10-23-08, 05:32 AM
#151 (permalink)
 I see firewall mods in your future Dave
Engine came up well with a clean.
I'm doing the same conversion on mine as part of my rebuild, and have had to modify the fire wall to fit around the end of the fuel rail and end runner on manifold.
Couple of pics. keep in mind it's a long way from finished
good luck with your conversion and keep up the good work
Cheers Steve
10-23-08, 05:36 AM
#152 (permalink)
Jeez Steve! that looks sweet! Wanna swap my sh!ttty green parts for your shiny alloy parts! They look awesome! Did you do that yourself? or get it done?
I had been warned about the firewall...was hoping I could fix it with a big f@%king hammer, looks alittle more involved then that, so thanks for the pics!
78 FJ40 4" Lift, F&R AirLockers Daily - 33 MTZ 15x10 ClassicLock Offroad - 35 BFG Krawlers, Staun Internal Beadlocks, 15x10 ClassicII
10-23-08, 05:47 AM
#153 (permalink)
Thanx Dave.
Did it myself. Lots of sanding using different grades of wet and dry and then used a polishing wheel on the bench grinder. took me about a week of late nights
couple more pics
with standard ford air box and tubing, AFM is part of air box lid.
The air intake is on the bottom left front corner. would be a piece of cake to hook up a snorkel
My efforts with a bfh to make it fit. Just ended up a mess
during polishing
10-27-08, 08:37 PM
#154 (permalink)
Thanks for the extra pics Steve.....looks good! Need to source the standard airbox and tubing for mine, and a new AFM actually, as the plastic casing is worn through on my AFM. Nice to know the std. setup fits neatly but.
Have you looked at the power steering bracket yet? it puts the pump way out on the guard by the looks of the 40 that mine came out of.
10-27-08, 09:09 PM
#155 (permalink)
Yeah had noticed that. my engine sits a bit funny due to the engine mounts it has, so the pump actually hits on the shock tower. I will be making new engine mounts to try and get it to sit properly, and then was thinking of sectioning and modifying the bracket to try and get the pump to sit in a bit closer to the engine. Failing that i was thinking of adapting a pump with separate fluid reservoir.
10-29-08, 03:44 AM
#156 (permalink)
mmmmm engine swaps. How bored would we all be if they were just straight fits.
10-29-08, 05:34 PM
#157 (permalink)
Rookie
Originally Posted by Twisty
Was pretty stoked this week, the 40 appeared in the French offroad magazine Option 4x4. They printed it on a full 2 page spread of it climbing up a hill at Glasshouse Mountains. They sent a couple copies of the mag over, and it looks like a really nice mag, pitty I cant read any of it but!
www.option4x4.fr
Heres the pic that appeared....can anyone translate what it says in the bottom left corner?
Full size: http://www.4wdlinks.com.au/albums/FJ...istys_FJ40.jpg
It'll also appear in the next issue (117) of Australian 4WD Action
I looked through the thread (great build btw) and didn't see any proper translation (no offense Andrew), thought I'd give it a shot.
Here goes nothing.
"Oldies but Goodies. This FJ40 is the next big thing in the australian press. And rightfully so : beautifully restored, this 1978 attends all sorts of off-road events in a country where an FJ in such good shape is extremely rare. A good throwback to its origins, this Toyota owner fixed and improved his FJ, so well it even outperforms local trucks with a handful of lockers. Even without lockers, this FJ40 is perfectly suited for the southern hemisphere. Among the upgrades, 4" Dobinson springs, Skyjacker shocks, extended shackles, front disc brake conversion, 35x12,5 Interco TrXus MT tires and a 140L gas tank. All of this while staying true to its original unique styling."
Option4x4 is actually a pretty good mag. Guys from expeditionportal.com would love it I'm sure. I read it every time I get a chance.
edit - indeed the extended thingies are the shackles. Fiex up the text.
