05-05-07, 05:00 PM
#31 (permalink)
ps: fwiw, i noramlly replace the stock breather setup with a barbed 90 deg fitting in order to run a breather line to the firewall so water can't get in there.
pretty simple mod and fairly effective.
05-06-07, 09:47 AM
#32 (permalink)
I'm guessing that one is goin behind something that uses a stub shaft ?
John on the hawgs
05-06-07, 11:01 AM
#33 (permalink)
yeah, i built that one for jeff, one of our fellow pmc members. going behind a 465. i also built him a set of twin sticks for it. if you would have come to the swap meet, you could have seen it in person. he picked it up that day. just in time for rubithon.
05-17-07, 05:18 PM
#34 (permalink)
Orion #342 --4:1 gears. No idea on the thrust washer. Mudrak built it. New output shaft
Ross Woody
TLCA Secretary - Member #7704
72 FJ40 - ORION #342 ROTW 10/6/08
07 TRD FJC
05-21-07, 12:11 AM
#35 (permalink)
Unknown serial number. Got it about a year ago. Shift rail works great. Hasnt ever popped out.
05-21-07, 12:46 AM
#36 (permalink)
Pics of Orion
05-21-07, 09:13 AM
#37 (permalink)
Looks like #264
Ross Woody
07 TRD FJC
05-23-07, 01:53 PM
#38 (permalink)
some college
#20243,
Installed by PO,
Chris
"If you could kick the person in the pants responsible for most of your trouble, you wouldn't sit for a month. " Theodore Roosevelt
1976 FJ40, Stereo by Euclid, Team Risher Metal Tech Family Cage, Tuffy consoles, 4inch Hell Creek , Saginaw Psteering, Cluthee sliders, IPOR Skid Plates, ARB Lockers stem & stern, Orion, ridin on 31575-16 BFG KM2 and Teflon Mojaves.
1994 FJZ80, Locked, OME heavies, ARB bumper, IPF, 31575-16 Firestone Dest. MT, snorkel, Metal Tech sliders,Warn M12K, 1/2 inch synthetic rope, Stereo by Euclid, Dual Optimas, drawer system , Iron Pig swing out & skid plates
2005 Chevy Z71 4WD Suburban, 28570-17 Duelers
2006 Honda Civic (DenMomDeb's sled), Bridgestone Serenity
05-23-07, 04:29 PM
#39 (permalink)
that sounds awful high.......
05-28-07, 07:54 AM
#40 (permalink)
#115 awaiting upgrades kit from AA. It will be replacing my Marlin case #26 in the next couple weeks.
"j**ps make great...traction!"
Kevin ehrlick tlca #3Ř07
rising sUn
stay on the trail
louisville, colorado B
'64 fj-40 (wild rice), '97 fzj-80 40th aNniversary (ricecake)
ST. FUAW!
05-28-07, 08:37 PM
#41 (permalink)
GCLC President
Originally Posted by cruiserhead
Case #356,ratio 4.1,cut back gears,stepped thrust washers,new shift fork,shaft,ball,spring.Recieved this a week ago,have yet to install it.
Tested the new case at GSMTR.No problems,except when I did not have the t-case shifter all the way in 4 hi.
David
1971-80 FJ40 Hey,I used what I had.Trail and plow truck.
`05 Trailblazer, wifes DD,`05 GMC 2500HD SLE Extra Cab 4x4 Cruiser Hauler,`95 Kawasaki Vulcan 1500
www.gclcny.com
Installer of Metal Tech products
Crum`s Custom Welding,LLC ccw1@optonline.net
Bumpers to roll cages,FJ40 skid plates-fits stock 3,4 speed & Orion trans and transfer case combos.1 year in development and Telico tested
05-30-07, 09:15 AM
#42 (permalink)
Dain Bramaged Member
#211
I believe it was the first one AA modified to work with a toy box.
The first attempt I had problems keeping it in low and high range.
AA provided me with the new shift rail/detent ball/spring, no real improvement.
Third try AA sent the back cut gear and stepped thrust washers. This cured the high range problem.
