Old 12-25-06, 08:56 PM   #1 (permalink)
paranoid56's Avatar
TLCA# 12202
71 FJ40 build up using my 84 xcab chassis (camotoy)
figured i would post this over here too as some people dont go over to the pirate board..
well, i bought this gem a few years ago, slowly doing things to it, but never really driving it.
This is what it looked like when i bought it nice eh?
I also have owned this for years now. started out as a bone stock truck, and now its a ARB locked F/R, dual cases, bla bla bla.
This truck served me well, was my DD for years, many trips to the hammers and the rubicon. finally bought a car to be my DD (06 WRX wagon) and ended up rolling the toyota
well, now i have two trucks that i cant drive on the streets. and i need something to mess around with
So, i am going to take the FJ40 body off and put it on the 84 truck frame. using everything from the motor and frame down. (man i hope this is a good idea)
So, started with this today.
just kept taking everthing apart.
1971 FJ40 w/ rust
1984 Toyota 4x4 Xcab rock cralwer
2006 Subaru WRX wagon
Want some GPS items? PM me for prices
camotoy
"Of all the things I have lost, I miss my mind the most"
paranoid56 is offline   Reply With Quote
Old 12-25-06, 08:57 PM   #2 (permalink)
paranoid56's Avatar
TLCA# 12202
working alone sort of sucks, but good thing i have a fork lift. getting the flat bed off was a easy with the right toys
had to just take one last pic of my stickers on the back window
before i poked the forks through
luckly this didnt happen till after i had it off the truck, the knot slipped
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 08:58 PM   #3 (permalink)
paranoid56's Avatar
TLCA# 12202
now, this is how the truck sits now.
and just so we know, this is how the FJ40 is sitting now
I am hoping that i will get the FJ40 over to the truck (which is at my work) over this week, and see how it looks
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 08:58 PM   #4 (permalink)
paranoid56's Avatar
TLCA# 12202
well, got the chassis all cut up, took 17" out of the center of the 84 x cab chassis
here is the first cut.
the center part all cut up.
he, never done this before
once cut, i pushed them together, put a bunch of clamps on it and welded it all up.
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 08:59 PM   #5 (permalink)
paranoid56's Avatar
TLCA# 12202
made up some frame plates. outside and inside.
fully welded.
now, the chasis is just right to fit under the body.
next up will be moving the engine back a few inches to match the front bib on the FJ. not sure on the rear drive line yet, as i need some weight on the chassis to see how the driveline angle will be.
FJ40 in the background to size up the chassis
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:00 PM   #6 (permalink)
paranoid56's Avatar
TLCA# 12202
well, got the body on, looks like its going to be stetched in order to have a long enought rear driveline.
the FJ40 body fits real nice ontop of the 84 chassis. once i move the rear shock mount, it looks like it will fit right on top.
i also think i want to have the grill at the front of the truck.
a side shot. i figure i will have to add a foot after the door opening. figure that should be the easyest place to do it.
oh, and one small issue. THIS THING IS WAY TOO TALL its right 8ft tall.
i think i am going to move the rear shackle mount to inside of the frame. that should lower it around 3 inches or so. I also think i am going to add a rear fuel cell to add some weight back there to bring it down more.
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:00 PM   #7 (permalink)
paranoid56's Avatar
TLCA# 12202
well today, i cut up the body and stretched it. added about 14inches. (well, havent added yet )
here are the cut pics.
man, this was a pain in the ass. took me hours just do do this
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:01 PM   #8 (permalink)
paranoid56's Avatar
TLCA# 12202
well, only had sunday to work on the truck, but have had a major headache all damn day..
Didnt get too much done.
started with making a bracket to bold on to the front half of the body, just like the stock set up.
Then i went about making a rear ledge for the new sheet metal to sit on. figured this would be stronger then just welding it directly one.
the hard part was that i had to make that circle shape to match the orginal floor.
so i cut a bunch of slices in it.
then i started shaping it to the shape needed.
and the finished product all ground smothe.
i also drilled holes in it so i could spot weld it on. i also put some small welds on the top to help out.
