Old 02-09-07, 06:38 AM   #1
Herb's Avatar
TLCA# 18324
Coolant overflow bottle (FAQ)
I just added a coolant overflow bottle to my '71. Originally, it was just draining the coolant overflow onto the driveway.
I bolted the overflow bottle to the side of the radiator housing and ran the tubing into the top and sealed her up with duct tape as I don't have the cap. The bottle top sits about level with the radiator cap.
Since doing this I've had coolant leak at the lower rad hose....and I'm wondering if it has anything to do with how I've connected this coolant overflow bottle. Does this overflow bottle need to breathe?...it can't now as it is sealed up with duct tape. Does it need to sit lower down in the engine compartment to facilitate flow?
Thanks for any suggestions....
'71 FJ40
Herb is offline   Reply With Quote
Old 02-09-07, 06:58 AM   #2
yotawheeler's Avatar
mmmm dont take my word for it but im pretty sure it needs to breath, mine didnt have a over flow bottle on it either and i just riged it up with a 2L pop bottle drilled a hole through the cap and never used anything to seal it....the hose was a pretty close fit though and it seems to be working
in my driveway....
'74 FJ40- disc brakes, saginaw,8274. SM420 sitten in the shop just waiting
'78 FJ45 project rig
x2 '81 BJ42
'86 HJ60
yotawheeler is offline   Reply With Quote
Old 02-09-07, 07:19 AM   #3
Shawn Russell's Avatar
Yes, it needs to breath. When the water goes in the bottle, the air has to go out.... The suction of the water cooling in the engine will draw the water back into the engine.
Shawn
65 V8J45 SWB, 70 V8J40
Shawn Russell is offline   Reply With Quote
Old 02-09-07, 07:21 AM   #4
EH!
steverb's Avatar
i keeped loosing my lid so now i just dont put one on. but the fluid dosent spill out so i just leave it with the lid off.
steverb is offline   Reply With Quote
Old 02-09-07, 08:29 AM   #5
Herb's Avatar
TLCA# 18324
Thanks guys...I'll let it breathe then.
CHeers.
'71 FJ40
Old 02-09-07, 12:32 PM   #6
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
The 60 series trucks have a great coolant recovery tank system that I have installed into early 40 series that did not come with them.
These pics are of the bottle and mount that I am running in my junk:
Old 02-09-07, 12:35 PM   #7
Poser's Avatar
TLCA# 1856
Another truck in the shop...
This configuration put the tank on the passenger fender with a little braket I fabricated and welded the Toyota bracket to:
Old 02-09-07, 12:37 PM   #8
Poser's Avatar
TLCA# 1856
The new OEM pieces and part numbers:
Old 02-09-07, 12:53 PM   #9
wantatlc's Avatar
jeezzz... no coolant container thread would be complete without this...
http://forum.ih8mud.com/1324075-post.html
SoCal FJ - 1974 FJ40 | Trail Photos | Parts Wanted & 4Sale
My FJ is better than your honor student
SPECS: SBC 350 | 4spd | Front discs | Saginaw | 33's | 3" lift SUA | Rancho 9000's | Detroit rear | Dual gas tanks | BeCool aux fan | Sliders | Onboard air | Stamped Bezel
wantatlc is offline   Reply With Quote
Old 02-09-07, 04:49 PM   #10
Focus on the Journey
bsevans's Avatar
TLCA# 16217
or this
Coolant Recovery and Winshield Washer Tanks
78 FJ40
ARB's F&R, Rear Disks, DUI HEI, 200 Amp Alt, OME 2.5, 33x10.50, PS, RE8000, Stout Rear Bumper, 4+Plus Sliders/U-Bolt Flip Kit/Tie & Relay Rods/Anti-Inversion Shackles, Dual Tanks, BTB Dash Box, Tuned Ceramic Coated Headers, Extended Axle Vents, BrakeQuip Custom Certified SS Brake & Clutch Flex Lines
ROTW My Yoda|HD Skid Plate|Recovery & Windshield Washer Tanks|Toyota Pulley on GM Pump|Bypass Hose
bsevans is offline   Reply With Quote
Old 02-09-07, 04:51 PM   #11
numtel's Avatar
TLCA# 14946
I just use the generic one from kragen's. It works great. Has a vent and comes with some hose.
numtel is offline   Reply With Quote
Old 02-09-07, 04:54 PM   #12
Poser's Avatar
TLCA# 1856
Thanks for adding those guys!
