03-07-07, 06:16 AM
#91 (permalink)
Lifer with a 2F-ETI
Called iin at the engine builder today, head should be finished early next week. He's also been good enough to take a few photos of the work, Will post them up as soon as I have them.
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
03-09-07, 02:54 AM
#92 (permalink)
Lifer with a 2F-ETI
Links
Mac's Space
On the rev limiter
03-09-07, 08:10 AM
#93 (permalink)
Cruiser Curmudgeon
Matt,
Would you post a pic of the combustion faces of the OE valves?
It would be good to show people the _large_ recess in the stock valves, particularly the 3FE intake.
Just by installing flat face valves, the CR will be raised quite a bit in the 3FE.
Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's  since 1988.
03-09-07, 08:41 AM
#94 (permalink)
Lifer with a 2F-ETI
Originally Posted by FJ40Jim
Matt,
No Problem
Before: The recessed stock 3F-E Valves, a little hard to see but you can make it out
After: Flat faced Ferrea Winsor Valves
Links
Mac's Space
On the rev limiter
03-09-07, 09:38 AM
#95 (permalink)
mmmm.... my head looks almost identical! did you CC the chambers? i was going to but was told it wasnt worth the effort in a 3FE. i wonder just how far off they are....
03-09-07, 03:28 PM
#96 (permalink)
Lifer with a 2F-ETI
The chambers were cc'd before the work started as I wanted the compression ration to be 8.0:1 once it pick it up on Wednesday I will have all the tecnical information including the flow rates as it was tested before and after the work done.
Links
Mac's Space
On the rev limiter
03-09-07, 03:57 PM
#97 (permalink)
i am looking forward to seeing it!
03-09-07, 11:00 PM
#98 (permalink)
Have you resolved issues about underhood clearance, fuel lines & tank sufficient for the increased pressure, ECM & harness routing & splicing, those kinds of things? What about gauges? Also the head is the closed chamber design, correct? Any issues with using the 2F flat top piston design? I know you've discussed opening up the combustion chambers but that was more for the turbo application, wasn't it? I am considering the 3FE head for my 40, naturally aspirated, but want someone else to do all the difficult, pioneering-type work, someone with the bucks who can afford all the expensive mistakes - my wife is complaining!
03-10-07, 12:44 AM
#99 (permalink)
... Alive
Plenty of room under a '40 hood for a 2FE. The tank is not pressurized, so that's a non-issue. The designs of the 3F, 3FE, and late model 2F pistons are all the saem so far as the combustion chamber is concerned.
There really isn't anything difficult about building a NA 2FE.
Mark...
03-10-07, 03:29 AM
#100 (permalink)
Lifer with a 2F-ETI
Mark...
I'm with Mark here, I think the issues with clearence is only on the early 80 serise 3F-E converting to the longer stroke 2F block. Rather than the other way around. Can't see an issue with the 60 serise as they came first with the 2F as did the 40's.
The Turbo creates many issues from fuel supply to reliability at high boost.
If I was building a NA 2F-E I would be looking at a higher compression ratio, a lot less work to the block. But still room to experiment and using the ECU and harness from the 3F-E. Where as I will run a stand alone ECU with a harness made to suit it, Motec or Wolf still looking at options here.
I would imagin though the power gains for a de smogged NA 2F-E would be worth the effort. But if you build a NA 2F-E first you would have to start over almost to build a 2F-ETI.
I'm sure we will have some issues to over come but thats the fun of building this and the thread.
Links
Mac's Space
On the rev limiter
03-12-07, 11:29 PM
#101 (permalink)
Lifer with a 2F-ETI
The results are in and looking good, just waiting for the graphs from the engine builders.
The cylinder head cc before was 79cc after 80cc with the Ferrea valves but this has remained about the same due to the seating of the valves been deeper I,m told.
