NOTES, skip this message if you are not interested in Tcase specs, Transmissions, or websites about either Tcases or Trannies.
i spent hours on end trying to find what would work with the 4L80E so hopefully anyone considering this swap will find this page and save a little time. the engine/tranny/tcase is out of the FJ and ive been taking pictures. if i can make the 454 work, i will do a write up (wont just yet in case its a flop and i go back to the I6).
transfer cases
203
2.01/1 gear ratio
full time 4wd
chain driven
’73-’79 Dodge, Ford, and GM trucks
cast iron
205
1.96/1 gear ratio
part time 4wd
gear driven
’69-’93 Dodge, ’77-’79 Ford, and ’69-’91 GM trucks
cast iron
near bulletproof, but 6 different models, so make sure it fits
$1095 reman online
208
2.61/1 gear ratio
part time 4wd
chain driven
’80-’93 Dodge, ’80-’86 Ford F-Series and Bronco, ’81-’88 GM trucks, and ’81-’87 Jeep fullsize trucks
aluminum
low gears make chain ok
$685 reman online
bolts and splines match np241
231
2.72/1 gear ratio
part time 4wd
chain driven
’88-present Jeep Wranglers and Cherokees, ’94-present Dodge ½-ton Ram pickups, ’87-present Dakotas, ’98-present Durangos, ’89-’93 S-10 Blazers and pickups, and S-15 Jimmys and pickups.
aluminum
internal oil pump, dodge1/2ton has stronger version. available 4/1 kits
$630 reman online
241
2.72/1 gear ratio
part time 4wd
chain driven
’88-2000 GM pickups, ’89-’91 Blazers, Suburbans, and Jimmys, ’88-’93 Ramchargers and pickups, and ’94-present Dodge ¾- and 1-ton trucks
aluminum
speedo has either mech or electric..so make it match
has 4/1 kit available.
A heavy-duty version of this transfer case is used in the Ram 2500 with the snowplow preparation package, all Cummins diesel-powered Rams, and Ram 3500 dualies.
$630 reman online
bolts and splines match np208 but 241 is Lside drop(i think because of IFS)
242
2.72/1
part/fulltime 4wd
chain driven
’98-present Dodge Durangos and Dakotas, Hummers, and ’87-present Jeep Cherokees
aluminum
better than np231, H1 uses this case with additional oil cooler
none avail online at this time
246
2.72/1
part time 4wd
chain driven
’98-present GM ½- and ¾-ton pickups, Tahoes, Suburbans, Yukons, Denalis, and Escalades
aluminum
great for escalades for pushbutton opperation, but front driveshaft is always spinning
$885 reman online
261
2.72/1
part time 4wd
chain driven
’99-present ¾- and 1-ton GM trucks
magnesium
improved np241HD for 6.0 and 8.1 vortec engines
263
same as 261 but electronicly shifted
strongest GM uses in light duty trucks...not as stong as FORDs 271 and 273...40lbs less though
$1395 reman online
271/273
2.72/1
part time 4wd
chain driven
’99-present Ford Super Dutys and Excursions
magnesium
rated for 7890 lb-ft of torque, and 17500 GVW...holy moly, 273 electronic shift
$695 reman online
dana 300
2.60/1
part time 4wd
gear driven
80-86 CJ jeep
available 4/1 kit, and twin shifter kit
transmisions
700r4 was renamed to 4l60 in 1991
1982 was first year of 700r4 in chev blazers
700r4 4spd 3.06 first gear
4L60-E 4spd 3.06 first
4L80-E 4spd 2.48 first
4L85-E 4spd 2.48 first
..................Advance Adapters.......................................... ................
..................ADVANCE ADAPTERS.......................................
steve at advanceadapters 1-800-350-2223 ex; 526
NP205 to 4L80E
if hooking up a 4L80E, the easiest thing that will bolt is a NP205 79-85, female, 32 spline, figure 8 bolt pattern, hooked to a th400,....found in 1 ton trucks
other 205s will work, but require machining/32spline adapter kits
dana 300 to 4L80E
4.25 inches $517 ...needs 6.5 slipyoke shaft from 2wd tranny
upgrade to 32 spline rear OUTPUT for fourhundred something dollars. adds 1.5 inches though
i need to measure the cone shaft....needs 6.5 inches for dana 300 for direct bolt up with 4.5 adapter, otherwise might need tranny work
...................parts mike parts............................................. .............
...................parts mike parts............................................. ...............
http://www.partsmikeparts.com/aaTran...dapterKits.htm ............
Adapter Parts
partsmikeparts.com notes
50-0410 GM 4L80 4-SP X NP205 71-79 TC $659
50-0401 GM 4L80 4-SP X DANA 300 T/C $449
50-1501 4L80E X TOYOTA L/C 10 SPLINE $519
50-1601 4L80E X TOYOTA L/C 16 SPLINE $519
50-1701 4L80E X TOYOTA L/C 19 SPLINE $529
here were some other websites i felt the urge to copy and paste into my notes page.
http://www.offroaddesign.com/catalog/doubler.htm .......................
GU4033 32 spline input conversion kit for NP205 $200.00....#GU4033 Price - $190.00
TH400 to NP205 figure 8 bolt pattern - $275 (New high strength aluminum)
Full Rebuild kit for NP205 (specify large or small input bearing) - $190.00
input gears...TH400 version 32 spline short input - $135
http://www.sams4x4store.com/Transfer%20Case.htm .....................
GM 4L80 & 4L80E 4SPD TRANS
MUST USE GM SHAFT 8661596 OR 24204289 N/A N/A 50-0401
4.5"ADAP N/A N/A N/A N/A N/A ....DANA 300,23 SPLINE,1980-86,NP208 &,84-86 XJ,NOTE 10
http://www.highangledriveline.com/jb_205lowmax.html http://www.stak4x4.com/4l80.htm http://www.atlas-tc.com/download/SelectChart.pdf http://www.4xshaft.com/index.html
