   Reply With Quote
Old 04-10-07, 03:45 PM   #8 (permalink)
I bought stock replacement springs for a 60 years ago from M_A_F_ and they sagged immediately. This was a daily driver, and they wanted me to send them in for evaluation, which I couldn't do. I took the truck to a local spring shop (Black's in Zanesville Oh) and they laughed at the steel the springs were made from. They re-arched them for me and added a leaf for about 1.5" of lift. After that they rode awesome. Black's said they could have built new springs for less than I paid and do all the labor (stuck, frozen parts, etc.). I have since installed two OME Dakkar kits and totally pleased with the quality. My 40 needs weight to be considered smooth (still no Cadillac ride). I am considering removing a leaf (leaves) when the hardtop comes off, should make for a smoother ride -and better articulation-. You may be able to remove leaves to soften, but may lower your ride height as well. Where is your truck from, where has it been- shackles may be rusted & not moving. Don't be afraid to flex.
If I wanted a stock ride I would have new springs built locally. OME Dakkar is reasonablly priced and I'm pleased with the quality. If I was rich or just wanted to go bigger I would totally go with Alcan.
mmmahhmatt is offline   Reply With Quote
Old 04-10-07, 07:57 PM   #9 (permalink)
Sorry to hyjack but what leaf would you remove to make for a smoother ride and better articulation? I have OME springs but want it to be a little softer and dont' really care about losing an .5" of height.
Thanks, Scott
Nasty Looking 1971 FJ40, Chevy 350, Orion, NV4500 5-Speed,
Chevy (Saginaw) Power Steering, Tilt steering,
4 Wheel Power Assist Disk Brakes,
4" lift, Alcan custom springs
sfrolich is offline   Reply With Quote
Old 04-11-07, 07:45 PM   #10 (permalink)
I've seen threads on this here @ mud. I think to remove bottom two leaves on OME rear, they are 'helper' or overload springs. On the 60 it is third up from bottom that goes.
try these:
Dakkar springs
Ride way too harsh
Old 04-11-07, 09:48 PM   #11 (permalink)
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
Hi All:
I've been running the OME suspension on a FJ40 since 1998. I have a 2F and an electric winch over the front axle so are using the medium-load OME13 front leaf springs, but found that the medium-load OME14 rear springs had too high of a load rating for my truck with no top or a soft top. Removing the third leaf from the top of the spring pack changed the load rating to "light-load" status (aka OME140.)
Be sure to PM me if you have any furthre questions.
Regards,
Alan
Thanks, Scott
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
"The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
Josie'sLandCruiser is offline   Reply With Quote
