LinkBack (8) | Thread Tools | Display Modes |
Oh...Durka Durka Durka.
Welcome the the frequently asked questions about the Fj40 and Fj45. As Fj55's share a fair amount of components, there may be some links to posts involving 55 series.
The FAQ will be locked, but the topics that are linked to will still be open, so if new info comes up, or someone has a better way to do something, you can continue the discussion in that particular post. If there are a number of good posts on the topic, the link you follow from here will contain an index of these posts . Hopefully that will keep this post less cluttered. Clear as mud eh? if you have any suggestions, or want to recommend a topic to include in the FAQ, or a post with good Tech, PM me. If, for privacy reasons or whatever, you don't want you username given credit for any suggestions, please include that in your PM. ![]() Hopefully this section will help. A good place to start with any project (SOA, Onboard Air, Engine swaps, and Front End Rebuilds, welding diffs Etc) is IH8MUD Tech Links A N D Tech Triva This will include specifics on axles, trans and tcases, driveshafts, special parts, such as SPEEDI SLEEVES etc... ================================================== = Also, for those Cruiserheads who are working on restoration-type projects and have specific questions regarding the history and accuracy of their projects, we suggest you check into the specific group forums for your vehicle. FJ25 Owners Group FJ45 Owners Club FJ55 Iron Pig Preservation Society Please use these sections only for those oddball items relevent to these rigs....tech issues on engine, transmission, axle, and other mechanical concerns should remain here in the Tech section, since these are universal to all early models of Land Cruisers. ================================================== = Last edited by Poser; 02-01-07 at 07:31 PM. |
General Frequently Asked Question Topics
BEZEL INFO Why the headlamp trim piece is installed with the wide part to the top. Purchasing an FJ-40 / FJ-40 B U Y E R S G U I D E BEST YEAR 40 PAINT CODES The meaning of FJ, HJ, BJ, etc. Best Manual, Factory Service Manuals, FSM info, etc. Rig Of The Week list BEST MODIFICATION YOU HAVE DONE WORST MODIFICATION YOU HAVE DONE BEST CHEAP MODS Misc Torque Specs-Use at your own risk! RUSTY BOLT REMOVAL Cruiser lean Last edited by Poser; 06-17-08 at 09:47 PM. |
Body and Interior
BEZEL INFO Why the headlamp trim piece is installed with the wide part to the top. Data plate info Best replacement tub debate FJ40 Windshield Glass Install Thanks Butch! ![]() PAINT CODES Bedliner info Fender flare info Key blank information diamond plate corner info.. Aftermarket front seat options Rear seat options Soft Top Links Front door compatibility/rear gate/hatch/ambi door info Hard half doors TUBE DOORS Rear lift gate gas struts CO2 setup info Poly vs. Steel OEM fuel tank RUSTY BOLT REMOVAL Rust removal using Electrolysis on a large scale 4-PLUS Tire/Cooler Carrier Install Last edited by Poser; 06-17-08 at 09:48 PM. |
Electrical information/upgrades
L E D bulbs / L E D tail lights Treeroot bib/marker lamp mods Headlamp switch bulb info Speaker/Radio info Heater blower motor upgrade Electric fan Info Difference between a generator and an Alternator. GM Alternator info Ammeter/Voltmeter info Gear reduction starter motor upgrade Last edited by Poser; 03-05-07 at 10:10 AM. |
Engine information
Engine swap/debate info 2F Engine information Broken dipstick guide tube removal info F/2F/3FE Firing Order Valve adjustment info Cylinder head interchangeability. Cylinder head comparisons Air rail plugs... F/2F EFI/TBI and Wiring Harness info Propane tech Intake manifold variations, F-2F engines Pilot bearing removal info Engine Knocks Electronic Ignition Systems interesting ignition info Carb tech (not dietary advice) Carb tech updated carb tech Date code carb identification Weber carburetor information Coolant overflow bottle info Last edited by Poser; 03-28-08 at 03:09 PM. |
Suspension/Spring/Lift, Wheel and tire information
Suspension/lift info Members opinion on tires Wheel Backspacing Drilling leaf springs Last edited by Poser; 02-10-07 at 10:59 PM. |
Power Steering info
Removing early stock steering column Power steering fitting sizes for pressure and return lines for ASE and Metric steering gears/pumps. Saginaw Power Steering info Power Steering pump pulley info Pitman arm info Pitman arm removal/pitman arm puller info Astro Power steering info Scout power steering Mini truck/OEM Power Steering info 60 Series power steering swap info 60 Series pitman arm info Pump mounting/bracket info Last edited by Poser; 02-26-08 at 05:55 PM. |
Lockers Lockers Lockers
The never-ending which one, which axle, Locker vs limited slip debate. Lunchbox locker tech Aussie Locker Installation Cable locker info/options OEM Electric locker Spool info Weld it! The pros and cons of a welded differential. Last edited by Poser; 03-15-07 at 05:42 PM. |
Front axle info, including mini truck brake swaps, knuckle rebuild, cut and turn, etc.