Old 02-09-07, 04:59 PM   #13
...put you in an FJ today
jsaltlick's Avatar
TLCA# 17094
My overflow bottle is a plastic Folgers coffee container. It's a one-off restoration item. Very rare.
John
1983 VJ47 Crew Cab "The Great Pumpkin"
1992 M-101
Tons of 40 parts for sale
<---Link
Finally I can get what I've always wanted....a used Toyota.
jsaltlick is offline   Reply With Quote
Old 02-09-07, 11:42 PM   #14
elder statesman
65swb45's Avatar
TLCA# 1086
Herb, if you pay close attention to the FJ60 bottle assembly pics that Poser posted, you will notice that where the hose goes into the bottle, it goes in via a tube that extends down into the bottle. The older units also had a tube, and the ones before that fed the coolant in from the bottom.
The point is that if your 'feed' either goes in from the bottom, or reaches down to the bottom, it will 'draw' back in to the radiator better, and will also help reduce blowby from the bottle.
Best
Mark A.
A carbureted man in a fuel injected world.
65SWB45, 64LWB45, 68FJ40,72V840, 76HJ45[going],84FJ60[gone], 76K5, 73Sub454, 89Sub7.4[gone], 97Sub5.7
TLCA delegate, Trail Crew-LAC TLCA, The White Trash of the Elwood Chapter
my website:
http://www.marksoffroad.net
65swb45 is offline   Reply With Quote
Old 02-10-07, 12:25 AM   #15
Lt1cruiser's Avatar
I also use the generic one and it does work great its mounted it on the Radiator support.
1971 FJ40 - 350 SBC with stock 3spd & T-case, 2 in. Shackle lift., 31 Remington Wide brutes, Front and rear locked, HEI.
1970 Chevy CST/10 - Completely stock, P/S, P/B, A/C, 402 Cu. BBC, Long bed, Posi.
1967 VW Baja-bug - Stock 1600CC, Rear disc conversion, straight pipes, 6 pt. cage, new paint.
Lt1cruiser is offline   Reply With Quote
Old 02-21-07, 06:13 PM   #16
badass's Avatar
TLCA# 16412
Poser, how much all these peices cost from toyota? Thanks.
79 fj40- Safari Snorkel, Mini-truck ps, 4:88 gears, ARB Rear Locker, Aussie front, Shackle Reversal, 35 MTRs, 5.5 SUA lift front, 2.5 inch OME SOA in rear, ARB Bull Bar, Choctaw Sliders, Kaymar Hi-lift mount on passenger side, and a solid 8 mpgs
badass is offline   Reply With Quote
Old 02-21-07, 06:22 PM   #17
Poser's Avatar
TLCA# 1856
I do not remember...
Send cruiserdan a pm, listing the part numbers and he should be able to let you know.
Old 02-21-07, 06:42 PM   #18
long inner hose on 40 series coolant bottle
So....my 60 has that setup; it's got that longer hose dipping into the reservoir.
My 40 (new to me) has the bottle, but no hose going to the bottom. Should I have that? Pics and intro to the 40 side of the world coming soon. :-)
1987 FJ60, SROR Sliders, lockers, 4.11s, 33s and other stuff
1977 FJ40, mostly stock.
CardinalFJ60 is offline   Reply With Quote
Old 02-21-07, 06:53 PM   #19
Poser's Avatar
TLCA# 1856
Yes, it will need that in order to draw the coolant/fluid back into the engine...unless the hose comes out of the bottom of the coolant container...
Old 02-23-07, 07:18 AM   #20
Herb's Avatar
TLCA# 18324
OK, thanks guys. I have insterted a tube into the top to act as a breather, it goes to the bottom of the tank, then up and out and is fastened to the outside of the tank, pointing down. The tube from the radiator goes in to the tank and goes all the way to the bottom in order to allow it to draw fluid back in.
Thanks to all for the help.
'71 FJ40
Old 02-23-07, 07:19 AM   #21
Herb's Avatar
TLCA# 18324
Poser, thanks for the part numbers and pictures....that is good stuff. I may need to replace my rigged set up once I finish with all my other "issues".
Cheers!
'71 FJ40
Old 02-23-07, 01:39 PM   #22
IH8MUD "I Live Here"
Volunteer's Avatar
TLCA# 16325
You're the man, I need one of these jewels right now. Called earlier in the week for a factory 78 jug to replace mine as it just cracked when I snapped the cap on and like everything else I call about its discontinued. I will go with this setup.
NObama '08
Bayou State Land Cruiser Assoc
Volunteer is offline   Reply With Quote
