LinkBack (21) Thread Tools Display Modes
Old 07-15-07, 03:25 PM   #181 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
Well it's time to start work, I had planned to pull the engine out after Vic Winch Challenge in late Aug and have the new 2F-ETI ready for comp in March 08.
Someone had better ideas though and moved Vic Winch this week to late Nov
So things have moved up a little. We would have had a good 6 months to play with to do this in now we have just over 3
The engine builder has now been told to source a short motor 2F for our needs and start work as I don't have the luxury of time to pull mine out and play with that.
This will however mean I have a spare tweaked 2F in the shed.
Now the one thing we have not yet discussed in detail is the Turbo, the engine builder is looking at at least 300 hp but maybe as high as 400 hp depending on boost
Now I have been searching through the net and I am pretty spoilt for choice the question is, who make a good Turbo Charger?
For my 2c I can't see us making it in time but we will give it our best shot to be ready for mid Nov and the new Vic Winch dates.
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 07-16-07, 12:43 AM   #182 (permalink)
Lifer with a 2F-ETI
Hi Matt,
Regard to our disscussion this morning. The estimated horsepower is 400 @ 5000rpm, Blower boost required approximatly 12lbs, compression ratio 8.5:1 and camshaft specification duration 220deg @.050". Valve lift .475" approx
If you require any further info please contact me.
Regards
Col
Who has any experience with these?
Turbonetic
Garrett
Any recommendations?
Links
Mac's Space
On the rev limiter
Old 07-16-07, 03:03 AM   #183 (permalink)
Matt, if you wanna know about turbo chargers, prob best to head over to a performance car forum such has Hot4s or fast 4s etc, guys over there would probably have alot more experience with turbos and what sort of engines they are best suited to etc..
- Dave
kiwi-fj40 is offline   Reply With Quote
Old 07-16-07, 04:13 PM   #184 (permalink)
Lifer with a 2F-ETI
- Dave
Tks not a bad idea at all, I hae been reading through the tec stuff on the Garrett site and my head hurts
Links
Mac's Space
On the rev limiter
Old 07-18-07, 11:58 PM   #185 (permalink)
Lifer with a 2F-ETI
Well after a few days in a dark room with my 14 year old daughters scientific calculator we have concluded I suck at math.
My Daughter however says the most suitable turbo size would be a Garrett GT3582R I new I had kids for a reason
Links
Mac's Space
On the rev limiter
Old 07-19-07, 10:25 AM   #186 (permalink)
Klunky Chris's Avatar
TLCA# 4821
Originally Posted by matt.mcinnes View Post
Also the Nissan Skyliner injectors are not compatibale with the fuel rail grrrrrr close but no cigar so back to the drawing board there, are well only $50 Aus back on Ebay they go.
Don't know if this helps you, but back when I was looking at building my 87 Supra Turbo, one trick everyone used was early Lexus V8 Injectors.
Fit perfect and had a lot more flow.
I have no idea how either relate to the 3FE, but it might be worth a look?
(Also swapping in the V8 air flow sensor gave a lower reading for a given amount of airflow. The whole system when tweaked a bit with fuel pressure and bypassed airflow would trick the factory computer into running withing it's mapping )
Chris Basehore TLCA# 4821
74 FJ40- built F, knuckles/brakes from a FJ60, Longs, 4" Pinnacle sucks big wads, mini PS, shite paint
93FZJ80 "klunky"- E-lockers, home built sliders, IronPigOffRoad bumper, CDL switch, D-less, mucho maintenance
www.ILUVROCKS.com
Klunky Chris is offline   Reply With Quote
Old 07-19-07, 10:30 AM   #187 (permalink)
TLCA# 4821
Turbonetic
Garrett
I *thought* the factory Supra turbos were Garrett?
could be wrong though. I think they're a good product though. Make sure you get one that's oil cooled and plumbed into your oil lines. That was much better than a sealed when I was into it, but it's been a few years and things might have changed???
