Old 03-13-07, 10:40 PM   #1 (permalink)
1973Guppie's Avatar
Gas tank pressure, how much is normal?
Was driving the FJ40 tonight and I noticed quite a bit of pressure coming from the front tank when I went to fill it up at the station. I had just finished coming down a large, long hill for about 25 minutes, probably a 1000 foot drop of elevation. I am trying to figure out if after a drop in elevation like this, is it normal to have some pressure built up in the tank? OR should the charcoal/vent system take care of this completely so you have no pressure in the tank? I have the tank routed correctly, I am sure of it. I am using the stock 73 FJ40 fuel separator and it is routed to the stock chevy charcoal canister and then to the engine so the available vapors can be used (the stock chevy canister has markings for each port and where they go). The only change I have made is to pull the beisch fuel filter looking thing which I believe allows vapor to pass but not gas, I replaced this with a piece of metal fuel line. The truck drove fine, so not worries there, and I did not really get any in cab fuel vapors but was wondering how much pressure is normal. I did notice that the vented cap I have mentioned to open slowly as fuel pressure can cause fuel to spray. Anyhow, any opinions appreciated.
Noah
1973Guppie is offline   Reply With Quote
Old 03-14-07, 10:54 AM   #2 (permalink)
1973Guppie's Avatar
bump, anyone, or am I just a retard?
WWW.WAGONRACKS.COM
Rack Info: http://forum.ih8mud.com/merchandise-...ml#post5145037
NEED A CRUISER MECHANIC?:http://forum.ih8mud.com/ca-san-diego...rlsbad-ca.html
1973 FJ40 - Vortec/NV4500/ARB's/SOA, 1970 FJ55 - Resto project, 1996 FZJ80 - DD
FJ55 Restoration Thread: http://forum.ih8mud.com/showthread.php?t=102079
FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40
Old 03-14-07, 11:12 AM   #3 (permalink)
FJBen's Avatar
OCD?
sorry I have nothing to add about how much pressure is normal
FJBen is offline   Reply With Quote
Old 03-14-07, 11:38 AM   #4 (permalink)
what he said
Mace's Avatar
The tank should be vented. So no pressure buildup if it is performing properly.
If you do not have a vent on the tank. A significant increase in ambient temp + a full or near full tank can actually fill your motor up with fuel..
I am kinda gay.......
I've set the bar, don't trip over it....
Old 03-14-07, 12:38 PM   #5 (permalink)
many times when filling up a near empty tank I also hear a rush, but seems to be more of a vacuum situation. I am not sure why the vents would allow this to build up
I wonder if...next time, you were to unplug your hose to charcoal canister.... or at the valve whether it would depressurize.
I remember the one way valve, that looks like a fuel filter, that is in-line to canister, after the separator, being confusing to me... not really understanding why it needed to be there...maybe to keep water from getting in the fuel in high water???
jm599 is offline   Reply With Quote
Old 03-14-07, 12:46 PM   #6 (permalink)
Colorado Boy-74-FJ40's Avatar
I drilled a hole in the gas cap on mine!
4 Chevys and a Yota
1994 4X4 Silverado pickup
2000 S-10 pickup
2000 Monte Carlo SS
2003 Trailblazer LTZ
and a little old 1974 FJ-40
Colorado Boy-74-FJ40 is offline   Reply With Quote
Old 03-14-07, 12:53 PM   #7 (permalink)
what he said
Mace's Avatar
Good idea until you have a off camber situation
Old 03-14-07, 01:04 PM   #8 (permalink)
Strait Cruisin's Avatar
The idea is that when a sealed fuel tank pressurizes, it pushes fumes into the charcoal container where it is stored until purged by a dump valve after start up (works off ported vacuum so it doesnt just gulp a bunch of air and die). Having the canistor is a good thing, IIRC, it can store up to a cup of fuel. On the down side you have fuel pushing against the float valve and fuel line connections. Some smog checks look at your gas cap too and how many HC's you are leaking there.
Strait Cruisin is offline   Reply With Quote
Old 03-14-07, 02:46 PM   #9 (permalink)
1973Guppie's Avatar
so for what it is worth, I have a vented gas cap AND I am sure that the tank is vented properly. According to the description above, isn't it possible that enough pressure built up quickly enough from me coming down in elevation that the purging system did not have enough time to vent the pressure buildup? If it doesn't just gulp a bunch of air then I would guess that some amount of pressure would be normal when coming down some in elevation? I will have to test it a few more times to see if it continues to happen.
Noah
WWW.WAGONRACKS.COM
Old 03-14-07, 02:50 PM   #10 (permalink)
what he said
Mace's Avatar
If it builds pressure it is not vented..
