Old 10-12-06, 09:18 PM   #1 (permalink)
H2o
Replacing 3 speed with 4 speed
I am looking to replace my three speed in my 74 fj40. I was wondering if someone could fill me in on what is involved. are there any extra parts needed? can i reuse my drive shafts?
I hear there is also some advantages of using the three speed transfer for the lower gearing.
thank..
H2o is offline   Reply With Quote
Old 10-12-06, 09:38 PM   #2 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
Garage
Tech links?
FAQ
Info in both.
Old 10-13-06, 08:37 PM   #3 (permalink)
Bad Coco's Avatar
I did this as well in my 71. As I remember it required a 2f bell housing, clutch, and flywheel. Was pretty darn straight foward. Being a pretty much a newbie myself, I may have left something out. Good luck
Don't gnaw on your kitty
Poo-flinger build up: http://www.pirate4x4.com/forum/showthread.php?t=548889
Bad Coco is offline   Reply With Quote
Old 10-13-06, 08:49 PM   #4 (permalink)
springfield user
brian's Avatar
pretty sure either clutch will work. however you will need to use all the parts from which ever one you go with IE the flywheel, pressure plate and disc.
it's only metal, we can out think it.
77-fj40 20th anniversary edition
87-fj60 216K mile DDer
93-fzj80 mall crawler
toyota material distribution center. your source for Factory Service Manuals.
they're alot cheaper than you think.
1-800-622-2033
brian is offline   Reply With Quote
Old 10-13-06, 09:35 PM   #5 (permalink)
I completed this conversion about a year ago. You will need the 2F bellhousing, the drive shafts from a 4 speed model(front is longer, back is shorter) a bearing and gear for the transfer case( 4 speed has different spline count and diameter). I got my gear and bearing from ironpigoffroad.com in Virginia. Used a new clutch, pressure plate and throw out bearing from 2F. Also replaced pilot bearing.
Andy
70 fj 40, 4 speed w/ 3 speed t-case, front disks,
rear locker, mini power steering, ramsey winch, 2.5" lift and 33's
03 Toyota Highlander Limited
07 Dodge Ram 4X4 Mega Cab
AJFJ40 is offline   Reply With Quote
