Closed Thread
LinkBack (8) Thread Tools Display Modes
Old 01-15-07, 05:20 PM   #1
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Exclamation *** F A Q *** Frequently ** Asked ** Questions *** F A Q *** (updated 13 AUG 08 )
Welcome the the frequently asked questions about the Fj40 and Fj45. As Fj55's share a fair amount of components, there may be some links to posts involving 55 series.
The FAQ will be locked, but the topics that are linked to will still be open, so if new info comes up, or someone has a better way to do something, you can continue the discussion in that particular post.
If there are a number of good posts on the topic, the link you follow from here will contain an index of these posts . Hopefully that will keep this post less cluttered.
Clear as mud eh?
if you have any suggestions, or want to recommend a topic to include in the FAQ, or a post with good Tech, PM me. If, for privacy reasons or whatever, you don't want you username given credit for any suggestions, please include that in your PM.
Hopefully this section will help.
A good place to start with any project (SOA, Onboard Air, Engine swaps, and Front End Rebuilds, welding diffs Etc) is
IH8MUD Tech Links
A N D
Tech Triva This will include specifics on axles, trans and tcases, driveshafts, special parts, such as SPEEDI SLEEVES etc...
Also, for those Cruiserheads who are working on restoration-type projects and have specific questions regarding the history and accuracy of their projects, we suggest you check into the specific group forums for your vehicle.
FJ25 Owners Group
FJ45 Owners Club
FJ55 Iron Pig Preservation Society
Please use these sections only for those oddball items relevent to these rigs....tech issues on engine, transmission, axle, and other mechanical concerns should remain here in the Tech section, since these are universal to all early models of Land Cruisers.
Poser is offline
Old 02-01-07, 05:21 PM   #2
Poser's Avatar
TLCA# 1856
General Frequently Asked Question Topics
BEZEL INFO Why the headlamp trim piece is installed with the wide part to the top.
Purchasing an FJ-40 / FJ-40 B U Y E R S G U I D E
BEST YEAR 40
PAINT CODES
The meaning of FJ, HJ, BJ, etc.
Best Manual, Factory Service Manuals, FSM info, etc.
Rig Of The Week list
BEST MODIFICATION YOU HAVE DONE
WORST MODIFICATION YOU HAVE DONE
BEST CHEAP MODS
Misc Torque Specs-Use at your own risk!
RUSTY BOLT REMOVAL
Cruiser lean
Poser is offline
Old 02-01-07, 05:23 PM   #4
Poser's Avatar
TLCA# 1856
Electrical information/upgrades
L E D bulbs / L E D tail lights
Treeroot bib/marker lamp mods
Headlamp switch bulb info
Speaker/Radio info
Heater blower motor upgrade
Electric fan Info
Difference between a generator and an Alternator.
GM Alternator info
Ammeter/Voltmeter info
Gear reduction starter motor upgrade
Poser is offline
Old 02-01-07, 05:23 PM   #6
Poser's Avatar
TLCA# 1856
Suspension/Spring/Lift, Wheel and tire information
Suspension/lift info
Members opinion on tires
Wheel Backspacing
Drilling leaf springs
Poser is offline
Old 02-01-07, 05:23 PM   #7
Poser's Avatar
TLCA# 1856
Power Steering info
Removing early stock steering column
Power steering fitting sizes for pressure and return lines for ASE and Metric steering gears/pumps.
Saginaw Power Steering info
Power Steering pump pulley info
Pitman arm info
Pitman arm removal/pitman arm puller info
Astro Power steering info
Scout power steering
Mini truck/OEM Power Steering info
60 Series power steering swap info
60 Series pitman arm info
Pump mounting/bracket info
Poser is offline
Old 02-01-07, 05:24 PM   #8
Poser's Avatar
TLCA# 1856
Lockers Lockers Lockers
The never-ending which one, which axle, Locker vs limited slip debate.
