Adjusted mine last night, tried it running and couldn't really do it right. So I shut it down and did them while sitting. I found they all needed adjusted a little, had 15,000 miles since last adjustment. Helped out alot. I have really been neglecting car care lately, been busy.
I tried something while doing this. Had the engine good and warm, and took temperature measurments with one of those point and shoot infared thermometers. Oh by the way those things are so cool. But what I found was temperatures around the rockers and springs and valves of around 140 to 130 degrees. When I was done, temps were down to around 130 across all the rockers and springs.
So it seems that cooling is probably less of an issue than we think. While the engine did cool some, it quit burning me to touch the rockers, I don't think you get a huge amount of shrinkage in 20-30 minutes time while adjusting and double checking.
Someone else should try this if they think of it. Kind of neat, actually found one cylinder area seemed hotter than the others, running lean maybe, vlaves were a little more out on it than the others????? I should shoot the head again after driving today to see if there are any changes between cylinders now.
1996 T100, Stock, nice truck
1973 FJ-40, Stock
1984 FJ-60, Stock, 225,000+miles
2002 Subaru Forester L, for the wifey