Steering Knuckle 101- Difference between the large and small pattern knuckles on Land Cruisers... Lock Out 101 9MM brake line adapter info Why do my brakes drag after I did a master cylinder or booster swap? Steering knuckle seal orientation (metal ring, rubber ring, flet) Mini Truck Disk Brake Conversion Links Including 1973Guppies write up! Front axle rebuild Seal for disc conversion on Ball and Claw axles Tie rod end bushings mini truck to LC More starter bushings for steering arms... DEATH WOBBLE Adjusting toe in another method to Adjust toe in Front Axle Cut/Turn Hy Steer Front and Rear Axle Swaps/Upgrades 60 series axles under a 40 Axle WMS to WMS numbers Last edited by Poser; 07-03-07 at 04:33 PM. |
#10 |
Rear axle info including disc brake swaps
9MM brake line adapter info Rear disc brake swap info Rear discs on a FF axle Why do my brakes drag after I did a master cylinder or booster swap? Installing a proportioning valve without flaring the brake line " Centering " a rear Land Cruiser axle Last edited by Poser; 03-20-07 at 10:05 PM. |
#11 |
Trans/T-case, Clutch and parking brake info
Trans/T-case, clutch and parking brake including information on the Orion transfer case, Fairey Overdrive and the PTO Gearbox and Winch info Proper clutch disc orientation Pre-fitting pilot bearing to transmission input shaft Flywheel step measurments Speedometer cable oil leak <---- Why your speedometer cable leaks oil at the transfer case, or why you are getting gear oil to the speedometer head and leaking in the cab. Longer parking brake cable info Custom speedometer cables Going through/rebuilding a one-piece tcase More one-piece case rebuild info 3 spd tcase to a 4 spd trans Toyota H55 five-speed tranny and split transfer case info 3 speed T case info 420/465 rebuild parts sources Low gearing options/craw ratio ORION INFO Fairey overdrive PTO Gearbox/Winch info Last edited by Poser; 01-16-08 at 07:59 PM. |
#12 |
It has been requested that when I modify the Frequently Asked Questions list, that I somehow make those new links of information known, so I am going to list them in this post as well as in the section that they are in.
We will see how this works for a while. ![]() DomSmith H55 info thread including parking brake conversion info for the split case H55/splitcase into 02/79-40 series Misc Torque Specs-Use at your own risk! Lock Out 101 TUBE DOORS More one-piece case rebuild info 4-PLUS Tire/Cooler Carrier Install Proper clutch disc orientation Pre-fitting pilot bearing to transmission input shaft Over the fender bench seat Low gearing options/craw ratio Flywheel step measurments Power steering fitting sizes for pressure and return lines for ASE and Metric steering gears/pumps. H41/Orion combo Weber carburetor information BEZEL INFO Why the headlamp trim piece is installed with the wide part to the top. ****** Last edited by Poser; 06-17-08 at 09:49 PM. |
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/13205-%2A%2A%2A-f-q-%2A%2A%2A-frequently-%2A%2A-asked-%2A%2A-questions-%2A%2A%2A-f-q-%2A%2A%2A-updated-17-jun-08-a.html
| New to fjs ?????????? | This thread | Refback | 05-28-08 07:13 PM | |
| Toyota4X4.RU -> TLC40 | This thread | Refback | 05-05-08 11:36 AM | |
| Untitled document | This thread | Refback | 04-20-08 04:45 AM | |
| Colorado4x4.org - The Build: My FJ40 | This thread | Refback | 03-17-08 05:26 PM | |
| Colorado4x4.org - The Build: My FJ40 | This thread | Refback | 03-17-08 05:25 PM | |
| 2F back into the 40 - Rising Sun Member Forums | This thread | Refback | 03-11-08 08:57 AM | |
| Toyota4X4.RU -> TLC40 | This thread | Refback | 02-26-08 03:46 AM | |
| Toyota4X4.RU > TLC40 | This thread | Refback | 01-05-08 03:16 PM | |
Home Loan | Loans | Loans | Paid Online Surveys | Anonymous Surfing |
