LinkBack (21) Thread Tools Display Modes
Old 03-27-07, 09:10 AM   #121 (permalink)
stumpy's Avatar
those prices ARE rediculous. i am going to check around and see if something more like the wolf price can be had in the states. while megasquirt looks like a great solution, the motec seems much more capable.
have you ever found a good list of all the sensors and components you would need to get either of those systems working? i havent read everything cover to cover yet, but i havent seen anything about whose throttle body to use, what MAP sensor, etc...
megasquirt is all GM from what i can tell, is that easy to get in OZ?
when your day just doesnt go quite as planned...
www.machinegunarmory.com
stumpy is offline   Reply With Quote
Old 03-27-07, 11:15 AM   #122 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
Most of the sensors will be Bosch
Check the MotorSport Products
http://apps.bosch.com.au/motorsport/default.htm
The Throtle body will come from the 3F-E but without the Air Flow Meter, that will not be used just a MAP sensor, Knock Sensor and a few others I have yet to fathom
Looks like the Autronic is the way I will be going as it has come highly recomended from here.
http://www.ontrack4x4.net.au/
This is all very new to me so forgive the lack of detialed info at this time, but it will come as I learn
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 03-27-07, 03:09 PM   #123 (permalink)
stumpy's Avatar
i am still trying to figure all of this out myself. how are you going to get it to work without a throttle position sensor? does a MAP negate the need for a TPS?
with one of the programmable spark maps, do you need a knock sensor? i would think that, if you are going to go with a user-programmable unit, you would just tune to knock for each rpm and then back off a few degrees, no?
Old 03-27-07, 04:22 PM   #124 (permalink)
Lifer with a 2F-ETI
Their is a throttle position sensor on the 3F-E injection maifolds throttle body, I will be using that one.
From what I understand so far the knock sensor is most important to stop detonation happening.
M.A.P negates the need for an air flow meter though you can have both to control emissions even better I belive, but don't quote me their. But from what I understand the air flow meter only hinders air flow into the engine. Below you can see why, later Bosch AFM are better I belive but still unnessercery.
Links
Mac's Space
On the rev limiter
Old 03-27-07, 05:54 PM   #125 (permalink)
stumpy's Avatar
yeah, everything i have seen says MAP is better. less restrictive and more accurate than an AFM.
about the TPS, i wasnt clear. have you figured out how to get the right signal out of the toyota TPS? that would certainly solve some fabrication issues trying to get a GM TPS/throttle body onto the 3FE manifold. does autronic allow you to calibrate a TPS based on the sender signal, or does it expect a specific signal pattern?
Old 03-27-07, 10:37 PM   #126 (permalink)
Lifer with a 2F-ETI
The word from the horses mouth at Autronic is not an issue TPS will be fine on the 3F-E even for my dinosaur. and I guess most other ECU's are the same.
You do however need a custom made distibutor to take a timing signal from, though this is nothing too difficult.
Links
Mac's Space
On the rev limiter
Old 03-28-07, 02:34 AM   #127 (permalink)
Lifer with a 2F-ETI
So where are we up to
Heads ready.
Custom con rods are on the drawing board.
All but the cold start injector gasket and the Idle speed control gasket are in, those two were ex Japan and are due in around the 4th of April.
Injectors are ordered and up to 3 weeks, once these and the EFI gaskets are in I'll re-assemble the EFI unit and re cal the TPS to FSM specs.
New thermostat and and rubber gasket to pick up this week.
Pretty much at the point now where everything will slow down a little as the parts for the block come in con rods, JE pistons, the cradle for the crank, custom head gasket and new head bolts.
That will take a couple of months, then the block will come out and all the parts will be assembled along with the work required to it.
From there the 2F-E will go back in and be trailered to have the ECU fitted and set up.
The good news here is my ceramic coated extractors will bolt stright back up for now.
I will have the truck dyno'd at his point and see what we have.
Once the ECU is setteled and everything is running smooth and the bank account once again restored the Turbo will be added and the ECU re programed.
Links
Mac's Space
On the rev limiter
Old 03-28-07, 08:34 AM   #128 (permalink)
what he said
Mace's Avatar
TLCA# Something
What signal do you need from a custom dizzy??
I am kinda gay.......
My Myspace
Mace is online now   Reply With Quote
Old 03-28-07, 08:38 AM   #129 (permalink)
Lifer with a 2F-ETI
Some sort of toothed wheel, so most likley a hall sensor from what I can gather, the ignition will come via coil packs not the dizzy that will just become a timing point from what I see.
Hope that makes sense
If you were to remain with the Dizzy set up I guess you may be able to use the 3F-E dizzy in the 2F motor and stick with the 3F-E ECU but this is not a suitable ECU for TurboCharging.
Links
Mac's Space
On the rev limiter
Old 03-28-07, 08:56 AM   #130 (permalink)
what he said
Mace's Avatar
TLCA# Something
No you are correct.. so you are gonna use the dizzy as a signal generator..
Not a bad idea at all considering you cannot just pull the dizzy (oil pump has to be run somehow..)