1000' is not that much elevation change.
Old 03-14-07, 03:15 PM   #11 (permalink)
stumpy's Avatar
and if your tank isnt vented, you can split your tank at the seams. trust me.
check your carbon canister and your evaporative control box. the later 40 evap box had a vent to fresh air too.
when your day just doesnt go quite as planned...
www.machinegunarmory.com
stumpy is offline   Reply With Quote
Old 03-14-07, 03:31 PM   #12 (permalink)
Not too bad
I had it nearly 30 degrees withe a pretty full tank and it leaked a little but not too bad. Anyone with a 40 knows they don't stay full for very long!
4 Chevys and a Yota
2000 S-10 pickup
2000 Monte Carlo SS
Old 03-14-07, 03:39 PM   #13 (permalink)
1973Guppie's Avatar
something must be going wrong then, I will check back through everything (lines, canisters, etc) and post back up. Do the charcoal canisters go bad? Does the evap emmission fj40 stock thing amajig go bad? to the point where they won't pass air/fuel? and how long do they usually last?
Noah
WWW.WAGONRACKS.COM
Old 03-14-07, 05:30 PM   #14 (permalink)
Carbon canisters usually have some sort of filter on them or draw from the air cleaner. They dont draw air (or should not) from the tank itself when running (you'd be doing the opposite of lowering the pressure in the tank from ambient) GM's, for example, have a filter pad on the bottom of the canister (stick your fingers under one sometime). Yes they do go bad (dust and dirt usually) but check for collapsed hoses, operation of the purge valve, etc.
Old 03-14-07, 08:39 PM   #15 (permalink)
Smile
Maybe taking the line off @ both ends & running some air thru it ???
John
FJx3
75 FJ40 purchased new basically stock
85 FJ60 complete OME 33x10.50 muds 260K still daily driver
89 FJ62 just turn 100K completely stock
John McVicker is offline   Reply With Quote
Old 03-14-07, 10:07 PM   #16 (permalink)
KOOTENAY KRUZER's Avatar
When you come down in altitude the ambient pressure increases so the tank would show a relative vaccuum if it was still at the pressure of the higher altitude, also the engine removes fuel from the tank, these two would combine to give you a vacuum in an unvented tank, not pressure. Also eventually the engine would quit because the fuel pump couldn't pull fuel against the vaccuum.
Wayne
1983 BJ42, SOA, Shackle Reversal, 4.11 diffs, locker in rear, Saginaw power steering, 33x12.5s. 4-wheel discs
1979 BJ40, 3"lift, 1982 BJ42 drivetrain, Saginaw ps, 32x10.5s, Warn 8274 winch
2001 Echo, stock
KOOTENAY KRUZER is offline   Reply With Quote
Old 03-14-07, 11:36 PM   #17 (permalink)
FJFOOL's Avatar
I was concerned about this also, and determined it was indeed vacuem, not pressure. I'm wondering if the vented cap I have is like a one way valve, letting air out, but not in as fuel level is depleted? Just a thought, haven't gone farther than that.
FJFOOL is offline   Reply With Quote
Old 03-15-07, 01:18 AM   #18 (permalink)
scouthead's Avatar
My '76 fj55 builds up pressure in the tank also. A few times it has actually projectile vomitted about a pint of gas onto me. And that was after filling the tank, driving a few gallons out of it, and THEN it belched gas out when I went to top it off and check milage...I have checked and all lines are clear, can blow air in and out of canister easily, replaced fuel filter looking vapor seperator-no change (and yes it's in the correct way), exhaust is not too close to tank, etc.
But even if something isn't working properly, where is the pressure coming from? I could understand a vacumm, but what could possibly be pumping pressure into the tank? A coup[le of times it's been bad enough that I've worried about the tank splitting or leaking...WTF !!??????
I've chosen to ignore the pile of receipts...but I know it's growing...
scouthead is offline   Reply With Quote
Old 03-15-07, 10:45 AM   #19 (permalink)
1973Guppie's Avatar
I have a vented gas cap as well, not sure if the vented caps allow only air OUT and not IN? I think for me it was probably vacuum as well, but not sure. Either way, vacuum or pressure, it should be equalizing if the system is vented correctly. Something must be wrong in my system. I am thinking it is somewhere in the engine area, charcoal canister or ?, I may pull the canister and leave an open line in the engine bay for venting and see what happens.
Noah
WWW.WAGONRACKS.COM
Old 03-15-07, 11:23 AM   #20 (permalink)
camcruiser13's Avatar
where did you get your vented gas cap?
i think i need one
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
DIY Beadlocks
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
