Old 12-22-06, 08:27 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
3FE Stroker Has Landed!
Better put on the shades.
Motor still in the crate is the correct color. Other pic was stollen from Pirate. Now if I can only get the engine off Dan's dock.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 12-22-06, 08:32 PM   #2 (permalink)
bjowett's Avatar
Sweeeet!
Brian
Jowett Engineering
Western Massachusetts
08 Tundra Double Cab 5.7 Supercharged AWD
93 FZJ80, locked, 4.6L, 6 speed, Orion FORSALE
04 VW Touareg V8 w/ locker (hers)
80 FJ40 , 83k, PS and AC
05 Yamaha RS Rage Snowmobile
06 Suzuki King Quad
93 VW Corrado Syncro AWD 3.0L
51 Jowett Jupiter Roadster
bjowett is offline   Reply With Quote
Old 12-22-06, 08:33 PM   #3 (permalink)
Fast Eddy's Avatar
TLCA# 18155
is right!
トヨタさん、ありがとうございました。
My '78 FJ40 - '73 and '78 FJ40 parts FS - WTB:Olive (653) Bib and Windshield frame
Fast Eddy is offline   Reply With Quote
Old 12-22-06, 08:50 PM   #4 (permalink)
TLCA# 7767
Looks sweet! How much $$$? Or is it one'a those if you gotta ask you can't afford it deals?
Nick
zebrabeefj40 is offline   Reply With Quote
Old 12-22-06, 08:52 PM   #5 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
To be honest, I don't know. I haven't seen the final tab. Either way you are right, don't ask. I couldn't afford it, but did it anyway. Go figure.
BTW, there is a lot of sweet machine work there. It's as purdy inside as outside.
aka Bushrat
Old 12-22-06, 11:50 PM   #6 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
We're talking about a 2F with a 3FE top end, right?
Mark...
Mark W is offline   Reply With Quote
Old 12-23-06, 02:00 AM   #7 (permalink)
Tigerstripe40's Avatar
Looks nice!
James Henry
Wasatch Cruisers
TLCA 11233
76 FJ40 'SeldomSeen'
91 VZN130 'CanOWorms'
Tigerstripe40 is offline   Reply With Quote
Old 12-23-06, 02:15 AM   #8 (permalink)
Coolerman's Avatar
TLCA# 13645
Cool
Holy smokes, that be one nice looking engine! What are it's specs? These guys build it? http://www.doaracingengines.com/
!Oy my 1971 FJ40
It's not having what you want, it's wanting what you got...
http://tinyurl.com/ygeqfp7 FJ40 Wiring Parts for Sale
http://tinyurl.com/mxj5ve Misc Parts FOR SALE!
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 12-23-06, 05:26 AM   #9 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Mark...
Yep.
Yep. I don't have all the specifics in my hands yet. What I do know is:
Minimal boring (.020") to retain wall strength.
Bored throttle body.
Balanced injectors.
Head ported.
Intake and exhaust gasket matched.
Compression 9:1.
Rotation balanced to zero.
Head benched flowed and cam engineered to match.
Built for torque, not rpm.
aka Bushrat
Old 12-23-06, 06:36 AM   #10 (permalink)
BigRedFJ40's Avatar
nice....... sounds like my the plans for my new motor....... just nrrd to come up wih the cash.......
BigRedFJ40 is offline   Reply With Quote
Old 12-23-06, 06:58 AM   #11 (permalink)
IH8MUD Chupacabra
1911's Avatar
TLCA# 16550
Too cool, 3FE's rule! I guess you're going to have to use a 3FE wiring harness and ECU to get the "E" to work?
Suggestion: use 3/4" conduit C-clamps as hold-offs for the fuel injector wiring loom instead of the stock plastic ones which will eventually melt and allow the loom to contact the EGR tube rail. The hold-offs are fore and aft on the top of the fuel rail.
