LinkBack (8) Thread Tools Display Modes
Old 02-12-07, 11:49 PM   8 links from elsewhere to this Post. Click to view. #1 (permalink)
1973Guppie's Avatar
Minitruck Front Axle Disc Brake Conversion For Dummies (FAQ)
So after doing my front axle Minitruck conversion I decided that I would do a tech thread outlining the process. There are many on here but I felt none I found had enough pictures. So if you have dialup, youre screwed, cuz there are going to be a lot of pics here, hopefully the mods don't delete my membership cuz I crashed their server,
I don't plan on putting a lot of wording in this thread, I hope the pictures explain themselves enough. I would reccomend anyone to read up on every thread they can find as it helps with the overall picture.
I used this excellent thread to do a step by step of the process,
http://www.geocities.com/Baja/Dunes/6948/
I printed it out and followed it to put the axle back together, along with a printout of the pics I took of the breakdown of the axle, with these 2 things the conversion was fairly easy.
Parts List:
for axle seals, bearings, etc, just call Kurt at cruiser outfitters, he will tell you exactly what you need, will have it and has fair prices.
I found all my hard parts at Kragen, your local store will match the kragen online store's pricing, which many times can be half of what it is when you walk in! so shop around and save some serious $$. Also, if you look at the weekly specials online they usually have nice coupons for stuff like brake cleaner, towels, etc. part #'s are kragen #'s and can be seen at www.kragen.com
RC3190 - Loaded Caliper
9838RGS - Rotor
I guess that's it, hope this helps someone and please correct me when I am wrong or involve your input for everyone's benefit.
first part will be axle teardown, 2nd will be buildup
Noah
3rd pic - snap rings being removed, get some snap ring pliers at local sears!
1973Guppie is online now   Reply With Quote
Old 02-12-07, 11:53 PM   #2 (permalink)
1973Guppie's Avatar
pic 1 - get a brass drift, you will need it! hit around and on the studs to release the hub
pic 2 - hub off
pic 3 - outer nut off, use screwdrive to bend tabs back on the star lock washer, you will need hub socket as well
WWW.WAGONRACKS.COM
Rack Info: http://forum.ih8mud.com/merchandise-...ml#post5145037
NEED A CRUISER MECHANIC?:http://forum.ih8mud.com/ca-san-diego...rlsbad-ca.html
1973 FJ40 - Vortec/NV4500/ARB's/SOA, 1970 FJ55 - Resto project, 1996 FZJ80 - DD
FJ55 Restoration Thread: http://forum.ih8mud.com/showthread.php?t=102079
FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40
Old 02-12-07, 11:57 PM   #3 (permalink)
1973Guppie's Avatar
pic 1 - hub nuts off
pic 2 - caliper off, 2 bolts on back of knuckle
pic 3 - pull washer and outer bearing out
WWW.WAGONRACKS.COM
Old 02-13-07, 12:00 AM   #4 (permalink)
1973Guppie's Avatar
pic 1 - pull hub / rotor assembly off
pic 2 - unbolt disc brake shield
pic 3 - remove shield and seal
WWW.WAGONRACKS.COM
Old 02-13-07, 12:02 AM   #5 (permalink)
1973Guppie's Avatar
pic 1 - remove spindle
pic 2 - remove birf and inner axle
pic 3 - remove tie rod, need a pickle fork and a BFH!
WWW.WAGONRACKS.COM
Old 02-13-07, 12:03 AM   #6 (permalink)
1973Guppie's Avatar
pic 1 - take a brass drift and hit the wheel stud hard with a BFH, this will knock the cone washer loose
pic 2 - take off your shims underneath the steering arms carefully! mark them as noted for proper orientation back on the LC axle, I used this method which from my research others have had good success with and it turns out my knuckle preload turned out perfect using the fishscale method
pic 3 - remove backside wiper stuff
WWW.WAGONRACKS.COM
Old 02-13-07, 12:08 AM   #7 (permalink)
1973Guppie's Avatar
pic 1 - pull off knucle, should fall right off
pic 2 - step on knuckle and remove bottom plate
pic 3 - note placement and orientation of bottom shims as well.
WWW.WAGONRACKS.COM
Old 02-13-07, 12:11 AM   #8 (permalink)
1973Guppie's Avatar
pic 1 - pull out seal and bearing from rotor/hub assembly
pic 2 - pound out old races from hub assembly, use a brass drift, there are little spots inside of the hub that are meant to pound on, look for them. *caution, the surfaces inside of all these parts are sharp and can cut so pay attention. there may or may not be 2 nuts holding the rotor to the assembly, remove these and the rotor will come off.
pound out old lug studs with a BFH
WWW.WAGONRACKS.COM
Old 02-13-07, 12:15 AM   #9 (permalink)
1973Guppie's Avatar
pic 1 - here is what you are left with
pic 2 - the drivers side steering arm will need to be cut if you are going to use it, if going SOA go with a high steer setup, marlin sells a great kit and he is a great guy
pic 3 - finished product, you just need to basically chop it at the back of it and remove the bent part that won't be used.
OK, SO I AM TIRED, THIS IS THE END OF THE BREAKDOWN PART, WILL WORK ON THE BUILDUP TOMM, GOOD NIGHT,
WWW.WAGONRACKS.COM
Old 02-13-07, 12:18 AM   #10 (permalink)
jrfj40's Avatar
WOW great job very infromative keep it up
1972 FJ40
TLCA #16396
"you can run all your life and never go anywhere"
jrfj40 is offline   Reply With Quote
Old 02-13-07, 01:28 AM   #11 (permalink)
Coolerman's Avatar
Marked for future reference! Glad to see more good folks taking the time to share their knowledge.