Make it sealed, there is no reason to vent a dizzy that is not creating a spark...
Also, remember that most signal generators are based off the crank, so a generator based off the dizzy needs to have twice the number of teeth for a single revolution..
My Myspace
Old 03-28-07, 11:37 AM   #131 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
The 3FE distributor should work pretty well for adaptation to another system. It's already sealed and waterproof and it has a multi-toothed trigger already (far more than six like you may expect, but I've never counted).
Mark...
Mark W is offline   Reply With Quote
Old 03-28-07, 11:58 AM   #132 (permalink)
Lifer with a 2F-ETI
Yep already thinking about that and the best way to achive it.
Links
Mac's Space
On the rev limiter
Old 03-28-07, 12:02 PM   #133 (permalink)
Lifer with a 2F-ETI
Mark...
I'll have a look at the one on the 3F-E in the morning when I get home from work, I have not really paid any attention to that one,
Links
Mac's Space
On the rev limiter
Old 04-12-07, 03:57 PM   #134 (permalink)
Lifer with a 2F-ETI
Well the gaskets finaly came from Japan only took 8 weeks But I have to admit I was a little when I was told the manifold gasket which had arrived 4 weeks ago had been sold yesterday. I had not picked it up as I thought I would wait on all the Gaskets arriving.
Paid in advance too. Few choice words with the General manager and one is been expressed from Japan and will be here today by 2pm. Just over 20 hours. Genuine gaskets too.
Also picked up for a $100Aus a 2F block for the engine builder to work out the measurements for the strenthening of the crank, rather than having to pull mine out and have it off the road longer.
Links
Mac's Space
On the rev limiter
Old 04-13-07, 01:54 AM   #135 (permalink)
Lifer with a 2F-ETI
Here are the graphs for the port and polish and the new valves before and after.
The Cam we will be using gives around .5ins lift
Intake
Exhaust
Links
Mac's Space
On the rev limiter
Old 04-16-07, 07:42 PM   #136 (permalink)
Lifer with a 2F-ETI
Ok heads all done and graphs are in.
Now on with the Con Rods, these are been custom made by my engine builder.
Is anyone else interested in set, if so speak up.
Links
Mac's Space
On the rev limiter
Old 04-17-07, 09:29 AM   #137 (permalink)
stumpy's Avatar
what is your plan on the rods? stronger, lighter, LONGER?
how much do you think they will cost you?
Old 04-17-07, 04:13 PM   #138 (permalink)
Lifer with a 2F-ETI
Stronger yes lighter yes, LONGER would give us more torque and has been discussed but this will be left to the engine builder to make the decision, also I guess it depends on how the drop forged JE Pistons sit.
You looking for a set for your engine too?
Links
Mac's Space
On the rev limiter
Old 04-17-07, 08:08 PM   #139 (permalink)
Lifer with a 2F-ETI
Mark...
Well finally got round to pulling the Dizzy off the 3F-E. The consturction at the top is very different, but the question is will it fit into a 2F???
It seems to have the nessercery timing points required but again are these suitable for a programable ECU?
Their seem to be 2 timming points the bottom toothed wheel which has 24 teeth, that makes sence to me for a 6 cylinder engine as each cylinder has four cycles (Suck, Squeeze, Bang and Blow) 6x4=24
The top wheel has only two timming points, that I would guess at been TDC for 1 & 6
Also from drawings and manuals the 3FE I have in my hand has the drive gear on the other way up to the 2F Dizzy
Need to make a few calls see if I can find a 2F Dizzy to compare it too side by side.
Links
Mac's Space
On the rev limiter
Old 04-19-07, 10:05 PM   #140 (permalink)
hurry up with the dizzy, i wanna drive this thing at vic winch!!
marin
marin is offline   Reply With Quote
Old 04-20-07, 01:19 AM   #141 (permalink)
Lifer with a 2F-ETI
marin
Hope your saving for your tyres, till then back in your box NAVI. Oh no I'm the NAVI this year
Links
Mac's Space
On the rev limiter
Old 04-20-07, 01:51 AM   #142 (permalink)
Lifer with a 2F-ETI
My youngest daughter insists on her pic been on here
with our 40
Now today I picked up an early 2F dizzy maybe some one can tell me the year, but at first glance side by side I recon the 3F-E dizzy will bolt stright in although it looks quite different.
Links
Mac's Space
On the rev limiter
Old 04-20-07, 08:07 AM   #143 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
Off the top of my head, if you use a piston with the same pin-piston face relationship as the 3F, that will allow you to use a longer rod than a 2F piston pin-piston face relationship will.
Rod bolts are going to the most important factor in improving the factory rods.
You don't expect you will be able to loose much weight unless you use lighter material (AL). It is not an overly fat rod.
Mark...
Old 04-21-07, 08:15 AM   #144 (permalink)
Lifer with a 2F-ETI
Measured the two dizzys I have at work and over all though side buy side they look a little different I recon the 3F-E dizzy will fit a 2F block.
Now saying that there were a few minor differences.