Links
Mac's Space
On the rev limiter
03-13-07, 10:35 AM
#102 (permalink)
did you match each chamber? 80ccs is bigger than i was expecting. i would have thought that even though the new valves are seated deeper, your volume would have gone DOWN, not up. what kind of compression are you expecting to get after all is said and done? you took some off the head and block, didnt you? (being lazy, dont want to go back through the whole thread)
03-13-07, 10:42 AM
#103 (permalink)
what he said
Funny, that head design is significantly different than the 2 2F heads I currently have.
the late model 2F head (off of block #2F 889248) I have looks a lot like a bathtub and the 79 2F head is shallower and flatter.. Also the runners are different profiles between the two motors as well.
Neither has the shaped ports..
03-13-07, 12:49 PM
#104 (permalink)
Lifer with a 2F-ETI
I think the shaped inlet ports are only found on the 3F-E head as thats where the injectors sit when the injection rail is bolted up. If I understand you correctly.
Hard to see in this pic but the injection rail seen at the bottom of the photo matches the inlet ports
Links
Mac's Space
On the rev limiter
03-13-07, 12:54 PM
#105 (permalink)
Lifer with a 2F-ETI
The compression will be 8.0:1 but that will be set by the pistons from what I understand not the head cc, although this information is required to set the block and custom pistons to the right hight. Hope that makes sence, trying to take a lot of tec info in from my engine builder here lol
You can see on the second photo on this page that their is some slight machine work to the kidney to accomadate the exhaust port better.
Yes each combustion chamber was tested. This engine will be balanced too.
Links
Mac's Space
On the rev limiter
03-13-07, 09:19 PM
#106 (permalink)
Lifer with a 2F-ETI
Found a better photo from before the clean up, you can see the injectors inside, hence the shape of the ports.
Links
Mac's Space
On the rev limiter
03-13-07, 09:33 PM
#107 (permalink)
Lifer with a 2F-ETI
Final bill pretty close to the estimate
Also the Flow Test HP, CFM I can't recall old age bad memory waiting on the graphs and figures
Before 250HP AFTER 350HP
Now as I understand it this is not the actual engine HP but just the capasity of the max air flow. I think it's like making sure you have enough gas from your fuel pump.
Eg: not enough fuel been delivered engine will run lean and you need a bigger fuel pump, not enough air and it will run rich and you need to increase your air flow.
AS you can see substantial gains can be made from the above work.
Some one please correct me if I'm wrong
I'm told this increase will suit the Turbo well
Links
Mac's Space
On the rev limiter
03-14-07, 11:29 AM
#108 (permalink)
was there a large difference in cc between the chambers? I think some of us are wondering how far off each chamber is.
Chris Basehore TLCA# 4821
74 FJ40- built F, knuckles/brakes from a FJ60, Longs, 4" Pinnacle sucks big wads, mini PS, shite paint
93FZJ80 "klunky"- E-lockers, home built sliders, IronPigOffRoad bumper, CDL switch, D-less, mucho maintenance
www.ILUVROCKS.com
03-14-07, 12:09 PM
#109 (permalink)
Lifer with a 2F-ETI
No all were pretty close and my engine builder would not have bothered if we were not going to try to push the engine so hard.
Links
Mac's Space
On the rev limiter
03-14-07, 08:01 PM
#110 (permalink)
Matt, Mark W.
While I was under the hood today observing the dribble of brake fluid down my booster, it made me wonder if the intake on the 3FE set up will clear it. I have seen a lot of posts on that subject. Does the booster need replacement with the mini-truck unit to provide clearance? It looks like a tight fit there.
03-15-07, 12:26 AM
#111 (permalink)
Lifer with a 2F-ETI
I belive your correct from what I have reading but
I drive on the other side of the road so my brake booster is opposite to your US ones.
Links
Mac's Space
On the rev limiter
03-15-07, 07:06 AM
#112 (permalink)
This is a great thread, thanks for taking so many good pics of the head work. How much meat was taken out of the heads? Im interested to know what kind of material removal nets the best flowbench results.
1988 FJ 62- SUA, 1" body, 34" trxus mudders, 2.5" exhaust, 27spl Longs/Pig Inners, 4.88s, torsen LSD/lockright, 4runner brakes, other random stuff...