www.ILUVROCKS.com
Old 07-19-07, 09:42 PM
matt.mcinnes
This message has been deleted by matt.mcinnes. Reason: repost
Old 07-19-07, 09:48 PM   #188 (permalink)
Lifer with a 2F-ETI
Had a good search around for Supra Turbo injectors and can't find anything in Oz that does not involve changing the fuel rail and other bits with high enough flow rates
Came up with these is the states TOYOTA Supra 87-92 Turbo 550cc Direct fit Injectors by Venom on an eBay
http://cgi.ebay.com/ebaymotors/TOYOT...14279365QQrdZ1
Links
Mac's Space
On the rev limiter
Old 07-22-07, 11:43 PM   #189 (permalink)
Lifer with a 2F-ETI
Big thanks to the Akarilo and his thread http://forum.ih8mud.com/60-series-wagons/163559-can-you-turbo-3fe.html
We will go the same way for the exhaust manifold to the turbo
Only difference been I will go a 2 into one collector at the T3 turbo manifold
Links
Mac's Space
On the rev limiter
Old 07-23-07, 11:33 AM   #190 (permalink)
TLCA# 4821
dang!
thought maybe they would be interchangeable....
did you check on any of the Toyota V8 stuff?
www.ILUVROCKS.com
Old 07-23-07, 12:26 PM   #191 (permalink)
Lifer with a 2F-ETI
Originally Posted by Klunky Chris View Post
dang!
The ones I found in the USA on eBay are an after marker stright swap 550cc as apossed to the 213cc originally fitted with. These will do just fine.
V8 injectors tend to be smaller due to more cylinders and the flow rates for a Turbo are far higher.
The Supra ones were a great Idea, Much better after market performance parts for these and only $20 shipping to Oz
Links
Mac's Space
On the rev limiter
Old 07-24-07, 05:41 PM   #192 (permalink)
Lifer with a 2F-ETI
Just an update on an earlier post now I have the Jaguar con Rod specs.
Jaguars straight 6 Cyl 4.2Ltr E Type con rods come in at 7.75 center to center the new JE pistons will be more akin to the 3F-E and the hight of these will set the compression.
Today I got to touch them
Now on with the 3F-E headers, the PO had just hacked them off at the exhaust pipe and as always sods law applies 3 out of the 4 exhaust bolts were no problem at all the 4th is now round
Ah well another little job for the tool maker at work before I shot blast them ready to be ceramic coated. I was also tight enough not to throw out the heat shields which I think may now come in very useful Oh yes and to find something to fill that strange hole in them that I can find no use for.
Links
Mac's Space
On the rev limiter
Old 07-24-07, 06:01 PM   #193 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Matt,
The big hole in the exhaust manifold was probably for the EGR. I used a freeze plug to fill it.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 07-24-07, 08:51 PM   #194 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Some good stuff.
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
"What fits your busy schedule better, exercising 1 hour a day or being dead 24 hours a day?"
Old 07-24-07, 10:09 PM   #195 (permalink)
Lifer with a 2F-ETI
Originally Posted by pappy View Post
Matt,
Cool TKS
Oh yes I was been sarcastic
Links
Mac's Space
On the rev limiter
Old 07-25-07, 08:38 AM   #196 (permalink)
MonstA T3/T4 INTERNAL WASTEGATE 600HP TURBO
this a good turbo my mate had got one brand new off ebay for $250 i dont know to much about 4x4 but turbo cars i do and i think these turbos are best bang for buck and good for up to 600hp
http://cgi.ebay.com.au/MonstA-T3-T4-INTERNAL-GATE-T04E-T04-600HP-TURBO-NISSAN_W0QQitemZ330149289339QQihZ014QQcategoryZ438 08QQrdZ1QQcmdZViewItem
bigluxs is offline   Reply With Quote
Old 07-25-07, 04:43 PM   #197 (permalink)
Lifer with a 2F-ETI
Well a little more bling, now time to send the headers off to be ceramic coated
Links
Mac's Space
On the rev limiter
Old 07-25-07, 08:09 PM   #198 (permalink)
Lifer with a 2F-ETI
Con Rod Bolts are coming from ARP
Links
Mac's Space
On the rev limiter
Old 07-26-07, 05:14 PM   #199 (permalink)
TLCA# 4821
GREAT!