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:02 PM   #9 (permalink)
paranoid56's Avatar
TLCA# 12202
Next up was the floor. I orderd a full sheet of 18ga (4x12 for 80bucks) i also had them shear 2 14"x4' long strips and 2 16"x4' this way i knew they were perfect
so i cut one to fit on the passerenger side and drivers side. then i finished up making the center bump. I had to do some notching on sides to make it fit perfect.
and the finish result. its not welded yet, and not fully done. but you get the idea. I havent figured out if i want to replace the whole floor yet either. the passenger side has been cut up my the PO, and the drivers side is sort of rusted. I guess it would just be as easy to make a full piece. damn, i wish i thought of this when i was out in the shop today
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:02 PM   #10 (permalink)
paranoid56's Avatar
TLCA# 12202
well, heres heres the flooring. damn shitty looking. and some extra cut holes thanks to the PO
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:03 PM   #11 (permalink)
paranoid56's Avatar
TLCA# 12202
just a pic of a side shot with the side panel on. getting to look a little better.
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:03 PM   #12 (permalink)
paranoid56's Avatar
TLCA# 12202
so, i decieded to just hack out the whole floor. and start from scratch.
I left a 3/4" lip on the sides, and cut right up the the front body mount.
Seemed like a good idea
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:04 PM   #13 (permalink)
paranoid56's Avatar
TLCA# 12202
So, i made a new center crossmember to help support the new flooring, and body. I am doing the flooring in sections for ease of install. but the rear seemed a bit flimsy. so i rolled some 1/4" beads in it.
I also am raising the drivetrain so i can have a flat belly. But looks like i was a bit off on how high i made that center hump. I am going to cut it gown tomorrow to match the rear of the tub.
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:04 PM   #14 (permalink)
paranoid56's Avatar
TLCA# 12202
well redid the center cross member again this time its the same height as the rear part of the tub.
I cut the top off and just replaced the tubing with some 1/2" plate with a nice gusset under it.
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:05 PM   #15 (permalink)
paranoid56's Avatar
TLCA# 12202
once that was finished, i started on the flooring. I used 1x1" tubing to make the under floor supports. Hopfully this should hold up well.
now fully welded to the body. its attached to the front body mount, and under the middle of the door opening and to the new xmember.
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 09:06 PM   #16 (permalink)
paranoid56's Avatar
TLCA# 12202
and here it is with the new floor pannels. all with 1/4" beads looks good. and should last a wile. i am going to spot weld it in and put seam sealer on it all. i need to fix a few of the foot well areas, and build a center hump section. but that should be somewhat easy
1971 FJ40 w/ rust
camotoy
Old 12-25-06, 10:40 PM   #17 (permalink)
tucker74's Avatar
Looking great man - that extra room is going to be nice! Any thoughts on bringing the center of gravity down? She's gonna be tippy for sure
Tucker
'94 FZJ80
'76 FJ40
www.walcs.com
tucker74 is offline   Reply With Quote
Old 12-25-06, 10:55 PM   #18 (permalink)
paranoid56's Avatar
TLCA# 12202
oh yea, i am putting the rear shackles through the frame, that should bring down the rear a few inches. the front of the rears is already frenched into the frame. as for the front, i am contaplating moving the axle forward a little and maybe taking a leaf ouf of each pack to bring it down. Its way too tall as it sits now. almost 8ft tall.
Shane
1971 FJ40 w/ rust
camotoy
Old 12-26-06, 12:47 AM   #19 (permalink)
Silicon 70's Avatar
TLCA# coming soon
You are *#%^ing crazy, but we like this sort of thing here. You got some skills to do that on your own. Keep us posted and keep the pictures coming.
1996 FZJ80 stock and unlocked "GREEN MONSTER"
1970 FJ40 1f & 4spd "BRUISER"
2001 Highlander "CREAMPUFF"
Silicon 70 is offline   Reply With Quote
Old 12-26-06, 06:00 AM   #20 (permalink)
holy hell that is a lot of work.
Looks good!
rabid is offline   Reply With Quote
Old 12-26-06, 06:08 AM   #21 (permalink)
shelfboy1's Avatar
TLCA# none
your work is good some how i missed the point i would have sold the 40 bought a body and put it on the frame to me you are stepping down using a pickup and wrecking a 40 for no reason i wish you luck and keep up the good work
shelfboy1 is offline   Reply With Quote
Old 12-26-06, 06:42 AM   #22 (permalink)
Yankee Toys Prez
Sporin's Avatar
looks great! I envy your fab skills and tools, very cool stuff.
