If I get a full Floating FJ40 or FJ60 rear Axle Housing, will my existing FJ40 3rd member with an ARB (from a semi floater) work with in the full floater?
"The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
And the reason for the three spider gears is so that there can be an opening in the ARB unit to get to the c-clips used to retain the axle shafts in semi-float applications.
You will put the thrust block pieces, spider gear pinion shaft and retainer in the same way and locktite the retaining bolt for the retainer. Then just install the third into the full float axle housing.