Glad to help! I'm enjoying this thread too much!
www.ILUVROCKS.com
Old 07-27-07, 03:39 AM   #200 (permalink)
Lifer with a 2F-ETI
The headers have gone to Jet Hot for their Ceramic Coating
Links
Mac's Space
On the rev limiter
Old 07-27-07, 06:17 AM   #201 (permalink)
agent orange's Avatar
TLCA# 16545
Whats the part number for the ARP rod bolts?
This is gonna be sweet, i cant wait to see it done.
1988 FJ 62- SUA, 1" body, 34" trxus mudders, 2.5" exhaust, 27spl Longs/Pig Inners, 4.88s, torsen LSD/lockright, 4runner brakes, other random stuff...
1986 pickup- 2wd, 22r, 4 speed, DD
1985 F-150- mpi 302, future tow rig
agent orange is offline   Reply With Quote
Old 07-27-07, 03:57 PM   #202 (permalink)
Lifer with a 2F-ETI
I'll catch up with the engine builder and get the ARP rod bolts part No, but remember these are to suit a Jaguar con rod not a 2F.
Now I had a look at a few options around for filling the the EGR hole on the headers and elected to us a 3/4 BSP Plug in Stainless Steel as this was the easiest for me.
So the metric hole was re tapped with no drilling required to 3/4 BSP and a plug fitted and stud locked.
The plugs are a stock item at most pneumatic outlets who deal with galvanized pipe, or a good plumbers merchant.
Links
Mac's Space
On the rev limiter
Old 07-28-07, 03:56 AM   #203 (permalink)
Lifer with a 2F-ETI
Well did a little more today and came across a surprise, the heat shields off the 3F-E headers I thought were some kind of fiberglass or moulded plastic but actually they are two layers of thin metal pressed and folded together.
So rather than just washing off the mud and giving them a good scrub I popped into work and shot blasted them clean.
Now the question is will these give me any benefit if i have them ceramic coated along with the headers or will a coat of heat proof paint do just as well.
Links
Mac's Space
On the rev limiter
Old 07-28-07, 10:57 PM   #204 (permalink)
Lifer with a 2F-ETI
Well ever since I rebuilt my 40 after this in early 2006
With this from eBay
Back to this
I have had this hole from the PO, in which resided a vacuum gauge to show how economically you are driving. Now come on we all know this is a total waste of time, it's a 40 and the only way it's going to be anymore economical it to make it lighter. So I did and through the gauge out
The old air filter and snorkel left a hole which lent it's self perfectly to the twin battery isolator switch in red. (comp requirement)
The ash tray and radio hole became
Well for just over a year now I have had this annoying hole just above the head light switch Well guess what I found a use for the hole
Now I have only to fit and connect the turbo and find a use for the long range fuel tank hole.
Links
Mac's Space
On the rev limiter
Old 07-31-07, 05:50 PM   #205 (permalink)
Lifer with a 2F-ETI
All quite when I got home for work this morning
Sprayed the Heat shields yesterday for the headers
Paint has to cure in an oven for best results
Windows are now wide open hmmmmm this stuff stinks
I think I'll stack the dish washer
Might be in trouble this time.
Links
Mac's Space
On the rev limiter
Old 08-02-07, 09:22 PM   #206 (permalink)
Lifer with a 2F-ETI
Injectors are in bound from TLF $335US Plus shipping
http://stores.ebay.com/TLFperformanceparts
Flow rates for these are 550cc plenty for what I need
Headers will be back next week, Time to start saving for the Turbo and ECU
Links
Mac's Space
On the rev limiter
Old 08-08-07, 05:38 PM   #207 (permalink)
Lifer with a 2F-ETI
Well the headers are back
But so bling are they i elected to put the heat shields on so not to hurt your eyes
Now your eyes have adjusted
Might have to get some shinny anodized bolts to replace the old heat shield ones
Links
Mac's Space
On the rev limiter
Old 08-08-07, 05:57 PM   #208 (permalink)
what he said
Mace's Avatar
TLCA# Something
400 hp??