'80 FJ40, '07 FJC
N5MUD
High Desert Cruisers
"What is life? It is the flash of a firefly in the night. It is the breath of a buffalo in the wintertime. It is the little shadow which runs across the grass and loses itself in the sunset."
- Crowfoot, Blackfoot warrior and orator
1911 is offline   Reply With Quote
Old 12-23-06, 07:39 AM   #12 (permalink)
Gus
Gus's Avatar
TLCA# 12746
Garage
Very cool, did they run it on an engine dyno? Do you know what the torque and horse power figures are?
A bunch of project rigs,current: 73 & 79 FJ40s, future: 64 FJ45
04.5 Dodge 2500 CTD, 04 VW Jetta TDI
Gus is offline   Reply With Quote
Old 12-23-06, 12:24 PM   #13 (permalink)
Fast Eddy's Avatar
TLCA# 18155
This would be a perfect application for a megasquirt-based DIY EFI controller.
http://www.megasquirt.info/index.html
トヨタさん、ありがとうございました。
Old 12-23-06, 12:59 PM   #14 (permalink)
LT
Metal Tech
LT's Avatar
TLCA# 12989
Now you gotta shove a turbo on that bad boy to complete the build
Propane Powered 2f.
LT is online now   Reply With Quote
Old 12-23-06, 01:14 PM   #15 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
Originally Posted by pappy View Post
Yep.
Balanced injectors.
Head ported.
Compression 9:1.
Not meant to be a put down at all, just to let folks know that they can and should do this to any 2FE motor they build. It's all pretty basic stuff.
FWIW, you can bore the pee outa a 2F block with no concerns about wal thickness. If you cared to get cutsom pistons made you could push it well beyond what is considered normal. How does .120 sound.
Nominal compresion of a 2FE that is .020 over is going to be 9.0:! right off the bat.
Opening the throttle body up some is a good move. Larger flow injectors might be a good thing to look into. I'd expect that to be the limiting factor now.
Balancing is always a good thing and should be done top any motor.
I'd expect the camshaft to be in the same range as the more popular carbed 2F cams... about 260+ advertised duration with about 440+ valve lift. (Choices are fairly limited.) :(
This motor will have a good strong lowrange that builds to a very strong midrange and keeps pulling to 5 grand and want to keep going. Probably peak torque at abot 25oo and peak horespower at about 4500. Assuming that they put the most effective cam in it. Broad and flat powerband.
I would expect that you will be very happy with it. IMHO the induction system is the limiting factor for a warmed over 2F. And the shorter rod length is the only thing that the 3FE has going against it. A well built 2FE is about the best you can do with that family of engines.
I currently have two 2FEs on the bench/in crates that I am getting ready to buid soon, and a 3FE that I have to decide whether to leave as a 3FE or turn into a 2FE.
Mark...
Old 12-23-06, 06:39 PM   #16 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
This is going into a 1969. No EGR or AI planned. Yes, it will run the 3FE harness and ECU.
Tim didn't have every thing he needed to make the motor run. The dyno pulls will happen after the motor is broken in.
The injectors flow about 7% more than stock. I don't have the flow sheet yet, but that's what I recall.
aka Bushrat
Old 01-15-07, 02:17 PM   #17 (permalink)
Moby's Avatar
Are the injectors stock units that have been reworked or are they new injectors? If they were re-worked do you know who did the work? If they are new do you know where they came from?
Joel
'89 FJ-62
Moby is offline   Reply With Quote
Old 01-15-07, 02:37 PM   #18 (permalink)
2badfjs's Avatar
WOW!!!!
and i thought i had a built 2f motor..................
"you sure do have a purdy motor"
SOLID ROCK OFF-ROAD
http://www.solidrockoff-road.com/
1991-92 80 series sliders available, WITH CAT PROTECTION!
SLIDERS FOR 40s' 60s' and 80s'
Rear 60/62 bumpers
Front 60/62 bumpers
[sigpic][/sigpic]
2badfjs is offline   Reply With Quote
Old 01-15-07, 04:41 PM   #19 (permalink)
Micah's Avatar
TLCA# 15017
i just have to add to the WOW comments, that is beautiful, let us know how it runs when you get it in.