The 2F dizzy measured to the point where it seats in the block 122mm from the tip that locates in to the oil pump. The 3F-E dizzy measures 120mm which means when bolted up their is 2mm less engaged to drive the oil pump.
The gear all though the same distance from the tip of the dizzy will sit 2mm higher as well.
The easiest soloution seems to be to strip the 3F-E dizzy down and machine 2mm off where it seats to the block. Not too hard to do.
Before I go down that road does any one have a 2F dizzy laying around they can measure for some comparrisons.
Q also posted here in 60 forum http://forum.ih8mud.com/60-series-wagons/151061-dizzy-q.html
Links
Mac's Space
On the rev limiter
Old 04-22-07, 12:58 PM   #145 (permalink)
awsome thread............holy $hit; I am running scared when I hit 3.000 rpm on my stock 2f!
Lou
n2666s is offline   Reply With Quote
Old 04-23-07, 02:08 AM   #146 (permalink)
Lifer with a 2F-ETI
Lou
Tks,
Long way to go yet but hoping to have the engine in by late August and Turbo'd by Xmas
Links
Mac's Space
On the rev limiter
Old 04-23-07, 06:24 AM   #147 (permalink)
G'day Matt,
It's fantastic to see such a 'technical' thread being posted by a fellow Aussie. The engineering skills of some of the members on this board are absolutely extraordinary and I reckon this thread has to be up there with the best of them. Keep up the good work and I look forward to bumping into you in the bush if you happen to be in East Gippsland.
Cheers,
Ben
P.S. A little of track but I'm curious about your choice of tyres. Why not something more aggresive Claws, Swamper, Simex (even the old faithful BFG muds) etc???
Pauciflora is offline   Reply With Quote
Old 04-23-07, 07:35 AM   #148 (permalink)
Lifer with a 2F-ETI
Originally Posted by Pauciflora View Post
G'day Matt,
Cheers,
Ben
Tks Oh by the way I'm a POM
East Gippsland would be for me the 4, 5 & 6th at Gippy Go Down so if your there say high you can't miss the truck
As for tyres mmmmmmmm http://scotto.3rdrock4x4.com/MattMc40.mov AT's rock but for Comp
After 10 years of drought I can see little point in running simex's for now, they are just wasted for everyday wheeling, the winch is rearly used even with AT's. Out of all the trips I have done I have not been out driven by anyone on Simex's or Swampers infact it's been more the other way around, the At's suit the currrent conditions.
But bring on the rain and watch me bolt the Simex's on
Links
Mac's Space
On the rev limiter
Old 04-30-07, 10:56 PM   #149 (permalink)
Lifer with a 2F-ETI
Well after looking at making our own custom Con Rods we have decided to not to, just too costly for such a small number.
We have elected to order a set from here instead http://www.cunninghamrods.com/ in 4340 Chromemoly
Links
Mac's Space
On the rev limiter
Old 05-11-07, 11:52 PM   #150 (permalink)
Lifer with a 2F-ETI
Finally the wiring loom has come out of the 80 series I got the engine from so of to pick that up tomorrow. Not sure how much of it will be of use a part from the conectors. May run a whole new custom loom.
Links
Mac's Space
On the rev limiter
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/134529-2f-3f-e-%3D-2f-eti-into-my-fj40.html
Posted By For Type Date
[3FE] Re: 3FE Turbo This thread Refback 05-04-09 04:09 PM
Turbo or Supercharger on 3F Cruiser? - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 04-11-09 10:19 PM
Turbo or Supercharger on 3F Cruiser? - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 03-15-09 04:05 PM
FOROS DE NUESTRO CLUB • Ver Tema - Potenciación exitosa This thread Refback 03-11-09 09:50 AM
2F Turbo/Super Cargado - foro.cruiserheads.com This thread Refback 03-10-09 02:29 PM
Laminova water to air intercooler - Page 3 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 02-21-09 05:57 PM
1hz flow rates - Pirate4x4.Com Bulletin Board Post #0 Refback 12-29-08 08:06 PM
Chilled intake...? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-30-08 09:34 AM
Outer Limits 4x4 Board :: View topic - changeing 3FE auto to 3F carby manual This thread Refback 11-07-08 12:50 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 07-14-08 02:28 PM
2f + 3f-e = 2f-eti Fj40 - Rising Sun Member Forums This thread Refback 06-05-08 04:04 AM
Untitled document This thread Refback 05-11-08 12:39 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 04-15-08 12:46 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 04-11-08 10:00 AM
Toontoys Forums :: View topic - WANTED - BJ60 Land Cruiser This thread Refback 03-09-08 10:12 PM
1983 FJ45 Troop Carrier Buildup - Page 24 - Expedition Portal Forums This thread Refback 02-21-08 07:19 PM
1983 FJ45 Troop Carrier Buildup - Page 24 - Expedition Portal Forums This thread Refback 02-21-08 12:29 PM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 01-22-08 03:57 PM
Turbo 2f... - Rising Sun Member Forums This thread Refback 12-20-07 01:39 PM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 12-17-07 12:34 AM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 12-16-07 08:27 PM