You really need to dyno this thing..
I am kinda gay.......
My Myspace
Old 08-08-07, 08:06 PM   #209 (permalink)
Lifer with a 2F-ETI
Originally Posted by Mace View Post
400 hp??
Oh we will we this thead started with a Dyno read out and this is where this thread will finish
The Engine may make 400hp and be the most powerful 2F know to man but it is far more likely we will run a little less boost. It needs to be reliable at comp as well as powerful.
Links
Mac's Space
On the rev limiter
Old 08-08-07, 08:14 PM   #210 (permalink)
Lifer with a 2F-ETI
You can tell it's was my birthday this week all my presents are arriving
My injectors from Ebay, top class service too from TLF, I signed for at 11:30am
At Foreign Delivery Unit, August 08, 2007, 9:15 pm, AUSTRALIA
Out of Foreign Customs, August 08, 2007, 2:07 pm, AUSTRALIA
Into Foreign Customs, August 08, 2007, 1:21 pm, AUSTRALIA
Arrived Abroad, August 08, 2007, 1:21 pm, AUSTRALIA
International Dispatch, August 05, 2007, 8:43 pm, Chicago (O'Hare) AMC
Enroute, August 05, 2007, 8:40 pm, CHICAGO, IL 60666
Enroute, August 04, 2007, 10:12 pm, SPRINGFIELD, IL 62703
Electronic Shipping Info Received, August 04, 2007
Acceptance, August 04, 2007, 2:35 pm, CHATHAM, IL 62629
At first glance they looked slightly different but they are a perfect fit.
You can see here why they deliver a little more fuel
Fuel rail now complete
Links
Mac's Space
On the rev limiter
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/134529-2f-3f-e-%3D-2f-eti-into-my-fj40.html
Posted By For Type Date
[3FE] Re: 3FE Turbo This thread Refback 05-04-09 04:09 PM
Turbo or Supercharger on 3F Cruiser? - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 04-11-09 10:19 PM
Turbo or Supercharger on 3F Cruiser? - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 03-15-09 04:05 PM
FOROS DE NUESTRO CLUB • Ver Tema - Potenciación exitosa This thread Refback 03-11-09 09:50 AM
2F Turbo/Super Cargado - foro.cruiserheads.com This thread Refback 03-10-09 02:29 PM
Laminova water to air intercooler - Page 3 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 02-21-09 05:57 PM
1hz flow rates - Pirate4x4.Com Bulletin Board Post #0 Refback 12-29-08 08:06 PM
Chilled intake...? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-30-08 09:34 AM
Outer Limits 4x4 Board :: View topic - changeing 3FE auto to 3F carby manual This thread Refback 11-07-08 12:50 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 07-14-08 02:28 PM
2f + 3f-e = 2f-eti Fj40 - Rising Sun Member Forums This thread Refback 06-05-08 04:04 AM
Untitled document This thread Refback 05-11-08 12:39 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 04-15-08 12:46 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 04-11-08 10:00 AM
Toontoys Forums :: View topic - WANTED - BJ60 Land Cruiser This thread Refback 03-09-08 10:12 PM
1983 FJ45 Troop Carrier Buildup - Page 24 - Expedition Portal Forums This thread Refback 02-21-08 07:19 PM
1983 FJ45 Troop Carrier Buildup - Page 24 - Expedition Portal Forums This thread Refback 02-21-08 12:29 PM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 01-22-08 03:57 PM
Turbo 2f... - Rising Sun Member Forums This thread Refback 12-20-07 01:39 PM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 12-17-07 12:34 AM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 12-16-07 08:27 PM