89 62 257k miles, 4 inch BTB lift, 1 inch Body lift, snorkel, custom front, rear bumpers, M8000
"However, I consider my life worth nothing to me, if only I may finish the race and complete the task the Lord Jesus has given me - the task of testifying to the gospel of God's grace." Acts 20:24
Micah is offline   Reply With Quote
Old 01-15-07, 06:29 PM   #20 (permalink)
Sputnik40's Avatar
TLCA# 6187
That is gorgeous!!!
I went .20 over when I rebuilt my 82 2F and am now running a DUI dist. and GM fuel injection... I wish I had the time to do it over and have it balanced, cammed and maybe shave the head. Other than that - it still flat out runs, except for the damn computer not being able to keep up with low rpm shifts on the SM420 between 2nd and 3rd...
I want to see the numbers on that thing when you get it running .
"The devil made me do it the first time. The second time I done it on my own."
Sputnik40 is offline   Reply With Quote
Old 01-15-07, 09:02 PM   #21 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Original injectors. Don't know who did the work, but I assumed it was RC. I'll try and find out.
aka Bushrat
Old 01-15-07, 09:18 PM   #22 (permalink)
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Hi All:
Thanks for sharing "Pappy," this is an interesting thread. Best of luck with the new power plant in your 'Cruiser.
Regards,
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
"The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
Josie'sLandCruiser is offline   Reply With Quote
Old 01-16-07, 10:16 AM   #23 (permalink)
Moby's Avatar
Excellent, thanks! My 3FE is getting torn down at the end of the month. I'm still trying to decide on whether or not to do a 2F short block, just trying to get all the info I can.
Joel
'89 FJ-62
Old 01-17-07, 12:06 PM   #24 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Pappy you going to post the link to your writup on the convesion and intallation?
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
"What fits your busy schedule better, exercising 1 hour a day or being dead 24 hours a day?"
Trollhole is online now   Reply With Quote
Old 01-17-07, 12:23 PM   #25 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
I would like to wait until I have it more completed. As much as I relish my 15 minutes of FAME, I'm very concerned about the 30 minutes of FLAME.
The answer is yes, but not now.
aka Bushrat
Old 01-17-07, 02:26 PM   #26 (permalink)
stumpy's Avatar
i will be interested when that write up comes on... i have the same setup in my girlfriends basement awaiting assembly. i added 1.84/1.50 stainless chev valves and z28 springs to just about the same setup you put together. i also opened up the F oiling bores to do some of the tricks Mark W wrote up in trails a few years back.
any sources on higher flow injectors? i was just going to clean mine out and hope for the best.
when your day just doesnt go quite as planned...
www.machinegunarmory.com
stumpy is offline   Reply With Quote
Old 01-17-07, 09:14 PM   #27 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Well, I guess it can't hurt since I have been sharing it with those who asked. Link is:
http://ratstew.home.comcast.net/3FEconversion.pdf
Boys, draft means draft so don't flame too hard. It's still a work in progress, as is the motor. I won't feel totally comfortable until I hear it run.
Jon
aka Bushrat
Old 01-17-07, 09:47 PM   #28 (permalink)
Moby's Avatar
Jon
Nice job!
Joel
'89 FJ-62
Old 03-07-07, 11:36 AM   #29 (permalink)
stumpy's Avatar
pappy- who bored out your throttle body? i want to do mine, but my machinist is afraid to do it without the new butterfly in hand.
i hear this is a pretty regularly attempted mod- any cruiser shops have experience with doing it? i would rather send it to somebody who has done it!
TIA
Old 03-07-07, 01:05 PM   #30 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
RC Engineering. Google them.
aka Bushrat
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/126976-3fe-stroker-has-landed.html
Posted By For Type Date
Outer Limits 4x4 Board :: View topic - changeing 3FE auto to 3F carby manual This thread Refback 11-07-08 12:50 PM