Fourth try, I talked to Mike (AA GM) at Cal4WD expo. We arranged for me to drop my case at one of AA's distributors in Auburn. Mike picked it up there and took it to Moab then back to the factory where Randy went through the whole case. (My T-case has been to Moab put neither me or my 40 have, how sad is that?)
The jury is still out but so far I have only had the case come out of gear once in low range. This may have been a linkage issue. Next week we are going to do the Barney Riley trail which should tell the tail.
Performance issues aside I have to say that it has been a pleasure working with AA. Their customer service is some of the best I have encountered anywhere. Every product will have problems at some point, how the vendor handles them is what makes the big difference. IMO AA has done a great job in my case.
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
05-31-07, 08:07 AM
#43 (permalink)
Beagles Rule!
Originally Posted by rusty_tlc
#211
I have #318 and it only pops out on really long down hill decents using the engine as a brake and only when in 4 Low.
06-02-07, 05:38 PM
#44 (permalink)
# 227
Transfer pop'd out twice going down hill in 4-hi. Called AA and got the kit with the shaft and washers but haven't had a chance to install. I have installed the twin stick shifter , stock one was shot , no more popping out for awhile but now it is doing it again . I will just take it to AA and have them fix it with gear etc. A little set back but still would not trade it . Love those low gears.
06-08-07, 08:12 AM
#45 (permalink)
Orion #367 installed behind an H42.
Built by LCR4WD (poser)
Reused main shaft and shift collar from 1979 transfer case, as they appeared to be in very good condition.
Steeped thrust washers were not needed, and gear free-play with the bearings pressed on the shaft was at .008” for the high-speed gear and .009” for the low-speed gear.
Orion case had a setscrew to retain the provided new shift shaft as was posted up earlier.
Main bearing preload was set at 15”#’s.
couple 40's, a troopy, and a 45 lpb waiting for love
07-02-07, 06:27 PM
#46 (permalink)
Rookie
Case#256 4:1
Popping out of high and low any speed any gear . Installed new shift rail, ball, spring and brass set screw. Seems to have helped the popping out of low but still popping out of high. Donor case was a freshly rebuilt 4spd. Georg at Valley Hybrids built the orion for me. No new cut washer. Right now I am really frustrated with this set up. I hope I can iron it out. Any input and help would be greatly appreciated.
Anyway when I installed the new shift rail and associated parts I noticed that the shift fork didn't seem to seat all the way down onto the synchro shaft sleeve.
Anyone ever experienced this?
Thanks for reading
Josh
07-02-07, 07:00 PM
#47 (permalink)
Oh...Durka Durka Durka.
Originally Posted by fgr55
#256
No new cut washer.
Because it did not need it or the stepped washers did not come in the kit?
The shift fork is not going to be resting on the range shift collar, but rather, suspended in the groove on the collar.
What is the condition of and style/type of transfer case control linkage, and are you positive that the control linkage is not contacting the body or something else is not causing the case to be kicked into neutral?
07-03-07, 07:54 AM
#48 (permalink)
Case#256 4:1
Thanks for reading
Josh
yup, i built that case amongst others. it is an early case. i reused the synchro slider (collar) and shaft since they were in great shape. the freeplay between the high and low gears was well within specs. i don't recall the exact measurements.
the last case i built was #357 and it came with the cut washers. i was not bale to use them because they ended up with no freeplay at all and the gears bottomed out on each other, causing them to bind.
i'm waiting for pics from josh to see what's going on with the shift fork and collar. i do not think it's the problem. i think the case might have to be updated to the cut gear and possibly the washers depending on the clearance.......
either way, i will stay in contact and make sure this gets resolved even though the case was not purchased thru me or from me. it was one of the main prizes at rubithon a couple of years ago. gark aka mudrak donated it to the raffle!
07-03-07, 08:39 AM
#49 (permalink)
#211
An update. We've did Barney Riley and Deer valley with no further problems. Rubicon in two weeks so I have my fingers crossed.
Dan Johnson
Rust never sleeps.
