hey y'all...
tryin to pull the flywheel, then bellhousing, off a 2F so i can put it up on an engine stand.
searched and found a couple of helpful threads:
help with bellhousing
and
Pulling Flywheel?
the tranny/xfer is off, got the bolts out, but i still can't get the flywheel to 'wiggle' off.
anything other than the 6 flywheel bolts that hold it on?
i made up a puller and tried it out to no avail...in retrospect i should have realized that the 6 bolts don't thread into the flywheel itself, ha ha, so i was basically just trying to bend my puller b/c i wasn't even pulling on the flywheel...oh well, chalk that one up to stupidity.
goin to head home and hit it with some more penatrating oil and try again later tonight, but i just wanted to check and make sure that i wasn't trying to pull it off when there was some other fastener or bolt somewhere...
any thoughts?
thanks,
malphrus