!Oy my 1971 FJ40
It's not having what you want, it's wanting what you got...
http://tinyurl.com/ygeqfp7 FJ40 Wiring Parts for Sale
http://tinyurl.com/mxj5ve Misc Parts FOR SALE!
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 02-13-07, 02:03 AM   #12 (permalink)
numtel's Avatar
Why would you bother pulling the bottom plate off the knuckles?
numtel is offline   Reply With Quote
Old 02-13-07, 08:26 AM   #13 (permalink)
great info waiting for the rest
noc231073 is offline   Reply With Quote
Old 02-13-07, 09:22 AM   #14 (permalink)
1973Guppie's Avatar
just the way I did it, you are correct, you could leave it on, I cleaned and painted everything though so thought it was a good idea. if you were to just swap everything dirty (which you could) then leave it.
noah
WWW.WAGONRACKS.COM
Old 02-13-07, 09:51 AM   #15 (permalink)
Supporting Vendor
cruiseroutfit's Avatar
I would always pull it off... not only so you can clean it & inspect the shims (possible re-shim depending on pre-load measurements), but also to make sure the studs are tight in the knuckle housing.
Kurt Williams
Cruiser Outfitters - YOUR LC PARTS SOURCE!
OME - ARB - AA - Safari - Helton - Engel
ExpeditionUtah - A lifelong project of exploring Utah
U4WDA
TLCA
Wasatch Cruisers
Mountain Yoats
Red Rock 4 Wheelers
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 02-13-07, 10:08 AM   #16 (permalink)
Wildman's Avatar
Can you give us the make/model on those part numbers? The min truck guys (being one myself) usualy use an IFS caliper with mid 80's FJ60 rotors this gives you a vented rotor with the 4piston calipers without using spacers, etc.
I am inthe progress of this swap myself and wonderd if all the stuff clears stearing componets, rims, etc.
heres the POR FAQ link: http://www.pirate4x4.com/forum/showthread.php?t=459180
People dont get it, theres no blank spots on the map anymore, anywhere on earth, if you want a blank spot on the map, you gota leave the map behind...
Build thread: updated 2/23
http://forum.ih8mud.com/showthread.php?t=169539
Wildman is offline   Reply With Quote
Old 02-13-07, 10:52 AM   #17 (permalink)
1973Guppie's Avatar
search for the p # on kragen.com, it will give you all of the applications it fits, which I believe are land cruisers and some other toyotas.
I had to switch from stock drum brake rims to stock disc brake rims, fit just fine now. drum brake rims will not work though.
Noah
WWW.WAGONRACKS.COM
Old 02-13-07, 01:55 PM   #18 (permalink)
In the garage
John Smith's Avatar
This is going to be a very helpful thread! Once you are finished you should have all these types of comments removed and have it locked and put in the FAQ.
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 02-13-07, 02:01 PM   #19 (permalink)
1973Guppie's Avatar
Front Axle Buildup
So the following is the step by step of the axle buildup. Some comments on the in between the breakdown and buildup. If I were to do this again, I would take all that greasy crap that came off of the minitruck axle and send it to a hot tank. By far the hardest part of this whole conversion was the cleaning of everything by hand and buckets of kerosene. Dirty, smelly, and probably not that healthy for you. Again, I really reccomend just taking all the knuckles and main parts to a shop with a hot tank. The bolts and such can be just left in a can of kerosene and will clean up just fine.
pic 1 - bolt rotor to hub assembly
pic 2 - tap in knuckle bearing races
pic 3 - press in wheel studs, I used the short side axle to do this, worked great. If you don't have a press, take to a shop and have them do this as a hammer did not work for me.
WWW.WAGONRACKS.COM
Old 02-13-07, 02:04 PM   #20 (permalink)
1973Guppie's Avatar
pic 1 - don't do this! I am a moron and didn't support the rotor correctly in the press, thing sounded like a shotgun going off! wish I was wearing some of those astronaut diapers when that happened, my wife came out to see WTF and looked at me like I was crazy.
pic 2 / 3 - tap in the new inner and outer bearing races.
WWW.WAGONRACKS.COM
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/137225-minitruck-front-axle-disc-brake-conversion-dummies-faq.html
Posted By For Type Date
Minitruck Front Axle Disc Brake Conversion For Dummies (FAQ) - IH8MUD Forums This thread Refback 02-10-09 12:56 AM
WTB: 40/55 disc front axles + birfs - Page 2 - Rising Sun Member Forums This thread Refback 01-02-09 07:12 PM
tight steering This thread Refback 12-27-08 01:10 AM
frein a disque sur BJ 40 - Forum 4x4 This thread Refback 12-05-08 06:10 AM
FJ40 Disc Brake Conversion - Page 3 - Rising Sun Member Forums This thread Refback 06-29-08 06:43 PM
Outer Limits 4x4 Board :: View topic - '64 FJ40 Front Diff disc brake conversion This thread Refback 04-15-08 05:40 AM
como le pongo frenos de discos a mi tlc???? - TwistedAndes This thread Refback 01-05-08 04:46 PM
Outer Limits 4x4 Board :: View topic - '64 FJ40 Front Diff disc brake conversion This thread Refback 12-20-07 03:30 AM