10-29-08, 05:41 PM
#158 (permalink)
Cheers Zorro, am guessing the extended bit would be the 2" extended shackles?? And yeah, the mag looked like it had some really good articles, even if I coudln't understand any of the writing.
11-20-08, 04:38 AM
#159 (permalink)
11-23-08, 05:45 PM
#160 (permalink)
Took the 40 down to Ray185s workshop on the weekend to fix a sump gasket leak on the 3f and give it a tune so its right to drive around over xmas, and all sweet to sell to fund the ford donk going in. (huge thanks to Ray for the help  ).
Was the first decent highway run since the new springs have gone in, and its 100 times nicer to drive. Really soaks up the bumps nice, and now that the castor is sweet again, doesnt wander everywhere. Has some bumpsteer, but its fine once you get used to it.
Few pics of the 40 on Rays 30 degree travel ramp.
11-26-08, 03:16 AM
#161 (permalink)
Started sussing out the rear flares a bit more this arve, have had the lasercut mounts for the tube flares for a couple weeks now, but haven't had a decent chance to fit them up properly. Am hoping to get both sides bolted up for next week so then Kane can weld in some infil panels in the front of the wheel arch.
You can also see that the drivers side rear spring does sit a inch or two higher then the rest, hopefully it settles back down to match the rest once I start driving it a little more. Rear panels have been cut to the bottom side of the inner tubs (bout 2" higher then std.)
12-21-08, 02:59 AM
#162 (permalink)
12-21-08, 03:00 AM
#163 (permalink)
Dodgy flex pics, was rubbing on the front guard too much to go further.
The second valve for the internal beadlocks.
My daily driver tyres (33x12.5R15 MTZ's) verse the 35x13.5R15 Krawlers
HUGE thanks to Ryano at Fourby's 4wd Superstore for sorting them all, and brining them up the coast  and to Boof for changing his mind and going back to mudders
01-14-09, 02:58 AM
#164 (permalink)
Have pretty much sorted most of the clearance problems with the krawlers. Good enough to take it out to LCMP next weekend for its first test run with the new susp and krawlers/internal beadlocks.
Tyres still rub on the front apron, and on the inside of the inner tub, but it doesn't look like it'll do any damage to the panels or tyres.
Front guard marked with electrical tape to cut.
Cut.
Didn't loose too much of the std look, and this is only a temp fix till Brooksy makes up some tube fenders.
Rear was cut to match the lasercut mounts I got done for the tube flares. I'll hopefully get some sheet welded into the front of the wheel arch next week, to make the opening back to normal sort of shape.
Tight fit still but.
Haven't bumpstopped the rear yet, but have 3" extended bumpstops in the front. Will sort some rear ones before LCMP but.
01-14-09, 03:00 AM
#165 (permalink)
01-20-09, 02:59 PM
#166 (permalink)
Taking the truck down to Komited Kustoms this arve as the front bar is finished, so we'll test fit all of it, and sort the light and winch mounts on it. Also going to sort the rear bumpstops and weld in some panel to the front of the rear wheel arches.
Since the front bar is now done, I'll get the rear one laser cut and pressed in the next few weeks. Decieded to get it built first before the rear flares, so the flares can match in neatly to the rear bar.
Some pics from Solidworks.
Will get a wheel carrier as well, but I'll just get Brooksy to wing that. Need to sort what LED tail lights to run too, and where to mount the number plate.
01-21-09, 03:59 AM
#167 (permalink)
Kane ended up crushing a finger in a press today, so wasn't able to work on the 40 this arve. Spoke to another mate who has a mig but, and he was free, so we atleast got the front bar all done. Came up really good! Haven't got any pics of it all welded up yet, but heres a quick mock up of it with all the lights and winch in there position. (Thanks to Cracka for the loan of the winch!)
01-25-09, 10:33 PM
#168 (permalink)
Took the 40 out to LCMP for the aust. day weekend. 40 went awesome all weekend. Drives and rides so much better with the new suspension, and am stoked with the krawlers too. Drive nice on dry/wet bitumen, gravel, mud, rocks, love them! Was good have the internals and being able to run heaps lower pressure then usual (10psi front, 8 psi rear).