Lunchbox locker tech
Aussie Locker Installation
Cable locker info/options
OEM Electric locker
Spool info
Weld it! The pros and cons of a welded differential.
Poser is offline
Old 02-01-07, 05:24 PM   #9
Poser's Avatar
TLCA# 1856
Front axle info, including mini truck brake swaps, knuckle rebuild, cut and turn, etc.
Steering Knuckle 101- Difference between the large and small pattern knuckles on Land Cruisers...
Lock Out 101
9MM brake line adapter info
Why do my brakes drag after I did a master cylinder or booster swap?
Steering knuckle seal orientation (metal ring, rubber ring, flet)
Mini Truck Disk Brake Conversion Links Including 1973Guppies write up!
Front axle rebuild
Seal for disc conversion on Ball and Claw axles
Tie rod end bushings mini truck to LC
More starter bushings for steering arms...
DEATH WOBBLE
Adjusting toe in
another method to Adjust toe in
Front Axle Cut/Turn
Hy Steer
Front and Rear Axle Swaps/Upgrades
60 series axles under a 40
Axle WMS to WMS numbers
Poser is offline
Old 02-01-07, 05:24 PM   #10
Poser's Avatar
TLCA# 1856
Rear axle info including disc brake swaps
Rear disc brake swap info
Rear discs on a FF axle
Installing a proportioning valve without flaring the brake line
" Centering " a rear Land Cruiser axle
Poser is offline
Old 02-01-07, 05:24 PM   #11
Poser's Avatar
TLCA# 1856
Trans/T-case, Clutch and parking brake info
Trans/T-case, clutch and parking brake including information on the Orion transfer case, Fairey Overdrive and the PTO Gearbox and Winch info
Proper clutch disc orientation
Pre-fitting pilot bearing to transmission input shaft
Flywheel step measurments
Speedometer cable oil leak <---- Why your speedometer cable leaks oil at the transfer case, or why you are getting gear oil to the speedometer head and leaking in the cab.
Longer parking brake cable info
Custom speedometer cables
Going through/rebuilding a one-piece tcase
More one-piece case rebuild info
3 spd tcase to a 4 spd trans
Toyota H55 five-speed tranny and split transfer case info
3 speed T case info
420/465 rebuild parts sources
Low gearing options/craw ratio
ORION INFO
Fairey overdrive
PTO Gearbox/Winch info
Poser is offline
Old 03-19-07, 05:42 PM   #12
Poser's Avatar
TLCA# 1856
It has been requested that when I modify the Frequently Asked Questions list, that I somehow make those new links of information known, so I am going to list them in this post as well as in the section that they are in.
We will see how this works for a while.
DomSmith H55 info thread including parking brake conversion info for the split case
H55/splitcase into 02/79-40 series
Lock Out 101
TUBE DOORS
4-PLUS Tire/Cooler Carrier Install
Over the fender bench seat
H41/Orion combo
Weber carburetor information
Even MORE valve adjustment info
(now with color pictures)
ARP connecting rod bolts
Poser is offline
Closed Thread
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/13205-%2A%2A%2A-f-q-%2A%2A%2A-frequently-%2A%2A-asked-%2A%2A-questions-%2A%2A%2A-f-q-%2A%2A%2A-updated-13-aug-08-a.html
Posted By For Type Date
New to fjs ?????????? This thread Refback 05-28-08 07:13 PM
Toyota4X4.RU -> TLC40 This thread Refback 05-05-08 11:36 AM
Untitled document This thread Refback 04-20-08 04:45 AM
Colorado4x4.org - The Build: My FJ40 This thread Refback 03-17-08 05:26 PM
Colorado4x4.org - The Build: My FJ40 This thread Refback 03-17-08 05:25 PM
2F back into the 40 - Rising Sun Member Forums This thread Refback 03-11-08 08:57 AM
Toyota4X4.RU -> TLC40 This thread Refback 02-26-08 03:46 AM
Toyota4X4.RU > TLC40 This thread Refback 01-05-08 03:16 PM
