03-22-07, 12:35 PM
Dizzy change, ignition coil too?
I just got a 76 dizzy w/ vacuum advance, an upgrade from a 9/72 with retard. My question is SOR says that if you buy their non-USA dizzy (retard to advance) that you need to upgrade your coil. Does this apply to this 76 dizzy? Will I need a coil from a 76 or can I just hook it all up as is? I think I should be fine, but just making sure. Also how important is it to change the clamp?
73 FJ40 rusting as we speak
03-22-07, 01:46 PM
I personally would put a new coil in place. If the coil is a Toyota, it should fit the clamp ok. Remember, the clamp is to be grounded to the block, fender and firewall for optimum ignition. The older coil may not be designed for 12 volts and require a "ballast" resistor (0.8 ohm); which would be eqpt on a 1972 FJ40. Oddly enough, my old stock coil on my 1980 [90919-02083] is labeled "use with external resistor"; which I don't have.
My system is a mallory points distributor with Jacobs computer system and coil.
Never hurts to have a few extra ignition parts around.
Tech information:
http://www.ih8mud.com/cruisertech.php
Dist info:
http://www.ih8mud.com/tech/dist.php
http://www.rzeppa.org/tech/jimcdist.htm
D.F.Morse
1994 FZJ80 Kazumatized 74000 mi
1979 FJ-40 74000 mi
Here endith the lesson
03-22-07, 10:17 PM
I guess my question is now: What coil? and do I just need the coil or do I need the whole set up from a 76-77?
03-23-07, 12:43 AM
elder statesman
Do you have a picture of the distributor? it might help.
SOR generally sells an 'early' vacuum advance dizzy, which is the same kind Downey and I sell as well.
Those distributors will work fine with your stock 72 coil.
Best
Mark A.
A carbureted man in a fuel injected world.
65SWB45, 64LWB45, 68FJ40,72V840, 76HJ45[gone],84FJ60[gone], 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
TLCA delegate, Trail Crew-LAC TLCA, The White Trash of the Elwood Chapter
my website:
http://www.marksoffroad.net
IT'S FASTER if you CALL ME!
03-24-07, 12:21 PM
Heres a picture
It's a late 76, other then that the part number is 2F in one box and 2U2 4 in the other.
03-24-07, 12:53 PM
This is the coil I'm using; been in service many years.
http://www.jacobselectronics.com/
http://go.mrgasket.com/pdf/jacobs_coils[1].pdf
Energy Coil . . . . . . . . . . . . . . . . . . . . . . . . . . . . . #380672T
D.F.Morse
1979 FJ-40 74000 mi
03-24-07, 12:56 PM
Cruiser Curmudgeon
Originally Posted by Tatunka
Heres a picture
What makes it a late '76?
Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's  since 1988.
03-24-07, 02:28 PM
You...
"75 & early 76: small distributor, completely redesigned, very good quality points distributor. Vacuum retard.
Late '76 &77: Same, but w/ vac advance" -JimC
03-25-07, 03:01 PM
Cruiser Curmudgeon
That looks like the 74-earlier style dissy.
Thanks,
Jim C.
TLC Performance
03-25-07, 03:59 PM
#10 (permalink)
The reason I thought that it was a 76 was the person I bought it from said it came off of his 76 2F. If it is something different please tell me as I am not well versed in distributor types, which is why I am glad to see you (JimC) taking a look. It is for a 2F, but maybe non-USA? I can get part #"s if needed. Thanks for taking the time.
03-25-07, 04:03 PM
#11 (permalink)
That could be a 69 vacuum advance just like the one that came off mine.
Where am I, and who are these people????
03-25-07, 05:46 PM
#12 (permalink)
The coil you have will work fine if it worked with the old distributor. If it has a ballast resistor, use it; if not don't.
03-25-07, 07:25 PM
#13 (permalink)
 WTF, thats what I get for not asking you guys what it was before I bought it. Well at least it's vac advance, that's what I was looking for. Thanks for asking all my questions. So with this information (year of dizzy) I should just leave everything just how it was and install this dizzy, right?