1986 pickup- 2wd, 22r, 4 speed, DD
1985 F-150- mpi 302, future tow rig
03-15-07, 07:45 AM
#113 (permalink)
Lifer with a 2F-ETI
Tks, the photos were taken by the engine builder for me.
Hard to say what porting and polishing gains for the flow as the valves were done at the same time, it all certainaly helps. Porting was matched to the manifold gasket I belive, If you look closely at the photos you can see the lines that the ports were opened up to. Pic 4 I think marked on the head.
The big improvment will be from the oversize valves and the selection of the right cam. As I understand it.
The desison on the cam has all ready been made and the air flow tests were to this cams specs.
Also remember this will be as you say, De Smogged
Links
Mac's Space
On the rev limiter
03-15-07, 11:32 PM
#114 (permalink)
Lifer with a 2F-ETI
Picked the head up today
Here's a photo of the intake maiifold which has been ported to match the head, the hole at the top of th port is where the injector sits.
Well that's stage one just about complete just waiting on a few gaskets from Toyota Japan.
The flow graphs I chassed up today and should be with us shortly.
Links
Mac's Space
On the rev limiter
03-17-07, 05:14 PM
#115 (permalink)
Lifer with a 2F-ETI
Gasket Part No for the 3F-E injection system and Thermostat housing genuine.
Manifold 17172-61060 Ex Japan only ordered 2
Air Surge 17176-61020 Only 11 left in Australia bought 2
Throtle body 22271-61020 Only 2 left in Australia bought both now Ex Japan only
Thermostat/head 16343-61020 Had no trouble getting this but think it will be the same on a 3F
Theromstat housing 16341-61030 Had No trouble getting this but think it will be the same as a 3F
Cold Stat injector 23293-61010 Ex Japan only ordered 2
Idle speed control valve 22278-61010 Ex Japan only ordered 2
Here in OZ the 3F-E only came in the very early 80 series 90-92 I think, as far as I can see the 62 series carried the 3F as we did not have the same emision restrictions. This however means that Toyota carry very few parts on the shelf for the 3F-E here, due to the short life span. Hence buying 2 of each gasket.
Links
Mac's Space
On the rev limiter
03-21-07, 10:21 PM
#116 (permalink)
matt-
i had a long chat with FJ40Jim today about the ECM in a build like yours. i am building something similar and some tuning issues came up. are you planning on using the 3FE ECM? with the additional air and fuel moving through this setup, the ECM may not have enough adjustment ability to compensate for the need for more fuel. since the map also controls spark, you may not be able to get the proper spark curve to get maximum performance. sure, it could handle a mild build, but bumping the compression, more engine volume, better flow, AND a turbo, it seems like you might need a programmable system.
opinions?
03-22-07, 08:36 AM
#117 (permalink)
Lifer with a 2F-ETI
Yep we will be running a new ECU as yet undecided on which and a custom loom too. No air flow meter just a M.A.P sensor from what I understand and a knock sensor as well as a few more, like I have said, this is all very new to me so learning as I go with Turbo, EFI, ECU but it's fun.
Currently looking at Motec and Wolf
Links
Mac's Space
On the rev limiter
03-26-07, 10:42 AM
#119 (permalink)
MoTeC looks interesting. i am going to study that one. i like the ability to run sequential injection, although most of the research i have done says that it wont make much difference in a cruiser. i have been looking into megasquirt for a setup to run my system but i am always open to options. you find a price list anywhere? i just browsed the site and havent found anything...
03-26-07, 02:13 PM
#120 (permalink)
Lifer with a 2F-ETI
Yep but hope your sitting down the MoTecs are not cheap
http://cgi.ebay.com.au/MoTeC-M48-PRO...QQcmdZViewItem
http://cgi.ebay.com.au/MoTeC-M600-EC...QQcmdZViewItem
I think the wolf V500 is looking better value but still serching and reading I'll post up other I find of interest
http://wolfems.cart.net.au/details/635751.html
Here is another, this one came recomended
http://www.autronic.com/
Links
Mac's Space
On the rev limiter