Only damage from the weekend is the rear shackle bushes flogged out. I think this is from when we relocated the rear mounts they are slightly out. Not sure what the fix for that will be yet....Will put some new bushes in first and see how they last.
Some pics.
Lookout on Sunday Creek Road.
They had plenty of rain lately, so everything was pretty slippery.....All the creeks were flowing nice too. One of the climbs at the start of Jims Jump Up.
Claw Gorge
01-25-09, 10:33 PM
#169 (permalink)
01-25-09, 10:34 PM
#170 (permalink)
Rut on a different part of camp road.
Got some vids that I'll upload and post later too.
01-27-09, 02:07 PM
#171 (permalink)
02-02-09, 08:18 PM
#172 (permalink)
02-02-09, 08:19 PM
#173 (permalink)
02-02-09, 08:20 PM
#174 (permalink)
02-02-09, 08:21 PM
#175 (permalink)
Few Videos.....
Through the gully pictured above.
YouTube - FJ40 Glasshouse Gully
Up the hill at the end of that gully.
YouTube - FJ40 - Muddy Glasshouse Climb
And some awesome news! Am selling all the Ford 250 EFI Crossflow conversion gear and have bought a MWB Cruiser with a rebuilt EFI 5L Holden V8 and Auto. Will put the motor and auto into the 40 and part out of the rest of the Middy  So stoked! Haven't told the missus yet
02-03-09, 09:02 AM
#176 (permalink)
Call me crazy, but why not put a diesel in the truck since they are readily available in Aussie land? A 12H-T or even 1HZ with turbo would be plenty sweet and run upside down.
Glad to see the ford going away though....we use those as fishing anchors over here.
78FJ40 13B-T, 5speed, split, full floater 70 series, cable lockers,4 disk, a/c, 60 pwr steering, all toyota except the a/c.
www.importpurist.com
Oh, and a bitchin FJ45 that may or may not be for sale.
"Much like a cat or hot buttered toast, the correct side will always try to land down. If the bezel is on upside down, then the force of it trying to right itself may cause you to roll your cruiser unexpectedly."
02-04-09, 10:12 AM
#177 (permalink)
junck the V8, Grab a 13B-t like roothy gave Milo! diesels shit over the petty motors! especially turbo diesels!
02-04-09, 05:26 PM
#178 (permalink)
Your crazy Rutbeer
I think cause you's dont have many desiels over there its a case of wanting what you cant have. Desiels do have there place in some types of 4wds, but I've never been much of a fan. Am a fan of the 200 series LC with the twin turbo V8 desiel but.
Anyway, am building this truck for fun, so petrol V8 will win hands down for that. Cant beat the sound of a V8 getting up a obstacle in the bush. If i was building it to tour the country then I'd consider a desiel. All the nice turbo desiels sell for rediculous $$ over here too,
Nah, sorry mate.....dont agree at all.
02-04-09, 06:20 PM
#179 (permalink)
Rookie
Escuse my ignorance, but can you please enlighten me as to how exactly the diesels "shit over the petty motors"? I'm very interested to hear your views if you can find the time to point out the immense advantages a diesel or even turbo diesel has over a petrol motor apart from the obvious water fording capability. Please don't say "because Roothy did it" and feel free to draw me a picture if its too hard to put into words.
02-04-09, 06:52 PM
#180 (permalink)
Wanting what I don't have? Sorry mate...I have had Chevy 350, 1F, 2F, 3F, and 13B-T. I have had in my possession, 3HZ's, a 12H-T and three 13B-T's. The 13B-T I am currently running kicks ass.
To each his own, but you can't beat the economy of the 13B-T and it's power is every bit as good as a strong 2F with the wastegate shimmed a bit. The 350 I had always had heat issues, not horrible, but you had to watch it. Sure, it sounded great and everyone loved it, but I wouldn't do it again.
