This depends on what you want your rig for.
If you are looking for easy, go mini truck power steering. The box is Solid Axle Mini Truck 1979-1985 from 4x4 toyota. IF you go that route. A FJ40/FJ60 power steering pump can be used if the engine is tapped for it. My engine isn't tapped for the FJ60 pump so I am using the saginaw pump. I got it from Rockauto.com for $52 Part #: 206823. The saginaw pump will need a mounting bracket.
You can also put FJ60 power steering in, scout power steering or OEM.
.·´¯`·..><((((º>`·.¸¸.·´¯`.¸.·´¯`·...¸