07-03-07, 12:51 PM
#50 (permalink)
Quick question for you all. My Orion did a weird sound the other morning when heading down the road. It almost sounded as if the bearings or the bronze washers on the idler ends ran dry momentarily...eery sound, but it immediately went away. Case has been great since the back cut gear, washers and new shift rail stuff, zero problems. I'm running straight 90W in it..anyone else have that anomaly happen to them??
Cheers!
78' FJ40,SBC,35's,SR,PS,Lifted SUA,Orion#2, Aussie rr, RDB.
"No electrons were harmed for this post, just re-directed a tad"
07-03-07, 02:04 PM
#51 (permalink)
Josh, double check the preload. When we did my orion it went together with three shims first try and was a little tight , took all three out and it was fine for a little while then it loosened up and needed 1 shim. I think the race was not seated 100% prior to assembly but got pushed in when I used 3 shims.
If thats good then take a look at the lock tab that holds the hi-lo shift rail at back of case. My tab was not flat, it looked stamped and had a little offset to it. Like 2mm maybe. Not a big deal but when put in one way it caused the hi-lo shift collar to rub the dogteeth on the low gear when in nuetral, reverse tab and no more rubbing the dogteeth.
John on the hawgs
07-24-07, 10:10 AM
#52 (permalink)
#211
Back from the Rubicon, no issues with the Orion, except me wetting myself every time I used it ( it tickled the piss out of me  ). Both the Orion and Toy Box are still noisy as all hell in low but no more than I would expect from new gears. High range was the same before I got a few miles on them.
Use of the two boxes was split about 45/45 on the trail. The other 10% was stuff I used stupid low for. All combinations worked great, except stupid low reverse, that goes beyond insane.
Dan Johnson
Rust never sleeps.
07-25-07, 05:09 AM
#53 (permalink)
Dan, did AA say what they found that let it pop out of low into neutral?
'77 FJ40: HFS, 33's, Locked and Low'd
07-25-07, 08:58 AM
#54 (permalink)
Randy wrote a list of stuff he replaced. I don't remember all of it off the top of my head but I'm sure I kept the note. I can try to dig it up if you want. IIRC the main thing he did was replace the shift lever, I'm not sure the correct terminology, the one that connects the external linkage to the internal shift yoke. It may have been worn enough to not fully engage the yoke. Or there may have been some slop in the external shaft from the flats getting worn.
Dan Johnson
Rust never sleeps.
07-26-07, 06:09 AM
#55 (permalink)
Beagles Rule!
Steve (aka Poser) listed up every thing needed to fix it.
I'm just not up to pulling my rig apart in the middle of wheeling season.
07-26-07, 10:21 AM
#56 (permalink)
It only takes a day to R&R Orion (if you've done as many times as I have lately).
I hear ya though, if the last round didn't fix my problems I wasn't going to screw with it again til next winter.
Dan Johnson
Rust never sleeps.
08-04-07, 12:33 PM
#57 (permalink)
Green 73 and chattfj40,
How do you like the H41 and Orion 4:1 combo? I'm considering it over an SM420 to three speed stock case.
'85 PU, 4.88s, ARB front, Detroit rear, 4.7 single case (for now), Budbuilt, 33" Swamps, 63" Chev rear springs
'74 FJ40 flogged nag
'76 FJ40 stocker resto candidate
'78 FJ40 destiny unknown
'81 FJ40 rebuild under way
08-06-07, 02:44 PM
#58 (permalink)
#373 4:1 ; mated to an H41 in H42 case 81:1 final ratio
Used stock thrust washer, as stepped washer didn't allow proper clearance.
Backcut HS gear and AA supplied shift rail: very stiff right now.
08-08-07, 12:18 PM
#59 (permalink)
What are you guys using for a cross member? Or are you using a cross member at all? I've got the AA propeller style but not the mounting hardware. I might ask treeroot to make me one like his. Not sure. What's everyone think?
08-08-07, 02:00 PM
#60 (permalink)
Great combo with a 2F. The H41 shifts easily w/ good spacing and at 80:1 usually the tires will slip before the engine drops to far below idle. I would do it again.
HTH,
Gary