Dave
Prez Yankee Toys
Windsor, Vermont
twitter~sporin
'93 FZJ80 Elockers, MAF/OME lift, 35" TrXus MT's, TJM Front Bumper, RockDog4x4 Custom Rear Bumper
Yankee Toys
Sporin is offline   Reply With Quote
Old 12-26-06, 07:43 AM   #23 (permalink)
oldIron's Avatar
X2 - great work. I wish I had half the skills you have and the shop. Great job so far, although I would be concerned with the overall height as well, but it looks like you are not looking to cruise this on the highway...
"If you choose not to decide, you still have made a choice"
Current build thread http://forum.ih8mud.com/40-55-series-tech/154578-my-sons-71-40-build-thread.html
oldIron is offline   Reply With Quote
Old 12-26-06, 07:52 AM   #24 (permalink)
paranoid56's Avatar
TLCA# 12202
well, the reasion i used the pickup chassis, is that it was already built and a bit lighter then the 40 frame. my pickup already had dual cases, ARBs F/R, just a nice buit up truck.
now the 40 was a pile of rust. had holes everwhere, the whole rear sill was gone, lots of holes in the floor board. the orginal PO swaped a V8 into the truck and did a horable job at it.
I am keeping the FJ40 chassis and building it up slowly (after this build) and putting an alu (or new steel) tub on it and building a nice driver.
Shane
1971 FJ40 w/ rust
camotoy
Old 12-26-06, 07:55 AM   #25 (permalink)
paranoid56's Avatar
TLCA# 12202
oh, i will be driving this on the highway this beast is coming down in height very soon. i want to get the body work done first, then its getting dropped. i can get at least 3 inches just from making it almost touch the frame, then another 10 (hopfully) by reworking the suspension
yea, lots of work, but since i have everthing i need (from dismantling both trucks, this built isnt costing me much money. thats the main reasion i am doing it. i am poor
Shane
1971 FJ40 w/ rust
camotoy
Old 12-26-06, 08:43 AM   #26 (permalink)
paranoid56's Avatar
TLCA# 12202
ok, here are the pics of the 40 when i bought it. it was by no means perfect.
cut fenders with bronco flairs
rust everwhere.
the interior was shot.
more rust holes
so, you pureists see, it was a pile when i bought it
1971 FJ40 w/ rust
camotoy
Old 12-26-06, 10:13 AM   #27 (permalink)
atoyot's Avatar
Bad ass project! Can't wait to see the end result. I think it's a great idea. That 40's body was too far gone for a restore anyway. Awesome work! Can't wait to see it in action. What are you going to do about the hard top? Are you just going to run no top or a soft top? I'm surprised you didn't just make it a flat bed or FJ45 type body! Thanks for the pics.
Originally Posted by Zimm View Post
there is a limit to what one country can afford to do, and we have hit ours. what use is winning their freedom, if it costs us our own?
atoyot is offline   Reply With Quote
Old 12-26-06, 10:13 AM   #28 (permalink)
Cruiseralive's Avatar
The reasons dont matter much to me. I really enjoy watching someone build something different and providing good pictures while doing it. Keep em comming.
Cruiseralive is offline   Reply With Quote
Old 12-26-06, 10:29 AM   #29 (permalink)
paranoid56's Avatar
TLCA# 12202
the hard top will be made to fit the PO cut holes in the roof for some sky lights and it was faling off so it was trashed. i will end up extending the sids, and most likly build up a mold to make a new 40 top.
but for now, it will just have a open top
and the flat bed idea was in my head, i just like the idea of having an extra seat in the back
and thanks to all the kind words. i hopfully will have this thing going in a month or two.
Shane
1971 FJ40 w/ rust
camotoy
Old 12-26-06, 03:38 PM   #30 (permalink)
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Hi All:
"Paranoid56," awesome project! Like others have mentioned, your fab skills are very impressive!
I look forward to watching the progress of this rig! Thanks for sharing with us.
Regards,
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
"The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
Josie'sLandCruiser is offline   Reply With Quote
