11-11-06, 10:15 AM
| | 250+ Club
| Showing my ignorance Never have claimed to be real bright ....but will a vaccume advanced dizzy with a pertronix gizmo out of a 73 1F fit a 78 2f no smog with a webber?....and is a distributor hard to rebuild if gears are not worn...or...is it even worth the time....just for the learnin factor?....
__________________ Political correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end! |
11-11-06, 10:28 AM
| | Knight-errant
| I'll show you mine if you show me yours...
I'm pretty positive it will fit. I ran that same dizzy setup on a late F then moved it to a 2F no problem. Think my 2F block is a '76 or '77. No idea what a Weber has or needs. |
11-12-06, 06:39 AM
| | 250+ Club
| Hey Pighead thanks for the reply...Is there any advantage to keeping the 78 dizzy over the earlier model 1f?...the 1f has only 10,000 miles on it and the 2f has 94,000 miles. ....Where can you find the electronics for replcement?
11-12-06, 07:31 AM
| | Cruiser Curmudgeon
| Quote:
Originally Posted by hatchman Is there any advantage to keeping the 78 dizzy over the earlier model 1f? | The 78 dissy has a ballbearing shaft and is waterproof. Quote: |
| The F dissy shaft run in bushings, which wear pretty quick. The 78-newer run in one or two ball bearings which usually last the life of the vehicle. The Denso electronics are very robust as well, so age is not much of a factor for that. Quote: |
| CarQuest.
__________________ Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's  since 1988. |
11-12-06, 10:00 AM
| | 250+ Club
| Thanks for the info!
11-13-06, 04:43 PM
| | KC6ZWY
| Quote:
Originally Posted by FJ40Jim The 78 dissy has a ballbearing shaft and is waterproof.
CarQuest. | Does this mean that the non-USA distributors come with bushings as well?
__________________ Doug
Olympia WA 1977 FJ40
1968 R60/2 W/Steib S350
1980 CT110
1984 R100ST |
11-14-06, 10:21 AM
| | Cruiser Curmudgeon
| Quote:
Originally Posted by Doug_S Does this mean that the non-USA distributors come with bushings as well? | Yes and no.
F engine- yes
2F- maybe
3F- no.
Jim C.
TLC Performance
